rans6andrew
Posted: Wed Jan 21, 2009 1:39 pm Post subject: Re: Dutch XL crash findings |
Jim, the engine weight I mentioned came from chucking my engine, exhaust system, oil cooler, water rad and oil reservoir onto my bathroom scales. The weights I saw agree with those from the Rotax 912UL manual. Adding in water and oil brought me up to 67 or 68Kg (149 pounds) if memory serves. The basic engine weighs just 57Kg.
I believe that the Dutch ultralight rules allow 475Kg gross weight. In the UK the rules are 450Kg for a 2 seat microlight BUT the empty weight has to be 450 minus 1 hours worth of fuel at max continuous power and minus 2 X 86Kg pilots which comes down to an empty weight of 268Kg (590 pounds). Apart from the fuel the aircraft must have everything it needs to fly when weighed empty.
If you use a 912, don't fit anything un-necessary, just basic instruments and go easy on the paint it comes inside the 268Kg empty weight. You can help this by removing excess length from bolts (leave 1.5 threads through nuts), round off edges and trim spare material from all brackets, keep wire and hose lengths to a minimum. I saved weight by throwing out a heavy key operated twin magneto and starter switch (8 ounces) and using individual mag switches and a starter button (less than 2 ounces). I have only one fuel gauge (2 were supplied) and a change over switch as this saves some weight and some panel space. I chose not to fit the Hobbs meter from the kit, I will use a handheld radio (not in at time of weighing!). When you put your mind to it there is plenty of savings to be made without affecting anything structural.
This works for a 601UL, I don't know what a 601XL could be built down to if attention is given to keeping the weight down but it must be in the low 600 pounds for the Dutch to be classing them as ultralights.
The aircraft is for daytime good vis pleasure flying, it does not need turn co-ordinator, artificial horizon, panel fit radio, transponder, autopilot, gps, spats, leg fairings, much sound insulation, carpets etc. I see most aircraft pictured on the Zenith website have cockpits with more kit (weight!) than modern frontline all weather fighters. A few ounces here, a few pounds there, it all adds up if you let it.
Andrew.
_________________ A good way through building a 601UL with 912UL.
Still flying Rans S6 with 503. |
GBzodiflyer
Posted: Wed Jan 21, 2009 2:12 pm Post subject: Re: Dutch XL crash findings |
Talking about weight difference , there is a very big difference in weights in the undercariage suppliied.
In usa kits , which is grove wheels etc , and a very heavy main aluminium gear leg , And the original zenair/czaw u,c is two seperate composite legs and light weight wheels /tyres/brakes , which i believe came from
http://www.marc-ingegno.it/index.php?option=com_virtuemart&Itemid=53&lang=en
my xl tail dragger with this lightweight u/c came out at 305 kg painted , weighed on u.s. built load cells .
do you guys in the u.s. have a lighter weight option main gear than the one supplied in the american kit , I am a little concerned as the guys here are building the u.s. version , but will be restricted to 560 kg mtow , a little lower than your 600 kg i think .
Gary .
bryanmmartin
Posted: Wed Jan 21, 2009 2:49 pm Post subject: Dutch XL crash findings |
There is a Grove main landing gear that is considerably lighter than
the Zenith supplied one. it's built from a stronger type of aluminum
so it can be lighter (but more expensive).
Gary .
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
_________________ --
Bryan Martin
do not archive. |
tiethoff
Posted: Wed Jan 21, 2009 5:39 pm Post subject: Dutch XL crash findings |
Lets assume they all are crazy in Europe ! Just pure hypothetical...
Sent: Thursday, January 22, 2009 12:03 AM
To: <zenith601-list(at)matronics.com>
Subject: Re: Dutch XL crash findings
Pure Hypothetical....
Let's say Zenith sold me 372 pounds of aluminum... this 372 does not count
the landing gear, canopy, canopy struts, landing gear fixtures, axles,
wheels, tubes, tires, nose strut, rivets, torque tube, brakes, dual
sticks, engine mount, cowling, canopy rails, flap motor, flap tube/arms,
interior, servos, fuel senders, gauges, bolts, fiberglass pants/tips,
nylon or cables.
Figure my O-200A engine, accessories, oil, engine mount, cowl, metal prop,
prop spacer, heat exchangers, exhaust, spinner come in at 250.
Figure the the misc. steel, main landing gear, rivets, wire, bolts, nuts,
rubber, pumps, batteries, avionics, lights, paint, fiberglass tips,
canopy, interior, cables, etc. come in at 250.
With four gallons of fuel, I am at 860, without fuel 836.
836 - 250 - 250 = 336 pounds of aluminum out of the 372 after trimming.
Assuming you can cut 30% of my engine weight and 30% of my "other" mass,
you still have 372 pounds of aluminum + 175 + 175 = 722.
To reach 590 one would have to trim the aluminum to 240/372 pounds or
shave off 35% off the airframe.
I don't know how anyone in the EU gets down to 590 pounds... 700 I can
see, 590???
http://forums.matronics.com/viewtopic.php?p 26064#226064
psm(at)att.net Guest
Posted: Thu Jan 22, 2009 7:57 am Post subject: Dutch XL crash findings |
Hi Sabrina,
While your statement is technically true, it leaves some issues unmentioned.
First, there is ot need to prove anything the the FAA to get a
certificate. That is, you don't need to prove the weight limit is
OK. You do need to prove you own the plane and that it was built
according to the appropriate rule set such as the 50% rule. The FAA
doesn't seem to concern itself with the general design safety of the
plane when it is certified as experimental.
For many of us, the Private License is a non-issue. The real issue
is the lack of need for a medical certificate to fly a plane that
qualifies as LSA.
Also, you can get your plane certified with a higher weight limit,
but the original design was limited to the 1320 pounds. That means
all the calculations of load limits are based on this weight. If you
fly it at a higher weight (which I'm sure we all will do from time to
time) you reduce the margin for overloading that can occur in choppy
weather or due to heavy handed piloting. You also need to change the
maneuvering speed.
Paul
XL getting close
At 07:06 AM 1/22/2009, you wrote:
| Quote: | Here, the FAA responds to the EAA and has developed a wonderful
EAB/E-LSA system that is efficient, relatively inexpensive and
open. If a builder can prove to the FAA that his particular XL can
carry more than 1320 pounds, he can certify it to that higher
weight, he will need a private pilot ticket to fly it, but the
process is there and it is transparent. No need to lie, no need to
cut corners here.
Gig Giacona
Posted: Thu Jan 22, 2009 9:27 am Post subject: Re: Dutch XL crash findings |
Paul,
While I don't have to weigh my plane with the DAR standing there I do have to show him the weight and balance information. To lie on that form is a violation of the law. As is flight with a MGW over 1320 lbs. I don't plane do do that either.
601XL Under Construction
Thruster87
Posted: Thu Jan 22, 2009 12:17 pm Post subject: Re: Dutch XL crash findings |
You poor buggers.We are allowed 700kg -1540 lbs MTOW and NO top speed limits [other then manufactures recommended] here down in OZ for the LSA category.
Posted: Thu Jan 22, 2009 2:04 pm Post subject: Dutch XL crash findings |
Hi Gig,
What law is it you would violate if you flew your plane over max gross weight?
Paul
At 09:27 AM 1/22/2009, you wrote:
| Quote: | Paul,
alex_001
Posted: Thu Jan 22, 2009 3:29 pm Post subject: Re: Dutch XL crash findings |
just to comment on the weight issue
planes do get weight checked in germany before reg.
my first xl(CZAW)back in 2005 (was the 1st one in germany) had 298kg no seats,no carpet etc, no wheelfairing, no airbox,rotax 912, no radio etc, only asi and alt,BRS, no propspinner,
my current xl has empty 323kg with avionics and other parts on it
most microlights are around this mark pioneer 300, ctsw, etc
there are some heavy ones made from cfk about 350kg ish.
this is also the reason i disscussed with chip Erwin (CZAW) why the sportscruiser has no microlight reg here cause at 330kg it comes to heavy for registration purpose. plane must be empty below 298 incl rescue system.
daveaustin2(at)primus.ca Guest
Posted: Thu Jan 22, 2009 3:57 pm Post subject: Dutch XL crash findings |
Re over gross,
I believe I'm right up here in Canada in that it would invalidate your C of
A and would also render your insurance nul and void.
Dave Austin 601HDS - 912
Posted: Thu Jan 22, 2009 4:00 pm Post subject: Dutch XL crash findings |
Hi Sabrina,
I agree with you about truthfulness on the documents.
I disagree about the max gross weight. Yes, the pilot is responsible
for knowing the airplane's take off weight. But no, he is not
responsible for seeing that it falls within the maximum specified on
ancient papers.
Most of my pilot experience was gained as a renter rather than
airplane owner. That means I have flown many different models under
many different conditions. One of those conditions is a regular
habit of flying some particular model planes over gross weight. One
example is the C-150. I don't believe I have ever flown one of those
under gross except when soloing. My most recent flight in one (last
year) was getting my BFR with another chunky old man in the
passenger's seat. I'm sure we were at least 100 pounds over
gross. That sort of flight is very common practice in the real
world. In a case like this the only other choices would be to not
fly or find a different aircraft type. Perhaps that would have been
a good choice, but I don't think we broke any laws or regulations.
In real world practice, it is important to understand how the plane
will perform under the actual flight conditions. A C-150 will do
just fine when flown over gross so long as the CG is good and the air
conditions are favorable - reasonable density altitude. The fact
that the original certification called for a lower take off weight
has little bearing on this situation.
Paul
XL getting close
At 02:40 PM 1/22/2009, you wrote:
| Quote: | Paul,
14 CFR 91.103(b)(2) Each pilot in command shall, before beginning a
flight, become familiar with all available information concerning
that flight. This information MUST include--...reliable information
appropriate to the aircraft, relating to aircraft performance under
expected values of airport elevation and runway slope, aircraft
gross weight, and wind and temperature
Unless you test your aircraft in Phase 1 at "over max" , how can you
possess "reliable information appropriate to the aircraft" re the
"gross weight."
So too, as to W&B you sign an 18 USC perjury advsory acknoweldgement
during certification that the information you gave was
truthful. Not to mention the notarized program letter.
graeme(at)coletoolcentre. Guest
Posted: Thu Jan 22, 2009 4:34 pm Post subject: Dutch XL crash findings |
Hi Paul
The regulations are quite clear in Australia It is the pilots responsability
to ensure the Aircraft does not
exceed max take off weight.
I agree the empty weight in the book is asumed correct so it is only the
load you added which would be calculated.
If you overload the Aircraft and it flies ok the concerns would be to fly
below the speeds indicated in the manual
other wise the wings may fall off also the Aircraft would not peform as per
book,
finally hope no CASA official catches you flying illegaly.
I see you have an XL I hope with all the talk on wing failure you will be
diligent and fly within the specifications.
not like some of crazy aerobatic stuff on youtube
Graemecns
Posted: Thu Jan 22, 2009 5:48 pm Post subject: Dutch XL crash findings |
Hi Graeme,
As you can see, there is some doubt about the actual meaning of the
regulations in the USA. My understanding is that flying over the
listed maximum gross weight is not against the rules.
I agree with most of your comments. I disagree, but only slightly,
on your point about flying speed. In fact, you might be safer at
higher speeds than if you were flying at a lighter weight. This is
certainly true for maneuvering speed since the plane will stall at a
higher speed rather than breaking up.
I suppose each pilot must make a judgement for each model airplane he
flies about the gross weight question. The Cessna 150 is a case
where it just isn't possible to fly at book maximum weight with two
adults in the plane. This is a fact known to just about everyone who
flies that particular plane. It doesn't climb as well as it would
with lighter weight, but it works fine in all other respects.
I'm not sure how to approach this question with an experimental
plane. I suppose the best answer is to test fly it at various
weights and CGs during the initial test period to learn how it
behaves. Then limit your loading to the tested conditions later on.
The opinion I got from my favorite instructor on this subject is we
must consider the conditions and the particular plane when loading
and flying. If the air temperature is very cold then you can clear
obstacles much easier than if the air is very hot.
I agree with you that gentle flying is called for when flying at
heavy weights. Of course, I try to do that no matter what the plane weight is.
Indeed, I do not intend to fly my XL in an overly aggressive
fashion. I am not an aerobatic pilot, and the only aerobatic
maneuvers I would consider doing in any plane are the low G ones such
as stalls and spins. One slight exception to this is the wing-over
maneuver which I have trained and performed in the C-152. It is a
"Box Canyon" turn maneuver where you use vertical space to make the
turn rather than horizontal space. You might pull as much as 3 g's
in the pull out if you perform it correctly. If performed
incorrectly you will pull the wings off any plane.
Paul
XL getting close
At 04:30 PM 1/22/2009, you wrote:
| Quote: | Hi Paul
responsability to ensure the Aircraft does not
the load you added which would be calculated.
to fly below the speeds indicated in the manual
as per book,
will be diligent and fly within the specifications.
Thruster87
Posted: Thu Jan 22, 2009 8:28 pm Post subject: Re: Dutch XL crash findings |
Hi Sabrina, NO medicals required.If you can hold a drivers license then you can hold a RAA license,but you cannot fly into controlled airspace or above 5000ft QNH unless it is for reasons of safety [only if you have a PPL and transponder fitted]
chris Sinfield
Joined: 28 Nov 2006 Posts: 270 Location: Sydney Australia
Posted: Thu Jan 22, 2009 8:39 pm Post subject: Re: Dutch XL crash findings |
Al
sorry to burst your 700kg bubble but the RAA is still limited as of yesterday to 544KG and the Xl in VH reg is limited to 600kg.
The Zodiac XL is not available in Australia as an LSA . Because AMD and Zenith do not maintain the Airworthiness of the individual aircraft as per the Aussie regs.
Chris..
Thruster87
Posted: Fri Jan 23, 2009 3:59 am Post subject: Re: Dutch XL crash findings |
Hi Chris you are correct.Been so busy building I got ahead of myself with respect to upcoming changes/proposals from CASA.To meet the LSA 1 of the following conditions is satisfied:
(i) the manufacturer of the aeroplane, or of the kit, was the holder of a
certificate of approval in relation to the manufacture of, or of kits for,
aeroplanes of a kind that includes the particular aeroplane;
(ii) the aeroplane, or the kit, was manufactured in accordance with an
approval given by CASA;
(iii) if the aeroplane, or the kit, was exported to Australia, a certificate that
is acceptable to CASA and that relates to the airworthiness of the
aeroplane, or the aeroplane that could be assembled from the kit, has
been issued by the appropriate authority of the country from which
the aeroplane, or the kit, was exported; So we are still waiting???
Gig Giacona
Posted: Fri Jan 23, 2009 6:23 am Post subject: Re: Dutch XL crash findings |
| psm(at)att.net wrote: | Hi Gig,
Paul
stepinwolf
Posted: Fri Jan 23, 2009 6:37 am Post subject: Re: Dutch XL crash findings |
| Gig Giacona wrote: | | psm(at)att.net wrote: | Hi Gig,
Paul
91.13 |
Probably the law of survival,,,,
Stepinwolf
701&750 Scratch
_________________ Long wing + vga's, = lo & slo |
