ricklach
Joined: 20 Jun 2006 Posts: 127 Location: Kernville, Calif.
Posted: Thu Jan 22, 2009 10:20 am Post subject: 750 Cruise vs 701 Cruise |
This question is for all you 750-Experts from a 701-Dummy. I was just reading the article in the new Kitplanes about the CH-750 (nice article). And I had two questions.
1. The picture on lower left of page 14 shows a BIG tab on the outboard end of the right Flaperon. What is it? And what does it do? Is this a trim tab? I looked at every other photo I could find of the CH-750 and I could not find a picture of the left outboard Flaperon to see if there is a BIG tab on that Flaperon too. Any help here would be appreciated.
2. After reading the posted specs for the CH-750 in the article and from Zenith, I have this question. If the CH750 is bigger, longer wing, wider cabin, wider horizontal stabilizer and elevator, heaver and still has the same 100HP as the 701, how can it have a cruse of 100MPH (at) 75% power? The 701 is smaller, lighter and has the same 100HP and it only has a cruse of 80MPH (at) 75% power. Why the difference?
I know I should ask Zenith this question and maybe they will see this post and answer it to help us all. But if not I would be interested in what the group might offer.
Rick
| | - The Matronics Zenith750-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Zenith750-List |
_________________ 701Driver
N35 26.700, W118 16.743 |
kenryan(at)alaska.net Guest
Posted: Thu Jan 22, 2009 10:49 am Post subject: 750 Cruise vs 701 Cruise |
When I was at Zenith, Sebastien told me that they improperly installed the struts on the left side at a slight angle. Since the struts on the 750 are airfoils, this improper installation necessitated the trim tab on the right wing balance things out.
Apparently, the streamlined struts contribute quite a bit to an increased cruise.
Another contributing factor to increased speed would be choice of propellers.
On Thu, Jan 22, 2009 at 9:20 AM, ricklach <rick(at)ravengear.us (rick(at)ravengear.us)> wrote:
[quote] --> Zenith750-List message posted by: "ricklach" <rick(at)ravengear.us (rick(at)ravengear.us)>
Rick
Rick
http://forums.matronics.com/viewtopic.php?p=226203#226203
br> -List" target="_blank">http://www.matronics.com/Navigator?Zenith750-List
MS -
k">http://forums.matronics.com
e -
t="_blank">http://www.matronics.com/contribution
Posted: Thu Jan 22, 2009 10:51 am Post subject: 750 Cruise vs 701 Cruise |
Rick
Rick
MS -
e -
Rhino
Posted: Thu Jan 29, 2009 12:54 pm Post subject: Re: 750 Cruise vs 701 Cruise |
Define cruise. The 701 can cruise at 100 if you want to push it to high cruise numbers. As for the differences between the two, horsepower is only one part of the equation. As was mentioned, some streamlining was done. And what kind of prop will an O-200 swing that you wouldn't see on a Rotax? What effect would that have? Is the thrust of an O-200 at 75%, swinging a different prop, different than that of a Rotax at 75%? I don't have all those answers, but it's more than a simple matter of horsepower.
And the 750 won't cruise at 100 MPH if you are set up for STOL. As the article mentioned, the higher numbers were achieved with the two blade Sensenich prop rather than the three blade Warp Drive that is currently installed. From the impression Roger gave me, the Sensenich was more of a cruise prop. With the Warp Drive installed we cruised generally between 93 and 99 MPH when I was there, so I'd expect something in between as an average.
63.68 KB |
1206 Time(s) |
_________________ Bob Simmons
CH 750
N750TN (reserved) |
russellinal(at)YAHOO.COM Guest
Posted: Thu Jan 29, 2009 4:41 pm Post subject: 750 Cruise vs 701 cruise |
The dyno test I have read say the O-200 puts out 79 HP max. When we see a 750 fly with the Rotax we can compare. My neighbor is going with the 914 in his 750 and I will use the corvair.
Rhino
Posted: Fri Jan 30, 2009 6:07 am Post subject: Re: 750 Cruise vs 701 Cruise |
I'm going with the Jabiru 3300.
Interestingly enough, I got my Zenair newsletter last night and there was an article by a guy who put strut fairings on a 701. He saw a 6 to 8 MPH increase if I recall correctly. He was surprised at the results, but it does show how such fairings can increase cruise speed.
CH 750
N750TN (reserved) |
FlyGuyTililDie
Joined: 22 Jan 2009 Posts: 26 Location: Germany/Italy
Posted: Fri Jan 30, 2009 9:41 am Post subject: Re: 750 Cruise vs 701 Cruise |
While browsing the picture galleries on Zenithair.com website, I noticed a few 701s with wheel pants. Does anybody know how much this might help with cruise speeds? Does anybody know which manufacturer they were using?
Just curious. Not sure I'd do it unless it yielded 10 extra mph because of how girlie it looks.
