leinad
Joined: 19 Sep 2006 Posts: 283 Location: Central Virginia
Posted: Tue Jan 20, 2009 4:54 pm Post subject: Leaky Prosealed Tank |
All,
I've assembled my fuel tanks with proseal and rivets. I put about 1/2 psi air in them and have a clear tygon tubing with red food dye attached to a door jamb as pressure indicator. I pump air into the tank with a bicycle pump. I raise the level of the fluid 13.8 inches to give my 1/2 psi and have a pointer to show where I stop adding air. My problem is that I've tested 2 of the 4 wing tanks and they both leaked! The first leaked down several inches in about 10 minutes and I was able to find the leak with sudsy water. The second took an hour to leak down an inch and I haven't been able to find the leak. I'm reluctant to put more pressure in the tanks. Has anyone gone through this, and what was the solution to both finding and fixing the leaks? I can't even get my hand through the filler, so applying more goo from inside seams impossible. Solutions I've considered have been to cut a large access hole in the back of the tank, patch my leaks from inside then patch the access hole. Another thought was form a U shaped bead of aluminum to wrap around the leaky joint, with plenty of proseal thus forming an fix from the outside. But I still need to find the slow leak on tank #2.
If I'm not clear about my methods I'm going to post some pictures on the web site: http://daniel.dempseyfamily.us
Dan Dempsey
| here you can see the air valve |
41.68 KB |
841 Time(s) |
| My leak detector is just a water collumn |
42.04 KB |
822 Time(s) |
_________________ Scratch building XL with Corvair Engine |
carlossa52(at)gmail.com Guest
Posted: Tue Jan 20, 2009 5:07 pm Post subject: Leaky Prosealed Tank |
Dan, most of what I learned about this type of sorcery was from RV builders (web sites and matronics archives).
I remember reading about somebody using a syringe to inject proseal (?) and fix a leak.
Good luck
Carlos
2009/1/20 leinad <leinad(at)hughes.net (leinad(at)hughes.net)>
[quote] --> Zenith-List message posted by: "leinad" <leinad(at)hughes.net (leinad(at)hughes.net)>
All,
I've assembled my fuel tanks with proseal and rivets. I put about 1/2 psi air in them and have a clear tygon tubing with red food dye attached to a door jamb as pressure indicator. I pump air into the tank with a bicycle pump. I raise the level of the fluid 13.8 inches to give my 1/2 psi and have a pointer to show where I stop adding air. My problem is that I've tested 2 of the 4 wing tanks and they both leaked! The first leaked down several inches in about 10 minutes and I was able to find the leak with sudsy water. The second took an hour to leak down an inch and I haven't been able to find the leak. I'm reluctant to put more pressure in the tanks. Has anyone gone through this, and what was the solution to both finding and fixing the leaks? I can't even get my hand through the filler, so applying more goo from inside seams impossible. Solutions I've considered have been to cut a large access hole in the back of the tank, patch my leaks from inside then !
Dan Dempsey
http://forums.matronics.com/viewtopic.php?p=225925#225925
http://forums.matronics.com//files/fuelsender_730.jpg
http://forums.matronics.com//files/leakdetect_805.jpg
tonyplane(at)bellsouth.ne Guest
Posted: Tue Jan 20, 2009 5:32 pm Post subject: Leaky Prosealed Tank |
May not have a leak in #2 . Make sure your temp is stable
If I remember correctly, PV=rT. Pressure X Volume = gas constant X absolute Temp
paulrod36(at)msn.com Guest
Posted: Tue Jan 20, 2009 5:36 pm Post subject: Leaky Prosealed Tank |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Dan, I went through much the same problem, with leaks that weren't "authorized". I cut about a 6-inch hole where the filler was, and went in by hand through that hole. Then I mounted the filler on a larger plate, pro-sealed between the tank and my "access plate", then drilled and rivetted (dip the rivets in proseal) to close the tanks. By the way, water is frowned upon in tanks. There's a risk of corrosion on the fuel sender. (don't ask how I know). I used a couple of gallons of diesel, and held the tank in different positions to check for leaks. Actually, proseal is tough enough that you might be able to slop it on externally, and stop a small leak.
Paul Rodriguez
leinad
Posted: Tue Jan 20, 2009 5:50 pm Post subject: Re: Leaky Prosealed Tank |
Paul,
Thanks for the guidance. Sounds like you did one of the ideas I've been contemplating. Now if I can find the leak in tank #2.
Tony,
Thanks, but it's not temperature. This can be proved by putting the air back in the tank. The indicator always goes down, never back up.
I have more photos up now at:
http://daniel.dempseyfamily.us/zodiac/fuel/index.html
Dan
[quote="paulrod36(at)msn.com"]<xml><xml><endif> Dan, I went through much the same problem, with leaks that weren't "authorized". I cut about a 6-inch hole where the filler was, and went in by hand through that hole. Then I mounted the filler on a larger plate, pro-sealed between the tank and my "access plate", then drilled and rivetted (dip the rivets in proseal) to close the tanks. By the way, water is frowned upon in tanks. There's a risk of corrosion on the fuel sender. (don't ask how I know). I used a couple of gallons of diesel, and held the tank in different positions to check for leaks. Actually, proseal is tough enough that you might be able to slop it on externally, and stop a small leak.
Paul Rodriguez
Trainnut01(at)aol.com Guest
Posted: Tue Jan 20, 2009 11:24 pm Post subject: Leaky Prosealed Tank |
Dan
When I built my RV I had to cut a hole in the back of one of the tanks to seal a leaky joint. I was really easy to do. (After I got the tank out.)
Carroll
XLVair
Inauguration '09: Get
notsew_evets(at)frontiern Guest
Posted: Wed Jan 21, 2009 6:38 am Post subject: Leaky Prosealed Tank |
Proseal has a gun with a long hose to get into fuel tanks. We have used it on many certified aircraft tanks. You wont like the price but it in Aircraft Spruce catalog....
SW
japhillipsga(at)aol.com Guest
Posted: Wed Jan 21, 2009 7:23 am Post subject: Leaky Prosealed Tank |
Dan, mix up some proseal and thin it with MEK. Get a thin tube , suck some in, direct it inside the tank to the offending area and blow. Do it several times if necessary. More proseal is almost always better than less. Best of luck, Bill
Roger Lee
Posted: Wed Jan 21, 2009 5:31 pm Post subject: Re: Leaky Prosealed Tank |
Slosh your tanks with Kreem Weiss. I have used it a few times and works like a charm. Fixes plastic tanks or metal. Easy to use. I had a leak in my fuel tank after 2 years. Sloshed it with Kreem Weiss and it was gone. Flight Design uses it in every plane. That's what guys use in old rusty car fuel tanks or motorcycle tanks. It's like a gray epoxy that sticks to anything.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
Posted: Wed Jan 21, 2009 5:44 pm Post subject: Leaky Prosealed Tank |
So if I empty my right tank. Fill the left tank with gas.
Put Kreem Weiss in the empty right tank. Go fly and do a few loops, the
tank will be sealed.
I got it.....
ggower_99(at)yahoo.com Guest
Posted: Wed Jan 21, 2009 7:35 pm Post subject: Leaky Prosealed Tank |
NO! to be sure is sealed, you need also to do some barrels, a couple of hammerheads and a couple of Lomcevaks
Saludos
Gary Gower
Do not archive.
--- On Wed, 1/21/09, steve <notsew_evets(at)frontiernet.net> wrote:
[quote]From: steve <notsew_evets(at)frontiernet.net>
Subject: Re: Re: Leaky Prosealed Tank
Date: Wednesday, January 21, 2009, 8:41 PM
[quote]--> Zenith-List message posted by: "steve" <notsew_evets(at)frontiernet.net> So if I empty my right tank. Fill the left tank with gas. Put Kreem Weiss in the empty right tank. Go fly and do a few loops, the tank will be sealed. I got it..... ---
Roger Lee
Posted: Wed Jan 21, 2009 8:48 pm Post subject: Re: Leaky Prosealed Tank |
Piece of cake.
I pulled my wing on a Flight Design and poured it in rotated the wing (left and right, up and down on the ends) and set it on a couple of sawhorses. Done.
I sloshed it twice to be sure.
Better than having a leak or even better, not having to bother to hunt for one.
It's used world wide for sealing all kinds of tanks.
Tucson, Az.
Cell 520-349-7056 |
Afterfxllc(at)aol.com Guest
Posted: Thu Jan 22, 2009 2:00 am Post subject: Leaky Prosealed Tank |
Do not slosh your tanks
I have seen some RV's that have sloshed tanks and the slosh WILL flake over time. I saw the pics of the tanks and don't see much pro seal on the outside. I would cover every rivet and not want to see any seams from the outside. More than likely you are leaking from a rivet and you need to cover them.
Jeff
Piece of cake.
A Good Credit Score is 7001028747/aol?redir=http://www.freecreditreport.com/pm/default.aspx?sc=668072%26hmpgID=62%26bcd=DecemailfooterNO62"> See yours in just 2 easy steps!
hills(at)sunflower.com Guest
Posted: Thu Jan 22, 2009 5:17 am Post subject: Leaky Prosealed Tank |
Ya, I built a couple of RV tanks, and the word is that if you don’t clean the tanks of all oils and other contaminates first, the slosh may come off later and clog your fuel filter and cause the engine to stop….
I don’t think Vans recommends sloshing anymore because of the problems.
Proseal will never come off, even if you want it to later (don’t ask me how I know)
Roger
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Afterfxllc(at)aol.com
Sent: Thursday, January 22, 2009 3:57 AM
Jeff
Piece of cake.
A Good Credit Score is 7001028747/aol?redir=http://www.freecreditreport.com/pm/default.aspx?sc=668072%26hmpgID=62%26bcd=DecemailfooterNO62"> See yours in just 2 easy steps! | Quote: | | http://www.matronics.com/Navigator?Zenith-List | 0123456789
Roger Lee
Posted: Thu Jan 22, 2009 5:56 am Post subject: Re: Leaky Prosealed Tank |
Kreem Weiss will not flake or come off if you do it right and it's just too easy to do it right. If you could look into a Flight Design tank near where you live, you would see why it doesn't flake. It becomes the tank. Hard as a rock. Use Kreem Weiss not some other cheaper brand.
Tucson, Az.
Cell 520-349-7056 |
Posted: Thu Jan 22, 2009 9:11 am Post subject: Leaky Prosealed Tank |
One word of caution, get the fingerscreen off the tank and plug the outlet before starting the procedure, with the fingerscreen sealed, no gas will com out.
Saludos
Gary Gower.
--- On Wed, 1/21/09, Roger Lee <ssadiver1(at)yahoo.com> wrote:
| Quote: | From: Roger Lee <ssadiver1(at)yahoo.com>
Subject: Re: Leaky Prosealed Tank
Date: Wednesday, January 21, 2009, 11:48 PM
| Quote: | --> Zenith-List message posted by: "Roger Lee"
Piece of cake.
Roger Lee
Tucson, Az.
Light Sport Repairman - Maintenance Rated
Rotax Service Center
520-574-1080
http://forums.matronics.com/viewtopic.php?p 26129#226129
leinad
Posted: Sat Jan 24, 2009 6:29 pm Post subject: Re: Leaky Prosealed Tank |
A follow up to my leaky tanks post
Two of my 4 tanks leaked. One leaked on the front seam in 2 spots. The other leaked around one of the threaded fittings. Rather than using a sloshing agent I tried the following.
The leak at the threaded fitting was right in a corner that I packed with proseal mixed with a little bit of fiber glass. This was done on the outside of the tank. There were lots of rivets shop ends poking out for the proseal to grap onto.
The other one was on the long straight seam. I bent up a U from 5052 aluminum and after removing the rivets from the leaky area I wrapped the seam with this U and drilled it to use the same rivet holes. Next I stuffed the U with proseal, hammered it on with a mallet and set the rivets. I should know late tomorrow if this worked.
Here's a picture of the patch.
Dan Dempsey
| Here's the patch just before drilling |
75.03 KB |
817 Time(s) |
leinad
Posted: Tue Feb 03, 2009 9:14 am Post subject: Re: Leaky Prosealed Tank |
Just a final word on this thread. Both the patches worked, so I'm finished with the tanks until installation time. Thanks to those who responded.
Dan
| leinad wrote: | A follow up to my leaky tanks post
Dan Dempsey |
ashontz
Posted: Wed Feb 18, 2009 7:54 am Post subject: Re: Leaky Prosealed Tank |
How about submerging the entire tank in water while it's pressurized and look for leaks, like they do with car tires at your local Tire World?
I'm just about to test one of my tanks (welded) and I think I'll do it that way myself.
William Dominguez
Posted: Wed Feb 18, 2009 8:40 am Post subject: Leaky Prosealed Tank |
That should work too but the soapy water worked very well for me and is simpler to do. I weight 150 pounds and I would have a hard time submerging 15 gallons of air in a tank of water, it might even float with me standing on top.
If you pressurize your tank using a balloons you might have to leave the balloon out of the water connected to the fitting via a hose.
William Dominguez
Zodiac 601XL Plans
Miami Florida
http://geocities.com/bill_dom
--- On Wed, 2/18/09, ashontz <ashontz(at)nbme.org> wrote:
Subject: Zenith-List: Re: Leaky Prosealed Tank
Date: Wednesday, February 18, 2009, 10:54 AM
--> Zenith-List message posted by: "ashontz" <[url=/mc/compose?to=ashontz(at)nbme.org]ashontz(at)nbme.org[/url]>
Andy Shontz
CH601XL - Corvair
www.mykitlog.com/ashontz
http://forums.matronics.cosp; --> http========================http://www.matronics.com/contributio==============
| [quote][b]
_________________ William Dominguez
Zodiac 601XL Plans
Miami Florida
http://www.geocities.com/bill_dom |
