Rotax Weight (from Dutch XL thread)
rsteele(at)rjsit.com
PostPosted: Wed Jan 21, 2009 10:38 am    Post subject: Rotax Weight (from Dutch XL thread) Reply with quote
This is very interesting. Where do these numbers come from (the
additional 25lbs)? I know I'm not alone it trying to find COMPARABLE
weights of engine installations . You'd think it was classified
information. What exactly is included in this extra weight?
Ron
BTW, your 68 kg (about 140 pounds) for the Rotax ignores some required
extra
equipment that brings the real powerplant weight up to closer to 165 or
so.
Yes, there's a difference, but it's not as much as Rotax advocates
claim.
MHerder
PostPosted: Wed Jan 21, 2009 12:18 pm    Post subject: Re: Rotax Weight (from Dutch XL thread) Reply with quote
It really is interesting how difficult it is to find different weights for similar installations.
Every manufacturer seems to quote their weights different, dry, wet, with accessories, without, with exhaust ,without etc. With coolant ,without. I also would love to know some real "useful" information regarding weights without playing the games that various manufacturers like to play.
Jab 3300 ready to fly real weight, wet, with exhaust,=x #
Cont 200 " "
Jab 2200 " "
Lyc 235 " "
Rotax 912 " "
Not that it's difficult to add up yourself... Its just a pain. Walking around and trying to talk to manufacaturers at Oshkosh and find out realistic weights feels like haggling a car deal to me. "Oh you want wheels with that?"
Zodiac 601 HD
Jabiru 3300
Wood Sensinich 64x47
Finally Flying
ronpollock(at)gmail.com
PostPosted: Wed Jan 21, 2009 12:37 pm    Post subject: Rotax Weight (from Dutch XL thread) Reply with quote
If the airframe doesn't vary that much would it be reasonable to
subtract that from an aircraft's total weight? Then everything left is
the firewall forward weights that we'd like to compare to. Minus gas
of course. And the prop weight should be known.
Ron in L.A.
On Wed, Jan 21, 2009 at 12:18 PM, MHerder <michaelherder(at)beckgroup.com> wrote:
Cont 200 " "
Jab 2200 " "
Lyc 235 " "
Rotax 912 " "
One Rivet at a Time!
http://forums.matronics.com/viewtopic.php?p 26031#226031
david_a_g_johnson(at)btin
PostPosted: Wed Jan 21, 2009 12:40 pm    Post subject: Rotax Weight (from Dutch XL thread) Reply with quote
If it's any use, I have just weighed my 601XL, It's not yet painted, but
apart from that, it's complete.
Jab 3300, wheel spats, Landing light, Strobes, Dual brakes/sticks.
Instrument fit is Dynon100 and 120 etc.
It came out at dead on 700Lbs.
Dave Johnson
(still grounded!!)
jaybannist(at)cs.com
PostPosted: Wed Jan 21, 2009 1:10 pm    Post subject: Rotax Weight (from Dutch XL thread) Reply with quote
Ron.
The first word of your post is diagnostic (that big "IF"). The weight of completed Zodiac 601XL airframes do vary - a LOT ! I know specifically of several XLs, with WW Corvair engines and none weigh the same, varying around 100 lbs, lightest to heaviest. In this case, the Corvair engine is the constant, not the airframe.
Jay in Dallas
Terry Phillips
One thing to do is to go to the 601XL spec page
http://www.zenithair.com/zodiac/xl/specification.html
There you find (hopefully) comparable data for the empty weights of Zodiacs
with the Jabiru 3300A, the Rotax 912, and the Lycoming O-235, of 695, 690,
and 800 lbs respectively.
Before I bought my kit, I asked either ZAC or JabiruUSA why these weights
did not reflect the engine manufacturer's data for the engine weights. I
was told that the engine manufacturer's numbers did not necessarily include
all the peripheral items that are necessary for the complete installation.
Terry
Ron
extra
so.
claim.
Terry Phillips ZBAGer
ttp44~at~rkymtn.net
Corvallis MT
601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail, flaps, & ailerons
are done; working on the wings
http://www.mykitlog.com/N47TP/
Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
Zenith 601XL/Jab 3300 slow build kit - Tail feathers done; working on the wings.
jmaynard
PostPosted: Wed Jan 21, 2009 1:35 pm    Post subject: Rotax Weight (from Dutch XL thread) Reply with quote
Radiator, coolamt, and associated plumbing.
Jay Maynard, K5ZC, PP-ASEL, AGI http://www.conmicro.com
http://jmaynard.livejournal.com http://www.tronguy.net
Fairmont, MN (KFRM) (Yes, that's me!)
AMD Zodiac CH601XLi N55ZC http://www.tronguy.net/N55ZC.shtml
Jay Maynard, K5ZC
AMD Zodiac XLi N55ZC
rans6andrew
PostPosted: Wed Jan 21, 2009 1:50 pm    Post subject: Re: Rotax Weight (from Dutch XL thread) Reply with quote
the table of aircraft weights on the page
has some er... errors in it. The empty weights of the Jab and 912ULS are only 5Lbs different and yet they are given as 6Kg different. 6Kg is 13Lbs!
They just don't add up.
Andrew.
A good way through building a 601UL with 912UL.
Still flying Rans S6 with 503.
ggower_99(at)yahoo.com
PostPosted: Wed Jan 21, 2009 7:42 pm    Post subject: Rotax Weight (from Dutch XL thread) Reply with quote
There are two simple questions that men will never get a straight answer ever:
Homebuilt engines real weight an power and women age... Smile Smile Smile
Saludos
Gary Gower
Do not archive.
--- On Wed, 1/21/09, MHerder <michaelherder(at)beckgroup.com> wrote:
Subject: Re: Rotax Weight (from Dutch XL thread)
Date: Wednesday, January 21, 2009, 3:18 PM
--> Zenith601-List message posted by: "MHerder"
Cont 200 " "
Jab 2200 " "
Lyc 235 " "
Rotax 912 " "
that?"
K Dilks
PostPosted: Wed Jan 21, 2009 10:50 pm    Post subject: Re: Rotax Weight (from Dutch XL thread) Reply with quote
Hi all,
I have to chip in with a little reality check on this topic.
I worked for three years in France for the Rotax dealer there.
The system is that the lanes for ULM ( microlight) must have a empty weight of 450 kg or 475 with a BRS fitted.
Now here is the punch line . The planes are NOT weighed , you just sign a declaration that states you comply. No inspection of the craft is made ONLY this declaration and you get registration.
Hence Zodiacs , Sting Carbons, and virtually all designes in this catagory are more than this limit.
We had a Sting Carbon retratable gear in the shop with every thing on it , Full IFR kit , pitot heat , second generator the list was endless. When i could not push it in our hanger on my own I asked the owner how much it weighed and he just laughed. So when he went out we weighed it at 410KG wet ! He then said the empty figure was about 375 and could he have some fuel to fill it up ...................Rotax engine too.
My point is that in the UK the really weight the planes but Im not so sure the REAL weight is on the documents in many European countries.
All the planes that live in Belgium have French registrations ( ULM) .....as the process is so easy.
This was also the case with the Belgium Zodiac dealer we did work for , he said that its better to be a bit heavy and safe ...... as he new all the Zodiacs were a bit porky.
Why the UK XL is limited to 560 kg ?? is this because they are from CZAW as my plans state 590 and that is what I shall enter on the paperwork.
Cheers!
Kev
Back home .................
PostPosted: Thu Jan 22, 2009 2:28 am    Post subject: Rotax Weight (from Dutch XL thread) Reply with quote
The breakdown was:-
Right 209
Left 221
Nose 270
I should have mentioned that, as this is a CZAW kit, I have the composite
legs (or at least the 'plane has!) which save quite a bit of weight, I would
guess about 25Lbs.
Dave Johnson
alex_001
PostPosted: Thu Jan 22, 2009 3:15 pm    Post subject: Re: Rotax Weight (from Dutch XL thread) Reply with quote
WR 109.0
WL 109.0
WN 105.0
Leergewicht in kg 323.0
all in kg rotax912uls brs radio transponder gps full analog instruments airbox, heater, y stick, ap navaid, strobes, landinglight, BRS, position lights, wheelfairings
2007 czaw 601xl
i checked the weight last week
 Filesize:  135.17 KB
 Viewed:  824 Time(s)
rans6andrew
PostPosted: Fri Jan 23, 2009 1:32 am    Post subject: Re: Rotax Weight (from Dutch XL thread) Reply with quote
alex,
did you set the aircraft level (spirit level on cockpit side rails etc) and close the canopy before reading the scales?
Overall weight will be spot on but calculated CofG will be off if you didn't.
Andrew.
alex_001
PostPosted: Sat Jan 24, 2009 8:24 am    Post subject: Re: Rotax Weight (from Dutch XL thread) Reply with quote
all done and similar fig as when new and collected with w&b sheet
