Spinners
Goto page 1, 2  Next
leinad
PostPosted: Sun Jan 18, 2009 3:29 pm    Post subject: Spinners Reply with quote
I purchased a 12" UHS spinner from ACS for my 601xl/corvair. Has anyone else used these. I was surprised to see that it comes with only a single bulk head for the front of the prop. How much of a concern is this? What are others using?
Dan Dempsey
jaybannist(at)cs.com
PostPosted: Sun Jan 18, 2009 3:44 pm    Post subject: Spinners Reply with quote
Dan,
I used the spinner from Van's that WW recommends. It has a bulkhead behind the prop and one in front of the prop. It was fairly easy to install and runs true. I can't imagine how a spinner would work with only one bulkhead.
Jay in Dallas
jmaynard
On Sun, Jan 18, 2009 at 03:29:37PM -0800, leinad wrote:
I purchased a 12" UHS spinner for 601xl/corvair from ACS. Has anyone else
others using?
I don't know where they get them, but the AMD spinner uses a single bulkhead
at the front of the prop as well.
Jay Maynard, K5ZC, PP-ASEL, AGI http://www.conmicro.com
http://jmaynard.livejournal.com http://www.tronguy.net
Fairmont, MN (KFRM) (Yes, that's me!)
AMD Zodiac CH601XLi N55ZC http://www.tronguy.net/N55ZC.shtml
Jay Maynard, K5ZC
AMD Zodiac XLi N55ZC
Gig Giacona
PostPosted: Sun Jan 18, 2009 3:56 pm    Post subject: Re: Spinners Reply with quote
Dan Dempsey
A single bulk head in itself isn't a problem. What may be a problem is if you are going to use the WW nose bowl you are going to have a 1/2" area around the spinner that doesn't match up with the nosebowl. It will produce a slight but probably measurable amount of extra drag.
W.R. "Gig" Giacona
601XL Under Construction
leinad
PostPosted: Sun Jan 18, 2009 5:30 pm    Post subject: Re: Spinners Reply with quote
My plan is build to build my own cowl, so that's not a problem.
Dan
Gig Giacona wrote:
Dan Dempsey
GLJSOJ1
PostPosted: Sun Jan 18, 2009 6:21 pm    Post subject: Re: Spinners Reply with quote
That's the same spinner that I have. Haven't flown yet, but it mounts up just fine. I measured and told ACS the dimensions I needed and it came out perfect for me.
601XL N676L FLYING PHASE I
CHESAPEAKE VA
leinad
PostPosted: Tue Jan 20, 2009 4:25 pm    Post subject: Re: Spinners Reply with quote
Jay,
My spinner weighs about 2 lb 6 oz. This "seams" heavy to me. Did you by chance weigh yours before installing it?
Dan
jaybannist(at)cs.com wrote:
Dan,
Jay in Dallas
PostPosted: Tue Jan 20, 2009 5:40 pm    Post subject: Spinners Reply with quote
Dan,
No, I didn't weigh it. Van's installation sheet doesn't give weights, either. I'd guess that the fiberglass cone is from around 1/16" to 3/32" thick. Van's drawing calls for a .063" (1/16") thick filler behind the prop blades. I actually used part of the cut-out for the prop for the fillers. The base of the cone is 13" in diameter and it is 13 1/2" from base to tip. The bulkheads are .063" 2024-T0 aluminum. We ('Vairheads) had to get together and come up with a hole pattern to fit the WW hub bolt pattern. When installing it, I used a laser spot aimed at the tip of the cone to insure the tip wouldn't move. I had the spark plugs out and rotated the prop to make sure of the alignment.
Jay in Dallas
leinad
PostPosted: Tue Jan 20, 2009 6:20 pm    Post subject: Re: Spinners Reply with quote
Jay,
Thanks for the info. At this point knowing the weight might convince me to call the UHS a mistake and order the Van's spinner. I'm really not very happy with the finish. There are many imperfections in the surface.
With 2 bulk heads I assume thickness of the prop is tightly controlled. My prop is 3 3/4" thick.
I'm a little concerned about what you say about the bolt pattern. Isn't W. Wynne using SAE1? (6 bolts on 4.375) That's what was on the plans I purchased from him about 5 years ago. Think I'll go visit the Van's site now.
Dan Dempsey
Dan,
Jay in Dallas
PostPosted: Tue Jan 20, 2009 7:05 pm    Post subject: Spinners Reply with quote
Dan,
My spinner from Van's had a super finish, right out of the box. It required no finish work, other than making the cut outs for the prop and painting. I don't know the SAE numbers, but WW's bolt pattern doesn't match Van's. I have a drawing of the bolt pattern we came up with. Let me now if you want me to send it to you.
Jay Bannister
hills(at)sunflower.com
PostPosted: Tue Jan 20, 2009 7:56 pm    Post subject: Spinners Reply with quote
Great Plains VW has a selection of “you build it” spinners…
Roger
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of jaybannist(at)cs.com
Sent: Tuesday, January 20, 2009 9:04 PM
Subject: Re: Re: Spinners
Dan,
Jay Bannister
-----Original Message-----
Sent: Tue, 20 Jan 2009 8:20 pm
Subject: Re: Spinners
--> Zenith-List message posted by: "leinad" <leinad(at)hughes.net (leinad(at)hughes.net)>
Jay,
is 3 3/4" thick.
Dan Dempsey
> Dan,
> Jay in Dallas
http://forums.matronics.com/viewtopic.php?p=225933#225933
size=2 width="100%" align=center>
Email message sent from CompuServe - visit us today at http://www.cs.com
leinad
PostPosted: Wed Jan 21, 2009 4:56 pm    Post subject: Re: Spinners Reply with quote
Jay,
Thanks for another reply and offer. No, I won't need the drawing. I made my own prop hub. It is SAE1, and the UHS SAE1 bulk head fits it. At this point I'm seriously leaning toward ordering the Van's spinner, but I can't find definite information on how thick of prop it will take. The Van's web site just says "thick wooden prop". I've seen one customer's sight that calls it 3.5" which is too thin, and another that calls it 4" which would work great. My prop is 3 and 3/4 inches thick and I have a 1/4" thick crush plate. If someone could report on the weight of the Van's 13" spinner that's help me decide too.
If I were to do "finish" work on this spinner it would involve using some filler to fill in the little scoops and waves that are in it. Then it'd be out of balance. So if I use it I'd have to just tell myself it's good enough as is.
Thanks anyway.
Dan
Dan,
Jay Bannister
PostPosted: Wed Jan 21, 2009 5:26 pm    Post subject: Spinners Reply with quote
Dan,
Van's instructions show installation for a wood prop, a metal prop and a constant speed prop. My prop is a Warp Drive and it worked just fine. They show different front bulkheads for wood, metal and c/s, all of which bolt to the prop assembly. As I recall, with mine, the front bulkhead was in front of the prop hub and not attached to it.
Jay B.
zenithlist(at)yahoo.com
PostPosted: Thu Jan 22, 2009 10:24 pm    Post subject: Spinners Reply with quote
Jay,
I also have Van's spinner FP-13 but the rear bulkhead bolt holes do not fit WW hub and the front bulkhead would not fit Warp Drive prop at all. I emailed WW numerous times inquiring about the front crashplate/bulkhead but he would not reply. Can you post the bolt hole patterns and how you got the front bulkhead to work?
From: "jaybannist(at)cs.com" <jaybannist(at)cs.com>
Sent: Sunday, January 18, 2009 5:43:40 PM
Dan,
Jay in Dallas
PostPosted: Fri Jan 23, 2009 6:05 am    Post subject: Spinners Reply with quote
John,
Here is the drawing and a photo of the rear bulkhead bolt pattern. You will notice that two of the holes are "enlarged" existing holes. This is OK since the alignment of the bulkhead is assured by the close fit of the bulkhead center hole to the WW hub and a good fit with the other holes.
Van's apparently has several different forward bulkheads for this spinner. The one I got sits far enough forward to clear the Warp Drive prop hub. I didn't have to do any modifications to make it fit that way. I guess the secret is in getting the correct bulkhead.
Let me know if you have questions.
Jay Bannister
 Filesize:  238.19 KB
 Viewed:  717 Time(s)
ModVansSpinnerPl.pdf
 Filename:  ModVansSpinnerPl.pdf
 Filesize:  22.71 KB
 Downloaded:  519 Time(s)
leinad
PostPosted: Fri Jan 23, 2009 8:45 am    Post subject: Re: Spinners Reply with quote
Jay,
Are you saying you don't have the propeller bolts passing through the front bulk head? Is there anything holding the front bulk head on to the prop? I don't see any use at all in such an arrangement. Normally one would use spacers, and long enough bolts to attach both bulkheads to the prop/hub assembly.
As to the drawing, it looks like you've confirmed that William is using SAE-1. It appears Vans has drilled the bulkheads for SAE-2 which I believe is 6 bolts on a 4.5" circle. (don't quote me)
Thanks for the post. Denise may skin me alive but I may be purchasing the Van's spinner. I still need to find out if there is enough space (I need at least 3 3/4" between bulkheads, and would like to know the weight of the assembly. One of the list members said he may get those dimensions for me this weekend. If he does I'll post them here so the group can benefit.
Dan
John,
Jay Bannister
PostPosted: Fri Jan 23, 2009 9:30 am    Post subject: Spinners Reply with quote
Jay,
Those are very helpful pictures of rear bulkhead. I will do as pictured. My front bulkhead is also small enough to clear (~1" in front of) the Warp Drive prop hub, and I have no idea how to mount it. Does your front bulkhead mount directly in front of the Warp Drive prop hub?
Sent: Friday, January 23, 2009 8:03:46 AM
John,
Jay Bannister
Afterfxllc(at)aol.com
PostPosted: Fri Jan 23, 2009 9:11 pm    Post subject: Spinners Reply with quote
The spinner that Van's sells will work just fine if you do some modifications to it. The Hole pattern is SAE 2 and you can either enlarge the holes in the lower bulkhead or you can drill new one's using the prop hub as a drill guide. If you use the prop hub it will be self aligning with the center hole in the bulk head and then you can simply drill new holes. This bulkhead is in compression so either way (enlarging the first set of holes or drilling new one's) will work just fine.
As for the top bulkhead you can either continue to try and get the one WW makes if you ever get an answer from him....... OR you can go to Lowe's and buy 6 1 inch spacers and 6 flat washers and drill the front bulkhead and crush plate for 1/4 20 screws and that will give you the perfect height for a Warp drive prop.
If you are using a wood prop you will need 6 3/4 spacers and 1 washer. I will post a pic of one I did and you can see it isn't that hard to do. I like the Van's front bulkhead much better than WW's because it makes the spinner rigid and WW's can be moved from side to side but if you can't get one what's the point.
Here are some pics of it and if you need anything else I will be glad to answer my email's and help you thru the process.
Jeff Garrett
Louisville Ky.
601XL N962T Aerolite Corvair 90%
601XL N524B Aerolite Corvair 155 Hrs
601XL N2257 Aerolite Corvair 87 Hrs
www.aeroliteproducts.com
www.project601xl.com
www.aerolite.camstreams.com
A Good Credit Score is 7001028747/aol?redir=http://www.freecreditreport.com/pm/default.aspx?sc=668072%26hmpgID=62%26bcd=DecemailfooterNO62"> See yours in just 2 easy steps!
 Filesize:  43.08 KB
 Viewed:  692 Time(s)
 Filesize:  23.2 KB
 Viewed:  704 Time(s)
 Filesize:  18.33 KB
 Viewed:  657 Time(s)
leinad
PostPosted: Sat Jan 24, 2009 6:11 pm    Post subject: Re: Spinners Reply with quote
Jeff,
I'm not sure who you meant this post for but it doesn't answer the question I've posted repeatedly, which is what is the distance between bulkheads? Obviously you know, or you wouldn't be able to recommend 3/4" spacers for some combination of prop and crush plate that you know about.
I thought there'd be enough corvair builders on this list using this spinner that someone might know the dimension, but I'll try asking on the RV board.
Thanks for your post anyway.
By the way I've posted a picture of the UHS spinner on my website at:
http://daniel.dempseyfamily.us/zodiac/propeller/index.html
Dan
b]
leinad
PostPosted: Sat Jan 24, 2009 6:56 pm    Post subject: Re: Spinners Reply with quote
Hurray! Gig (William Giacona) came through for me. The distance is "approximately" 4 1/4". So my 3-3/4 prop with 1/4" crush plate should fit with 1/4" (spacers) to spare. Thank you Gig!
Dan
Goto page 1, 2  Next
Page 1 of 2
