Posted: Fri Jan 16, 2009 7:06 am Post subject: What can I use to cover battery terminals? |
At 01:47 AM 1/16/2009, you wrote:
| Quote: | I have an Odyssey PC545 battery. That battery uses 6MM screws to mount the positive and negative terminal to its brass lugs.
There is only ~ .030" clearance between the bottom of the terminal and the battery case.
I will be putting adhesive lined heat shrink on the terminal lapping onto the #4CC wire, but it will still leave plenty of metal exposed to create a momentary 1200 amp short, or at least 545 amps for 5 seconds.
Those silicone terminal covers don't have a chance to fit into a .030" gap.
I could mutilate the silicone terminal covers, but it will not be a great fit but it will kinda work.
I could put electrical tape covering the terminals, that will kinda work but a hack job.
Anyone have any ideas for a more eloquent solution?
See pictures #25 and #26:
http://www.europaowners.org/modules.php?set_albumName=album266&op=modload&name=gallery&file=index&include=view_album.php
Thx.
Ron Parigoris] |
Why a battery box at all? The RG batteries are quite
happy strapped down in a simple tray. Capture the footprint
in tray with say 1/2" tall sides and strap down with a
couple of 200# plus webbing straps, either one of which
would hold the battery in place with 10G acceleration.
Alternatively, dishing the top of the box is the
"legacy" approach. Our rules of thumb for clearances
in the TC aircraft call for .25" min clearance for
equipment items mounted RIGIDLY in the airframe
and .50" is better.
( -Thomas Paine 1776- )
rparigor(at)SUFFOLK.LIB.N Guest
Posted: Fri Jan 16, 2009 7:50 am Post subject: What can I use to cover battery terminals? |
Hi Bob
"Why a battery box at all?"
I agree, my "box" is missing the top half, and will be missing about 1/2
of the bottom.
Guess should have called it a battery tray.
You can see from picture that the terminals are completly exposed. I know
when working in the cramped quarters of the aft fuse, a wrench or
something metalic is going to short the battery, and besides branding me
with a red hot tool, the battery is going to shower me with AGM soaked
goo:
http://www.europaowners.org/modules.php?set_albumName=album266&id=Bat11&op=modload&name=gallery&file=index&include=view_photo.php
Ron P.
johnciolino(at)comcast.ne Guest
Posted: Fri Jan 16, 2009 10:48 am Post subject: What can I use to cover battery terminals? |
Ron,
Just a thought--why not construct a L shaped piece of lexan or other
plastic. Screw one leg of the L to the top face of the battery hold down bar
and use the other leg to create a shield covering the terminal. It would
not encapsulate the terminal but should keep an errant wench from making
contact. It would be an easy fiberglass lay-up; but I don't know if
fiberglass is a conductor or not. Others can chime in on that.
John Ciolino
Sent: Friday, January 16, 2009 10:35 AM
To: <aeroelectric-list(at)matronics.com>
Subject: Re: What can I use to cover battery terminals?
