fuselage stand
cjhukill(at)cox.net
PostPosted: Tue Jan 13, 2009 8:34 am    Post subject: fuselage stand Reply with quote
Here are a couple of fotos of the stand I built. I use my aerolift to turn the stand on it's side, which allows me to work on the fuselage without leaning over. This is a real back saver! 2 people can easily rotate the stand without a lifting device. It cost about 30 bucks in thin wall 1X2 steel and a set of cheap casters.
Chris Hukill
cabin top hell
 Filesize:  127.92 KB
 Viewed:  286 Time(s)
 Filesize:  171.3 KB
 Viewed:  274 Time(s)
dlm46007(at)cox.net
PostPosted: Tue Jan 13, 2009 11:43 am    Post subject: fuselage stand Reply with quote
I don't know whether it has been mentioned but a wooden dolly on wheels from home deport aviation department under each wing attach point and one under the baggage area works fine . Total about $40.
