johnd(at)data-tech.com Guest
Posted: Mon Jan 12, 2009 10:34 am Post subject: N601JD First Flight |
N601JD my 601XL with a Jabiru 3300 took to the air for the first time
last Friday at Avery County Airport (7A8) in Spruce Pine, NC. Its a
quickbuild kit that I started in April 07.
The obligatory Youtube video is at
http://www.youtube.com/watch?v=vIVt40B5dLc. Its short and a bit shaky so
be careful if you get motion sickness
The flight went well with only a couple of minor squawks:
1. Need to add a stop to the throttle (at) low RPMS to prevent the engine
from stopping when the throttle is pulled too far back to idle. The US
Jabiru guys recommend a small cable stop added to the throttle cable at
the carb to prevent this.
2. Aileron trim is wired backwards, Oops, didn't notice a real need for
the aileron trim though
3. Experiment with my Sensenich Ground adjustable prop and also
re-jetting the Bing carb to maximize performance. CHTs and EGTs looked
good though, perhaps I wont have to spend too much time messing with
cooling issues.
Woo hoo, now only 38 more hours till the end of Phase 1...
If only I had remembered to turn on my in cockpit video recorder, I'll
do that next time...once the darned weather clears up again.
Thanks to all the list members who helped with questions during the
build process.
John Davis
Burnsville, NC
N601JD - 601XL/Jab 3300
Now Flying!!!!
jaybannist(at)cs.com Guest
Posted: Mon Jan 12, 2009 10:46 am Post subject: N601JD First Flight |
John,
A big Congratulations ! ! Beautiful airplane !
It must have been a calm day since you landed opposite to the way you took off, right?
Jay in Dallas
Posted: Mon Jan 12, 2009 10:52 am Post subject: N601JD First Flight |
Hi Jay,
Thanks, we have a bit of a slope on the runway and unless the winds are bad will takeoff downhill and land uphill.
John
jaybannist(at)cs.com (jaybannist(at)cs.com) wrote: [quote] John,
Jay in Dallas
Terry Phillips
Joined: 11 Jan 2006 Posts: 346 Location: Corvallis, MT
Posted: Mon Jan 12, 2009 11:28 am Post subject: N601JD First Flight |
Congratulations, John!
Enjoy your new airplane.
Terry
At 01:29 PM 1/12/2009 -0500, you wrote:
| Quote: | N601JD my 601XL with a Jabiru 3300 took to the air for the first time last
Friday at Avery County Airport (7A8) in Spruce Pine, NC. Its a quickbuild
Terry Phillips ZBAGer
ttp44~at~rkymtn.net
Corvallis MT
601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail, flaps, & ailerons
are done; working on the wings
http://www.mykitlog.com/N47TP/
_________________ Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
Zenith 601XL/Jab 3300 slow build kit - Tail feathers done; working on the wings. |
z601(at)anemicaardvark.co Guest
Posted: Mon Jan 12, 2009 11:54 am Post subject: N601JD First Flight |
On Monday 12 January 2009 12:29, John Davis wrote:
Congratulations!
Those who can, do. Those who can't, sue.
Jim B. Belcher
BS, MS Physics, math, Computer Science
A&P/IA
Instrument Rated Pilot
General Radio Telephone Certificate
leinad
Joined: 19 Sep 2006 Posts: 283 Location: Central Virginia
Posted: Mon Jan 12, 2009 5:00 pm Post subject: Re: N601JD First Flight |
Congratualtions John, and good luck with the flight testing.
Dan Dempsey
_________________ Scratch building XL with Corvair Engine |
sdthatcher
Joined: 13 Mar 2008 Posts: 91 Location: Port Saint Lucie
Posted: Tue Jan 13, 2009 3:27 am Post subject: Re: N601JD First Flight |
I really enjoyed the enthusiasm of your family when you landed. It was a great video and that airport at Spruce Pine looks great. I have my plane over in Andrews, NC. Hope to see you some time.
And Jay sure is good at noticing the not so obvious (runway departure and approach). He'd be a great detective. I missed that runway thing completely!
| johnd(at)data-tech.com wrote: | N601JD my 601XL with a Jabiru 3300 took to the air for the first time
cooling issues.
build process.
John Davis
Burnsville, NC
Now Flying!!!! |
_________________ Scott Thatcher, Port Saint Lucie, FL
601XL with Corvair, Registered as E-LSA
N601EL, EAA203 140 hours and not flying currently. |
