Cutting off back of cockpit module
gregoryf.flyboy(at)comcas
PostPosted: Sat Jan 10, 2009 9:50 pm    Post subject: Cutting off back of cockpit module Reply with quote
To list,
When I was marking the cockpit module for cutting a long time ago, it seemed
like the scribe lines at the sides of the module (near the back end) went up
in an angled, circular fashion as seen in the picture. I assume that most
people cut the scribe line parallel to the (already cut)opening. Did anyone
see it like I did, and cut the way I have it marked? An advantage of cutting
it that way would be that it would give more surface area for the glue to
hold the CP module to the fuselage, in that area.
Greg
The extra picture: be careful who comes in to the hangar (and lurks in wait)
to watch you build! It is hard to tell from the picture, but 'it' was a
pretty good size, or at least a runner up. Last years winner had black and
white colored hairs all around its legs and body. I had difficulty getting
pictures of him. He seemed to know that I was on to him. Both have met their
makers Smile
 Filesize:  53.47 KB
 Viewed:  402 Time(s)
 Filesize:  36.24 KB
 Viewed:  388 Time(s)
Ivor Phillips
PostPosted: Sun Jan 11, 2009 3:32 am    Post subject: Cutting off back of cockpit module Reply with quote
Hi Greg
I didn’t bother cutting it down at all, A good clean up and a dose of redux gives a substantial increase in body strength right beside the main Tri-Gear legs,
But then that is probably why my Europa is heavy!Smile
regards
Ivor
---- Greg Fuchs <gregoryf.flyboy(at)comcast.net> wrote:
To list,
Greg
makers Smile
rlborger(at)mac.com
PostPosted: Sun Jan 11, 2009 3:14 pm    Post subject: Cutting off back of cockpit module Reply with quote
Greg,
I went back to my build site to refresh my memory on how I trimmed
that part of the CM.
Year #2, Q4 2003, pics 6 & 7 show the CM ready to bond in place. You
can get a good idea how I trimmed my CM there.
You certainly can trim it as you indicate and provide additional
bonding area and strength, but understand that it will be at a weight
penalty.
Yes, there are lots of critters ready to take over your space and many
are willing and able to fight you for it. I need to work out some
better way to seal the big door on my shop from the critters. Also
seal in some heat!
Check six,
Bob Borger
Europa Kit #A221 N914XL, XS Mono, Intercooled 914, Airmaster C/S
http://www.europaowners.org/N914XL
(99.999% done) Essentially complete. Running Tests & Final Inspections.
3705 Lynchburg Dr.
Corinth, TX 76208
Home: 940-497-2123
Cel: 817-992-1117
On Jan 10, 2009, at 23:47, Greg Fuchs wrote:
To list,
it seemed
went up
most
anyone
cutting
glue to
Greg
in wait)
was a
black and
getting
met their
makers Smile
<DSC00826.JPG><DSC00801.JPG>
PostPosted: Sun Jan 11, 2009 10:12 pm    Post subject: Cutting off back of cockpit module Reply with quote
Thanks Ivor,
It is good to know that it won't get in the way of anything (or be too
thick). It leaves all of the options on the table.
I too, like the idea of strengthening that area a bit.
How heavy did your Europa come in at?
What would you attribute most of the extra weight to?
~Greg
Hi Greg
I didn't bother cutting it down at all, A good clean up and a dose of redux
legs,
regards
Ivor
PostPosted: Sun Jan 11, 2009 10:16 pm    Post subject: Cutting off back of cockpit module Reply with quote
Thanks for the picture reference. It looks like you followed the text
religiously. I can swear that my (almost imperceptible) scribe line follows
the dotted line in my picture. Well, based on everyone's responses, it
appears that the sky is the limit on the cutting. Though any will work, I
think I will choose a hybrid. Not quite like the manual, and not quite no
cutting at all. A little increase in strength in this area couldn't hurt too
much, especially to support the future bed......and sink.
Whoa! I saw (on your website)your picture of the black Widow hangar watch
spider! I would think that he wouldn't be the only one doing the
watching...that you would be watching him too! LOL.
Thanks for the input, and good luck on your 0.0001% . OHH to be
there..(stop daydreaming Greg!!!)
~Greg Fuchs
Greg,
penalty.
seal in some heat!
Check six,
Bob Borger
