n277dl
Posted: Sat Jan 10, 2009 8:34 pm Post subject: EFIS - Dual screen AFS advanced deck |
Hey folks,
I was playing around with xpanel panel design tool and it looks like it will be tight to get a set of Advanced Deck screens side by side on the stock -10 panel without pushing the com/gps/avionics stack to the right of center. I've seen a couple post from Rob H that shows his panel and it looks like they will fit, just snugly. (I'm assuming Rob is flying with the larger Advanced Deck in his 10)
So, just curious with those that are flying with dual/triple screen efis's... is it a big deal that the avionics stack is pushed off center? If you were doing it again, would you keep the dual screens side by side (and/or stacked) or would you split them up and move one screen to the right side and only fly with the one screen in front of you?
I'm flying with a Dynon d10 in the 7A and of course without the moving map I want the 430 close.
Won't I still need to have easy access to the 430 for IFR approaches/flight plans, etc.
Hope to finish up the baffles/cowl tomorrow. Going to have to get off the fence and decide on avionics soon to keep this thing moving forward...
_________________ Doug
"Fools" are always more creative than process people and will always find ways to ruin a perfectly good set of processes. |
ricksked(at)embarqmail.co Guest
Posted: Sat Jan 10, 2009 9:07 pm Post subject: EFIS - Dual screen AFS advanced deck |
Doug,
I'm not sure you can get it to work with the stock panel. Heres mine with an aftermarket panel and two 3500's. Stein sells one that will work though I'm sure. This picture was well over a year ago, lots more airplane around it now.
Rick Sked
40185
690.35 KB |
646 Time(s) |
lbgjb10
Posted: Sun Jan 11, 2009 8:51 am Post subject: Re: EFIS - Dual screen AFS advanced deck |
I have dual AFS 3500 set up to change to 4500 with garmin 'stack' between. They are 'shifted 'left' so all is easy to reach. I was initially concerned that the panel lacked 'symmetry but since really appreciate how easy it is to reach 430/530 and the right AFS. The copilot still can use the right AFS and also reach the radios. The autopilot also is in each reach, and easy to see. cheers. larry
_________________ Larry and Gayle N104LG |
MauleDriver(at)nc.rr.com Guest
Posted: Sun Jan 11, 2009 11:26 am Post subject: EFIS - Dual screen AFS advanced deck |
Slightly off-topic, but here is my 3 screen GRT with Stein's "center
canted left" panel blank. Fair symmetry here but still pilot optimized.
Bill "wiring it up" Watson
40605
don't archive
157.42 KB |
568 Time(s) |
bwestfall
Posted: Sun Jan 11, 2009 12:49 pm Post subject: EFIS - Dual screen AFS advanced deck |
Larry I'd love to see pictures if you have them.
-Ben
__________ Information from ESET NOD32 Antivirus, version of virus signature
database 3757 (20090111) __________
The message was checked by ESET NOD32 Antivirus.
lbgjb10
Posted: Sun Jan 11, 2009 5:17 pm Post subject: Re: EFIS - Dual screen AFS advanced deck |
i'll see if i can get the picture attached. it's a crummy picture, but only one i have of the panel. haven't finished it yet--still trying to figure out what kind of labeling to do. i'll take some pictures next time at the hangar
44.31 KB |
613 Time(s) |
geoff Combs
Posted: Sun Jan 11, 2009 5:39 pm Post subject: Re: EFIS - Dual screen AFS advanced deck |
I have developed a new panel for the RV-10 I am building and it will hold 2 AFS advanced decks side by side. Here is a picture of the prototype
mock up in my Rv-10. In this picture the backups are above but I will put them on the left side running vertical.
New picture of the carbon panel
45.88 KB |
538 Time(s) |
443.99 KB |
642 Time(s) |
526.32 KB |
626 Time(s) |
_________________ Build QB RV-10 N829GW
n277dl
Posted: Sun Jan 11, 2009 7:15 pm Post subject: Re: EFIS - Dual screen AFS advanced deck |
| ricksked(at)embarqmail.co wrote: | Doug,
Rick Sked
40185
Rick, looks nice. How tall is the panel? Looks like Stein has a blank that is ~1.5" taller than Van's stock. I'm 6'5" so knee/leg room is key for me.
Doug
