Fuel flow indicator
Fox5flyer
PostPosted: Thu Jan 08, 2009 6:37 am    Post subject: Fuel flow indicator Reply with quote
It should work just fine, Lynn. The sender measures the flow through the
line. Once you become accustomed to having a fuel flow gauge, you'll never
have another airplane without one.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 402+ TT
"The aim of an argument or discussion should not be victory, but progress."
- Joseph Joubert
Lynn scribbled:
I would think that the F210 would work with gravity fuel flow...why
wouldn't it?
Lynn Matteson
Lynn Matteson
PostPosted: Sat Jan 10, 2009 9:07 am    Post subject: Fuel flow indicator Reply with quote
My Northstar F210 arrived today...that was quick. In reading the
installation instructions (yeah, I'm one of those guys) for the
transducer, it says to install vertically. This is going to be a bit
of a problem for me because I don't have much of a vertical area
between the header tank and my carb, which is down low on a Jabiru
engine. I may have to install in my console, using a 90° fitting on
either side of it, due to limited vertical space inside the console.
They say the vertical mounting is so that any air bubbles can be
cleared more easily.
Has anyone mounted theirs horizontally? If so, have you had any
problems? I can see their point regarding air bubbles, but I'd think
that any air bubbles would vibrate themselves out rather quickly,
unless there is a "trap" built into the cavity of the transducer
where the impeller resides...I'm assuming this is a rotating-impeller
measuring device, right?
Lynn Matteson
Jabiru 2200, #2062, 596+ hrs
Sensenich 62x46
flying again after engine rebuild, and new Electroair direct-fire
ignition system;
also building a new pair of snow skis
Lynn
Kitfox IV-Jabiru 2200
N369LM
akflyer
PostPosted: Sat Jan 10, 2009 10:56 am    Post subject: Re: Fuel flow indicator Reply with quote
engine. I may have to install in my console, using a 90� fitting on
Lynn Matteson
Sensenich 62x46
ignition system;
Lynn,
Mine is coming off the header tank behind the seat and I put about a 15% slope to it. It works just fine.
DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
Lynn Matteson
PostPosted: Sat Jan 10, 2009 12:20 pm    Post subject: Fuel flow indicator Reply with quote
Thanks Leonard...I might get away with a bit of slope to mine
too....drop the fuel line to the floor level of my console, a slight
bend up, then the transducer, then a slight bend from the transducer
to the roof of the console, then forward...ought to work.
Lynn Matteson
Sensenich 62x46
ignition system;
> Lynn Matteson
> Kitfox IV Speedster, taildragger
> Sensenich 62x46
> ignition system;
> do not archive
Lynn,
DO NOT ARCHIVE
Leonard Perry
Soldotna AK
Avid "C" / Mk IV
582 IVO IFA
Full Lotus 1260
As done as any plane will ever be.... cause now the tinkeritis
takes over.
hander outer of humorless darwin awards
http://forums.matronics.com/viewtopic.php?p 23892#223892
Lynn
N369LM
larry huntley
PostPosted: Sat Jan 10, 2009 2:41 pm    Post subject: Fuel flow indicator Reply with quote
Received mine today also. Larry
Larry Huntley,Dundee,NY
Kitfox 4-1200 N234EE
EA81,AMAX Redrive Warp 3 blade
815TL
PostPosted: Sat Jan 10, 2009 5:08 pm    Post subject: Re: Fuel flow indicator Reply with quote
Larry, let me know how you make out with it. Even though I only have the 10 gallon tank in mine, it would be nice to be able to figure fuel burn rate for best distance.
Andrew
Fox5flyer
PostPosted: Sat Jan 10, 2009 5:19 pm    Post subject: Fuel flow indicator Reply with quote
Lynn, not being one to follow the crowd or be quick to do what I'm told, I
mounted mine horizontally. Their reasons have merit. However, if it's
mounted down low, like mine is, just after it comes out of the header,
there should be no bubbles as they will move toward the highest point and
away from the transducer. Once it's installed, just pump a couple gallons
of gas through it and any air in the system should be gone. Over 400 hours
on mine and no problems.
You're correct on how the impeller works.
Deke Morisse
Mikado Michigan
- Joseph Joubert
transducer, it says to install vertically. This is going to be a bit of a
problem for me because I don't have much of a vertical area between the
header tank and my carb, which is down low on a Jabiru engine. I may have
to install in my console, using a 90° fitting on either side of it, due
to limited vertical space inside the console. They say the vertical
mounting is so that any air bubbles can be cleared more easily.
Has anyone mounted theirs horizontally? If so, have you had any problems?
I can see their point regarding air bubbles, but I'd think that any air
bubbles would vibrate themselves out rather quickly, unless there is a
"trap" built into the cavity of the transducer where the impeller
resides...I'm assuming this is a rotating-impeller measuring device,
right?
Lynn Matteson
Sensenich 62x46
ignition system;
larry huntley
PostPosted: Sat Jan 10, 2009 7:02 pm    Post subject: Fuel flow indicator Reply with quote
Hi Andrew,
Heard you were under the weather. Hope things are picking up.
Kitfox will be a while. Champ fuselage will be out of the shop next week
Fox bottom cowl is undergoing surgery to reposition the radiator. It will be
in the shop next and will get a carb change and a muffler system. I think it
will fly within the month. Getting the skis cleaned up just in case..
I have a place in mind for the monitor ,but I have to read and find oiut
if it needs to be forward of the fuel pump or if it can be behind it just
below the header.
Small tank might be even more reason for a monitor.
Larry
Lynn Matteson
PostPosted: Sun Jan 11, 2009 6:12 am    Post subject: Fuel flow indicator Reply with quote
Thanks, Deke. I'll mount mine according to what vertical room I have
within the confines of the console, taking their "must be mounted
vertically" note in BOLD FACE lettering into account. Sounds like you
and Leonard both bucked the system. : ) My only concern about it NOT
being vertical is that there might be a pocket in the impeller
cavity where air could hide, and hinder readings.
By the way, the skis are coming along, one is finished, ready for
primer, and the other is waiting for the proprietor of the ski shop
to get his butt back out there and finish it up. The hangar driveway
is cleared out, the ramp will get a snowthrower touch up today, and
the skis could be going on tomorrow. Don't ya love this new snow? We
just got about 10" of more in the last two days....just in time for
the test of the skis.
Lynn Matteson
Sensenich 62x46
ignition system;
On Jan 10, 2009, at 8:18 PM, fox5flyer wrote:
<fox5flyer(at)idealwifi.net>
told, I mounted mine horizontally. Their reasons have merit.
However, if it's mounted down low, like mine is, just after it
comes out of the header, there should be no bubbles as they will
move toward the highest point and away from the transducer. Once
it's installed, just pump a couple gallons of gas through it and
any air in the system should be gone. Over 400 hours on mine and
no problems.
Deke Morisse
Mikado Michigan
progress."
- Joseph Joubert
> bit of a problem for me because I don't have much of a vertical
> area between the header tank and my carb, which is down low on a
> Jabiru engine. I may have to install in my console, using a 90°
> fitting on either side of it, due to limited vertical space
> inside the console. They say the vertical mounting is so that any
> think that any air bubbles would vibrate themselves out rather
> quickly, unless there is a "trap" built into the cavity of the
> transducer where the impeller resides...I'm assuming this is a
> rotating-impeller measuring device, right?
> Lynn Matteson
> Sensenich 62x46
> ignition system;
> do not archive
Lynn
N369LM
akflyer
PostPosted: Sun Jan 11, 2009 4:38 pm    Post subject: Re: Fuel flow indicator Reply with quote
It is a "turbine" in there not an impeller.... now you can brag about having a turbine in your kitfox....
Here are a couple pics of mine
 Filesize:  270.58 KB
 Viewed:  586 Time(s)
 Filesize:  309.39 KB
 Viewed:  576 Time(s)
DO NOT ARCHIVE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
Lynn Matteson
PostPosted: Sun Jan 11, 2009 5:36 pm    Post subject: Fuel flow indicator Reply with quote
Touche.... : )
Lynn Matteson
Jabiru 2200, #2062, 600.2 hrs
Sensenich 62x46
ignition system;
DO NOT ARCHIVE
Leonard Perry
Soldotna AK
Avid &quot;C&quot; / Mk IV
582 IVO IFA
Full Lotus 1260
takes over.
http://forums.matronics.com/viewtopic.php?p 24120#224120
http://forums.matronics.com//files/transducer_install_2_161.jpg
http://forums.matronics.com//files/transducer_install_1_608.jpg
Lynn
N369LM
Dick Maddux
PostPosted: Mon Jan 12, 2009 8:43 am    Post subject: Fuel flow indicator Reply with quote
I have always wanted a fuel flow gage in my Kitfox but I am a little concerned about the sending unit. What if the rotor jams? Will it stop the fuel flow to the engine? Now I had one in my Piper Pacer before I sold it and I loved it.(it was the EI aviation unit) That Northstar unit is sure tempting me as it is cheap, light and has lots of useful features.
Another useful item I would not be without is my Monroy traffic alerter. It works very well at detecting traffic. I now have it installed in my panel vs on top of the glareshield.
        Dick Maddux
        Pensacola,Fl
New year...new news. Be the first to know what is making headlines.
akflyer
PostPosted: Mon Jan 12, 2009 12:53 pm    Post subject: Re: Fuel flow indicator Reply with quote
[quote="Dick Maddux"]I have always wanted a fuel flow gage in my Kitfox but I am a little concerned about the sending unit. What if the rotor jams? Will it stop the fuel flow to the engine? Now I had one in my Piper Pacer before I sold it and I loved it.(it was the EI aviation unit) That Northstar unit is sure tempting me as it is cheap, light and has lots of useful features.
� � � � Dick Maddux
� � � � Pensacola,Fl
I cant imagine how big of a piece of crap it would take to stop the turbine from flowing fuel. If you are that worried, you could run a simple bypass valve and line around it in the extremely remote event that it stopped flowing. But if you are going to go to that length, you may as well run a redundant fuel system to include new pick ups in the tanks all the way to an additional fuel pump. May even try to bolt another set of carbs inline incase one get some crap jammed in the needle.
I would not be too worried about it. Just run the clear filter in front of it as the instructions call for (you can see it in the pics I posted) and you should be golden. I am convinced that the benefits far out weight the negatives or what if's. You would be amazed what 30-50 rpm will do for fuel burn (let alone a couple hundred RPM) versus the speed difference it shows on the GPS.
DO NOT ARCHIVE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
gary.algate(at)sandvik.co
PostPosted: Mon Jan 12, 2009 1:21 pm    Post subject: Fuel flow indicator Reply with quote
The way the turbine is designed it will allow full flow thru even if it jams.
I have been using them for approx 6 yrs and no problems
Gary Algate
Classic 4 jab 2200
Office Phone: +61 8 8276 7655
This e-mail is confidential and it is intended only for the addressees. Any review, dissemination, distribution, or copying of this message by persons or entities other than the intended recipient is prohibited. If you have received this e-mail in error, kindly notify us immediately by telephone or e-mail and delete the message from your system. The sender does not accept liability for any errors or omissions in the contents of this message which may arise as a result of the e-mail transmission.
“This year, instead of sending you a Christmas card in the mail, we have made a contribution to [url=Arial]UNICEF Australia[/url]. We wish you a safe and happy Christmas".
Catz631(at)aol.com
Sent by: owner-kitfox-list-server(at)matronics.com
13/01/2009 03:22 AM
Please respond to
kitfox-list(at)matronics.com To
kitfox-list(at)matronics.com cc
Subject
Dick Maddux
Pensacola,Fl
pwmac(at)sisna.com
PostPosted: Mon Jan 12, 2009 2:47 pm    Post subject: Fuel flow indicator Reply with quote
Correct Gary.
Boatersland has the northstar F210 on sale $109. Good until 1/31
Paul
At 01:20 PM 1/12/2009, you wrote:
[quote]The way the turbine is designed it will allow full flow thru even if it jams.
Gary Algate
Classic 4 jab 2200
“This year, instead of sending you a Christmas card in the mail, we have made a contribution to UNICEF Australia. We wish you a safe and happy Christmas".
Catz631(at)aol.com
13/01/2009 03:22 AM
Please respond to
To
cc
Subject
Dick Maddux
Pensacola,Fl
New year...new news. Be the first to know what is making headlines .
Kitfox-List Email Forum -
- MATRONICS WEB FORUMS -
- List Contribution Web Site -
Dick Maddux
PostPosted: Tue Jan 13, 2009 6:12 am    Post subject: Fuel flow indicator Reply with quote
OK ! You guys have convinced me I am buying one of these Northstar units today at the super deluxe price of $109. Now I just have to find a space in my panel as it is full of stuff.
        Dick Maddux
        Pensacola,Fl
jridgway
PostPosted: Tue Jan 13, 2009 5:57 pm    Post subject: Re: Fuel flow indicator Reply with quote
I had one years ago on another aircraft years ago. LOVED IT !! Just got one for my KF3. What I usually did was measure the fuel in the wing tank with a 'accurately calibrated' measuring stick..then enter this value in my Fuel Computer during normal engine warm up / preflight procedures. I would update gallons on board (i.e. fuel remaining) every time I added gas to the aircraft. If I had not flown for few weeks or so, I would do measuring stick double check / recalibrate during my preflight..saved my butt twice..
I also just added a low fuel sensor on my KF3. I welded up a lightweight aluminum tube (about the size of a bathroom paper tissue tube) and put a float switch in it and put it in line between the header tank and one wing tank. I did this because I did not want to risk trying to put it in the header tanks and get a leak I could not stop.
Jack
