Spinner Template
Paul Valovich
PostPosted: Fri Jan 09, 2009 9:03 am    Post subject: Spinner Template Reply with quote
I have seen numerous references to a constant speed spinner cut-out template – supposedly located somewhere on the web.
I have searched in all the usual places in an attempt to locate it – with zero success.
Can anyone provide the link? I have a new Hartzell prop.
The -8A plans provide clear direction for drawing one by hand, but I want a cross-check on my efforts. Seems to me that random mass distribution errors introduced during the prop/spinner mounting process should nearly cancel out or have minimal effect if one is very careful. However, this is one area where I want to do everything possible to eliminate vibration.
Paul Valovich
RV-8A N192NM Reserved (again)
Dale Ensing
PostPosted: Fri Jan 09, 2009 9:33 am    Post subject: Spinner Template Reply with quote
Paul,
I have a drawing/tracing of the actual finished cut-outs in my Van's 6A spinner for a Hartzell prop. Can
fax to you if you would like.
Dale Ensing
Dale Ensing
RV-6A
Aero Plantation
Weddington NC
Bill Schlatterer
PostPosted: Fri Jan 09, 2009 6:17 pm    Post subject: Spinner Template Reply with quote
Not sure if this is the one you want but it is for the blended AF Hartzell on my O-360 A1A. Others available on the Hartzell site.
Hope this helps!
Bill S
7a finishing
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Valovich, Paul
Sent: Friday, January 09, 2009 11:00 AM
To: rv-list(at)matronics.com
Subject: Spinner Template
Paul Valovich
href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List
Van's-Hartzell_Cutout_Temp_.pdf
Download
 Filename:  Van's-Hartzell_Cutout_Temp_.pdf
 Filesize:  31.86 KB
 Downloaded:  429 Time(s)
