Fox5flyer Guest
Posted: Wed Jan 07, 2009 6:58 am Post subject: First Flight - finally |
Agreed, Rick. During takeoff I don't look at my airspeed indicator as it's all done by "seat of the pants". Twice, in the past, after takeoff I found I had no airspeed. However, flying the airplane was not an issue as I simply maneuvered back to my airstrip, landed, and determined the problem. Both times it was caused from me forgetting to put my pitot cover on and after only a couple of days a bug (of some sort) had laid an egg inside it that turned into a little green maggot that completely the tube. Simple fix. Of course, I'm much more careful now about remembering that cover.
Also, congrats on your completion and first flight, Rick. Kudos to you for sticking with it for all of these years. Many would not have ever completed it. Keep us in the loop regarding your fly off.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 402+ TT
"The aim of an argument or discussion should not be victory, but progress."
- Joseph Joubert
Lynn Matteson
Posted: Wed Jan 07, 2009 8:38 am Post subject: First Flight - finally |
I agree....at one point in my training (in my Kitfox) my instructor
reached over and covered the ASI, and told me to land, which I did
because by then it was registered in the seat of my pants just how
the plane should feel when it is at the right speed to land.
Lynn Matteson
Jabiru 2200, #2062, 596+ hrs
Sensenich 62x46
flying again after engine rebuild, and new Electroair direct-fire
ignition system;
also building a new pair of snow skis
On Jan 7, 2009, at 9:34 AM, Weiss Richard wrote:
On Jan 6, 2009, at 10:08 AM, Patrick Best wrote:
> So you continued to fly test manoeuvres despite a lack of airspeed
> indication?
Yes. The maneuvers were necessary to return to the airport and
land anyway. (Turns, slow flight, etc.)
Lack of an airspeed indicator is not the end of the world. Just
had to look outside at the wingtip and see the angle it made with
the horizon. Also, your senses come into play. Air noise levels,
seat of the pants, visual cues, engine sound, etc. It really was a
non issue.
You're in the air, flying fine, and you know you have to return to
earth. What would you do differently?
Rick Weiss
N39RW Series V Speedster, 912ULS
SkyStar S/N 1
Port Orange, FL
www.matronics.com/contribution _-
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Patrick.Best(at)telus.com Guest
Posted: Thu Jan 08, 2009 7:46 am Post subject: First Flight - finally |
Thanks for your responses to my question!
It makes good training sense too.
-PB
PMorel
Joined: 09 Jul 2007 Posts: 62 Location: Locust Grove, GA USA
Posted: Thu Jan 08, 2009 12:48 pm Post subject: First Flight - finally |
Rick
Nice job! I really like the paint scheme. Reminds me of an airline I used to work for
Paul Morel
912 Speedster
93.86 KB |
421 Time(s) |
93.99 KB |
401 Time(s) |
_________________ Paul Morel
912 Speedster
Locust Grove, GA
www.WingsAirPhotos.com |
MDKitfox(at)aol.com Guest
Posted: Thu Jan 08, 2009 9:17 pm Post subject: First Flight - finally |
Paul,
Thanks. If your airliner had a widget in the logo, you win the prize. Glad you noticed. It took a few weeks to do.
Rick Weiss
SkyStar S/N 1
Port Orange, FL
On Jan 8, 2009, at 3:46 PM, Paul Morel wrote:
| Quote: | Rick
Paul Morel
912 Speedster
= [quote][b]
PMorel
Posted: Fri Jan 09, 2009 6:19 am Post subject: First Flight - finally |
Rick
I used to work in DAB for DL 80-96 then to Flight Control to dispatch. Also lived in Port Orange and NSB off Tomoka Farms Rd. We need to hook up sometime. Getting close to my "First Flight" too. Maybe in a couple of weeks. Ran into a snag with my interior seats and glareshield but with the help of the kitfox enthusiasts and supporters, I think I'm going to do fine.
Paul
912 Speedster
Locust Grove, GA
330.92 KB |
405 Time(s) |
334.95 KB |
388 Time(s) |
912 Speedster
Locust Grove, GA
