Thruster87
Posted: Wed Jan 07, 2009 9:39 pm Post subject: Tire Pressure |
What tire pressures are recommended for the standard Zenith issue Condor tires ?? Thanks
Gig Giacona
Posted: Thu Jan 08, 2009 6:08 am Post subject: Re: Tire Pressure |
According to page 6 of 6-G in the construction manual 50psi.
601XL Under Construction
tonyplane(at)bellsouth.ne Guest
Posted: Thu Jan 08, 2009 7:03 am Post subject: Tire Pressure |
Per the AMD Zodiac 601XL POH for 500x5 4 ply tires the T.P. is 30 psig.
You can get the AMD XL POH on the Zenith web site.
Tony Graziano
Gig Giacona
Posted: Thu Jan 08, 2009 8:32 am Post subject: Re: Tire Pressure |
| tonyplane(at)bellsouth.ne wrote: | Per the AMD Zodiac 601XL POH for 500x5 4 ply tires the T.P. is 30 psig.
Tony Graziano
That is correct for the 4 ply tires but according to the build manual the kit comes with 6 ply tires.
jaybannist(at)cs.com Guest
Posted: Thu Jan 08, 2009 9:45 am Post subject: Tire Pressure |
AMD says 30 psi. ZAC says 50 psi. I split the difference and use 40 psi.
Jay in Dallas
Thruster87
Posted: Thu Jan 08, 2009 12:33 pm Post subject: Re: Tire Pressure |
Thank you all .I friend runs his Cessna 150 at 30psi nose and 28psi mains. So 30psi should be in the ball park
leo.gates
Posted: Thu Jan 08, 2009 3:26 pm Post subject: Tire Pressure |
Jay, ZAC says air to 2/3 rim above ground for the HD and HDS. (2/3 tire
rim distance to outside of tire) Of course that is 1200 lb gross vs
1320 for the XL. On my HDS I found 2/3 to be 18 psi. OK for unimproved
runway, I guess. I find 25 psi is just right. 50 psi seems a bit
overpressure to me.
Leo Gates
N601Z - CH601HDS TDO
Rotax 912UL
jaybannist(at)cs.com wrote:
[quote] AMD says 30 psi. ZAC says 50 psi. I split the difference and use 40 psi.
Jay in Dallas
