sight glass fuel indicator?
pwmac(at)sisna.com
PostPosted: Tue Jan 06, 2009 2:09 pm    Post subject: sight glass fuel indicator? Reply with quote
Kinda late reply. Thanks for jogging my brain.
Anyway here are 2 more solutions:
http://www.cruzpro.com/fu30.html
Very cool and simple!!
and
http://www.northstarnav.com/en/Products/Fuel-Management/F210-Fuel/
Very popular. The "Northstar F210" is the same product as the "Navman
Fuel 2100". It has a new price and supplier.
Get these gadgets from the boat places.
Paul
At 12:40 PM 12/8/2008, Paul Morel wrote:
Here's about the cheapest Fuel Flow system I found. I got it a
little cheaper at Oshkosh this past summer and it's going in my Speedster.
http://www.fdatasystems.com/
Paul Morel
Model IV Speedster
Locust Grove, GA
akflyer
PostPosted: Tue Jan 06, 2009 7:05 pm    Post subject: Re: sight glass fuel indicator? Reply with quote
I have the 210 and love it. Seems to be pretty dang accurate. It says within 5% out of the box, and it can be calibrated with a known quantity to get it within 2%. So far I have not seen a need to calibrate it any closer.
DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
Float Flyr
PostPosted: Tue Jan 06, 2009 8:15 pm    Post subject: sight glass fuel indicator? Reply with quote
Leonard:
Where did you buy it? $$$?
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Float Flyr
PostPosted: Wed Jan 07, 2009 7:11 am    Post subject: sight glass fuel indicator? Reply with quote
I just got this in from Dave Fisher. He's the one who puts all those vids
on youtube. He claims to have run over 5000 gal. through one of those
units... He didn't say if they were real gallons or the U.S. Smile ... (Sorry,
thats right we don't have gallons here any more...Right!) and it's still
accurate. He was also nice enough to pass along the current price $109 U.S.
this was from a marine supply shop. www.boatersland.com/f210.html . I'm
going to be looking into this one.
Noel Loveys
Campbellton, NL, Canada
CDN AME intern, PP-Rec
C-FINB, Kitfox III-A
912 almost installed
Aerocet 1100 floats
noelloveys(at)yahoo.ca
winmail.dat
 Filename:  winmail.dat
 Filesize:  181.49 KB
 Downloaded:  302 Time(s)
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
msm_9949(at)yahoo.com
PostPosted: Wed Jan 07, 2009 9:22 am    Post subject: sight glass fuel indicator? Reply with quote
Noel: I've had one of these in Lola for 2 years now. Cheap and easy to install. Displays fuel burn, gallons used, gallons remaining. It's so accurate I've gotten to using fuel burn instead of rpms as primary power setting indication. You'll love it.
Marco Menezes N99KX
Model 2 582-90 C-Box 3:1 w/clutch
--- On Wed, 1/7/09, Noel Loveys <noelloveys(at)yahoo.ca> wrote:
Subject: RE: Re: sight glass fuel indicator?
Date: Wednesday, January 7, 2009, 10:09 AM
(Sorry,
still
akflyer
PostPosted: Wed Jan 07, 2009 9:28 am    Post subject: Re: sight glass fuel indicator? Reply with quote
Noel Loveys
Aerocet 1100 floats
That is where mine came from, but I think it was more when I ordered it last year. Get it, you wont be dissapointed. And it will really open your eyes when you see what 100 RPM can do to fuel burn versus cruise speed. I think you will find that you fly just a couple MPH slower and can stay up alot longer ant get farther down the trail....
DO NOT ARCHIVE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
larry huntley
PostPosted: Wed Jan 07, 2009 1:55 pm    Post subject: sight glass fuel indicator? Reply with quote
G'day Foxy Folks,
I called to order this fuel monitor. I see they also list a transducer. Is
this needed? The girl at the phone thought so. Makes a substantial
difference in price. Also, how do these hook up? Do they go in the line ,or
around it or ???
Sounds great to me as I am in the final processes of putting my Kitfox
back in the air after a fuel shortage off field landing. Thanx for the info.
Larry
Larry Huntley
Dundee,NY
4-1200 EA81
Amax redrive Warp Drive prop
Larry Huntley,Dundee,NY
Kitfox 4-1200 N234EE
EA81,AMAX Redrive Warp 3 blade
gary.algate(at)sandvik.co
PostPosted: Wed Jan 07, 2009 2:03 pm    Post subject: sight glass fuel indicator? Reply with quote
Likewise I have the Navman Fuel flow meter and checked accuracy after 3,000 Ltr (792 US Gals) and it read about 15 Ltrs high. Less than 2% and probably more due to draining at fuel checks than internal accuracy.
Gary Algate
Classic 4 Jab2200
Office Phone: +61 8 8276 7655
This e-mail is confidential and it is intended only for the addressees. Any review, dissemination, distribution, or copying of this message by persons or entities other than the intended recipient is prohibited. If you have received this e-mail in error, kindly notify us immediately by telephone or e-mail and delete the message from your system. The sender does not accept liability for any errors or omissions in the contents of this message which may arise as a result of the e-mail transmission.
“This year, instead of sending you a Christmas card in the mail, we have made a contribution to [url=Arial]UNICEF Australia[/url]. We wish you a safe and happy Christmas".
"Noel Loveys" <noelloveys(at)yahoo.ca>
Sent by: owner-kitfox-list-server(at)matronics.com
08/01/2009 02:01 AM
Please respond to
kitfox-list(at)matronics.com To
<kitfox-list(at)matronics.com> cc
Subject
Noel Loveys
Aerocet 1100 floats
winmail.dat
 Filesize:  181.49 KB
 Downloaded:  310 Time(s)
PostPosted: Wed Jan 07, 2009 2:28 pm    Post subject: sight glass fuel indicator? Reply with quote
I think you'll find the transducer is the small turbine that fits in the fuel line to record fuel flow - a simple 12 V wire connection runs back to the Fuel Flow meter to feed the system.
It is suggested that the transducer is located cabin side of the firewall i possible as they are normally made from glass reinforced plastic and will melt if exposed to extremely high temps (engine fire), I had difficulty dong this as mine has barbed connections and I don't have any hose inside the cabin so I connected it between the engine bay fuel filter and the carby. I then wrapped it completely in fire proof material so that it is full protected.
Hope this helps
Gary
Gary Algate
Classic 4 Jab2200
"Larry Huntley" <asq(at)roadrunner.com>
08/01/2009 08:32 AM
Please respond to
Subject
Re: Re: sight glass fuel indicator?
--> Kitfox-List message posted by: "Larry Huntley" <asq(at)roadrunner.com>
G'day Foxy Folks,
around it or ???
Larry
Larry Huntley
Dundee,NY
4-1200 EA81
larry huntley
PostPosted: Wed Jan 07, 2009 2:46 pm    Post subject: sight glass fuel indicator? Reply with quote
Gary,
Do you know if the transducer is part of the unit that is for sale? Also,what do you think of the chances of the little turbine plugging or failing and stopping fuel flow?
Thanx, Larry
akflyer
PostPosted: Wed Jan 07, 2009 2:46 pm    Post subject: Re: sight glass fuel indicator? Reply with quote
Mine came with the transducer
Northstar Explorer F210 NSTF210 1 113.99
Digital Fuel Display
w/Single Engine Kit
Subtotal 113.99
Shipping 23.47
Tax 0.00
Total 137.46
This was from my order on 6-30-07
I have a kitfox header tank installed behind the seat. I have a filter then the transducer coming off the bottom of the header, then reduce the line down to 5/16" and run aluminum tubing along the floor through the firewall into the gascolator.
DO NOT ARCHIVE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
Float Flyr
PostPosted: Wed Jan 07, 2009 3:10 pm    Post subject: sight glass fuel indicator? Reply with quote
I emailed boatersland and the reply I got was the transducer, which is
needed, is included in the kit.
This is part of the reply I got this afternoon.
<snip>
yes it does come with the sender
yes we do ship to Canada
<end of snip>
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
PostPosted: Wed Jan 07, 2009 3:36 pm    Post subject: sight glass fuel indicator? Reply with quote
Larry
when I purchased mine I paid about $250 and this included the transducer - most of the systems I have seen always include the transducer as they really do come as a set!
The turbine in the transducer is designed so that if for any reason it stops rotating it can still supply full flow through the blades of the turbine.
I know this works as on one occasion after transporting my plane to Australia when I started the engine I was showing fuel flow (up to max RPM on the ground) yet my EGT's were all in the green proving there was ample flow to the engine. After a few minutes the transducer started turning and all read normal.
I pulled the transducer and found that there was some fine residue in it which I cleaned out with no further problems.
I guess the 3 months in a shipping container with a dry fuel system allowed some crap to settle out.
Gary
Gary Algate Classic 4 jab2200
“This year, instead of sending you a Christmas card in the mail, we have made a contribution to [url=Arial]UNICEF Australia[/url]. We wish you a safe and happy Christmas". [quote][b]
Lynn Matteson
PostPosted: Wed Jan 07, 2009 7:52 pm    Post subject: sight glass fuel indicator? Reply with quote
When I go to this site: http://www.northstarnav.com/en/Products/Fuel-
Management/F210-Fuel/ two pictures come up....what is the D210?
They only seem to describe the F210.
Lynn Matteson
Jabiru 2200, #2062, 596+ hrs
Sensenich 62x46
flying again after engine rebuild, and new Electroair direct-fire
ignition system;
also building a new pair of snow skis
and
"Navman Fuel 2100". It has a new price and supplier.
Paul
> <pmorel(at)bellsouth.net>
> Speedster.
> Paul Morel
> Model IV Speedster
> Locust Grove, GA
Lynn
Kitfox IV-Jabiru 2200
N369LM
Paul A. Franz, P.E.
PostPosted: Wed Jan 07, 2009 8:44 pm    Post subject: sight glass fuel indicator? Reply with quote
Depth Display
<http://www.boatersland.com/d210.html>
Here's the manual
<http://primus.northstarnav.com/icrns/Northstar%20FAQS/Manuals/D210_manual.pdf>
Paul A. Franz
Registration/Aircraft - N14UW/Merlin GT
Engine/Prop - Rotax 914/NSI CAP
Bellevue WA
425.241.1618 Cell
Paul A. Franz, P.E.
Bellevue WA
425.241.1618 Cell
425.440.9505 Office
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
Lynn Matteson
PostPosted: Thu Jan 08, 2009 5:57 am    Post subject: sight glass fuel indicator? Reply with quote
Thanks, Paul....depth of snow? Just kidding....the F210 sounds like a
good "hole filler" for that hole in my panel where my fuel pressure
gauge used to reside (now that I've gone to gravity fuel feed)...and
beneficial, too. I may have to get one.
I would think that the F210 would work with gravity fuel flow...why
wouldn't it?
Lynn Matteson
Sensenich 62x46
ignition system;
almost done with building a new pair of snow skis
On Jan 7, 2009, at 11:42 PM, Paul Franz - Merlin GT wrote:
Depth Display
Paul A. Franz
Bellevue WA
425.241.1618 Cell
Lynn
N369LM
