Posted: Tue Jan 06, 2009 3:06 pm Post subject: W&B 601XL |
It has already been tested and (as I recall) the pilot and passenger walked
away. Picture attached. Was it Poland or the Czech Republic?
-- Craig
28.95 KB |
865 Time(s) |
Terry Phillips
Joined: 11 Jan 2006 Posts: 346 Location: Corvallis, MT
Posted: Tue Jan 06, 2009 4:22 pm Post subject: W&B 601XL |
I believe it was Minnesota. See:
http://brsparachutes.com/files/Documents/Press%20Releases/PR%20Saves%20212-213.pdf
Terry
At 04:04 PM 1/6/2009 -0700, you wrote:
| Quote: | It has already been tested and (as I recall) the pilot and passenger walked
-- Craig
Terry Phillips ZBAGer
ttp44~at~rkymtn.net
Corvallis MT
601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail, flaps, & ailerons
are done; working on the wings
http://www.mykitlog.com/N47TP/
_________________ Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
Zenith 601XL/Jab 3300 slow build kit - Tail feathers done; working on the wings. |
Gig Giacona
Posted: Tue Jan 06, 2009 7:18 pm Post subject: Re: W&B 601XL |
| Terry Phillips wrote: | | I believe it was Minnesota. |
Well they talk funny there too.
That is amazing. I can't put a screw in the canopy without causing a crack yet this one can have a rocket go off inches away and not damage it.
Look at the gear on that thing. It pulled MANY G's on impact and yet the wings stayed on.
601XL Under Construction
Martin Pohl
Joined: 30 Jan 2006 Posts: 118 Location: CH-8645 Jona SG, Switzerland
Posted: Wed Jan 07, 2009 4:41 am Post subject: Re: W&B 601XL |
If anybody is interested in where the CZAW and european ULM versions have their BRS installed, have a look at the ULM-drawings (6-UL-5).
I am not sure if the 600kg BRS-version would fit right behind the firewall? The ULM version only needs the lighter 450kg parachute.
Martin
 Download |
| Filename: |
Zenair ULM supplement 22 pages.pdf |
1.96 MB |
| Downloaded: |
624 Time(s) |
_________________ Martin Pohl
Zodiac XL QBK
8645 Jona, Switzerland
http://www.pohltec.ch/ZodiacXL/Main.html |
PatrickW
Joined: 27 Oct 2006 Posts: 380 Location: Fort Worth, Texas
Posted: Wed Jan 07, 2009 7:30 pm Post subject: Re: W&B 601XL |
| Martin Pohl wrote: | | I am not sure if the 600kg BRS-version would fit right behind the firewall? |
I'm considering mounting a BRS-1350 between the firewall and the instrument panel of my 601XL with 650 canopy.
Here's pictures: http://picasaweb.google.com/Patrick.Hoyt/BRS#
When using the 650 canopy on the XL, I believe that the usual baggage compartment location is no longer possible due to the 650 canopy covering what previously would have been the frangible cover installed in a cutout of top skin. It may be possible to mount the BRS behind the baggage compartment bulkhead, but that would move the CG much further aft.
The challenge with putting the BRS up front is that it will displace depth behind the panel, which will limit what can be put in the panel on the passenger's side. To partially mitigate this, I fabricated a pan that allows the BRS to sit lower. I plan to "fine tune" my CG with appropriate placement of the battery.
I'm interested in what other people are doing, particularly those who are installing BRS's on 650's or XL's with 650 canopies.
- Pat
ggower_99(at)yahoo.com Guest
Posted: Wed Jan 07, 2009 9:11 pm Post subject: W&B 601XL |
Great for flying NORDO with only a compas OVER the instrument panel
Saludos
Gary Gower
PLEASE Do not Archive.
--- On Wed, 1/7/09, PatrickW <pwhoyt(at)yahoo.com> wrote:
| Quote: | From: PatrickW <pwhoyt(at)yahoo.com>
Subject: Re: W&B 601XL
Date: Wednesday, January 7, 2009, 10:30 PM
| Quote: | --> Zenith601-List message posted by: "PatrickW"
Martin Pohl wrote:
| Quote: | I am not sure if the 600kg BRS-version would fit right behind the
firewall?
bulkhead, but that would move the CG further much aft.
- Pat
Patrick
601XL/Corvair
N63PZ (reserved)
http://forums.matronics.com/viewtopic.php?p 23481#223481
alex_001
Posted: Thu Jan 08, 2009 10:00 am Post subject: Re: W&B 601XL |
have a look at drawing and pics to see forward installation (std CZAW)
91.77 KB |
762 Time(s) |
369.96 KB |
779 Time(s) |
170.16 KB |
803 Time(s) |
946.75 KB |
750 Time(s) |
PatrickW
Posted: Thu Jan 08, 2009 11:49 am Post subject: Re: W&B 601XL |
| alex_001 wrote: | | have a look |
Thanks for sharing those, Alex.
- Pat
