dalemed
Posted: Wed Dec 31, 2008 12:05 pm Post subject: Hand Riveter Heads |
Is Zenith Aircraft Company the only source for riveter heads that will form the A4 and A5 rivet heads properly?
I recently returned two heads to Zenith that I had originally purchased from them about 30 years ago when I thought I would scratch build a CH250. I used these in a standard hardware store hand riveter. I've used this old tool to set some rivets on the 601XL/650 that I'm building now and I wasn't very happy with the head that was being formed on the rivet. So, I decided to send them back to Zenith and have them reworked. Even though I had them triple wrapped, they broke out of the envelope and were lost. Zenith kindly sent me some new ones! However, the new ones won't fit my old tool (the replacements are a smaller diameter thread - the same as the thread on the pneumatic riveter I bought from Zenith).
The Zenith factory now tells me they can't supply the thread size my old riveter needs. So, I decided what the heck, I'll just buy a new riveter! I bought one at the local Menards that looked like it would get me into tight places only to discover when I got home that it uses the same thread size heads as my old riveter!
So I'm now looking for another supplier of rivet heads, or a recommendation for a good manual riveter that will take the same thread size heads as the Zenith Pneumatic riveter.
Any recommendations will be appreciated!
_________________ Dale
Zenith Zodiac CH650 |
bryanmmartin
Posted: Wed Dec 31, 2008 12:15 pm Post subject: Hand Riveter Heads |
It's not too hard to grind the heads to the proper shape your self.
Just chuck the head into a drill motor and spin it while grinding with
a small grinding bit in a Dremel tool. I bought spare heads for my
Harbor Freight riveter so I could grind a set and still have a flat set.
On Dec 31, 2008, at 3:05 PM, dalemed wrote:
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
_________________ --
Bryan Martin
do not archive. |
jaybannist(at)cs.com Guest
Posted: Wed Dec 31, 2008 12:21 pm Post subject: Hand Riveter Heads |
Dale,
I bought a swiveling head type rivet puller at the local Ace Hardware. I found that the ZAC riveter nose pieces wouldn't fit; so I just ground the Ace nose pieces myself. They were so hard that I had to heat them up and let them cool to be able to grind them. I chucked the nose piece in a hand drill and ground it with a ball end tool in a Dremel. It may not have precisely the same contour that ZAC provides, but I compared the results from both and it was certainly close enough for me.
Jay in Dallas
psm(at)att.net Guest
Posted: Wed Dec 31, 2008 12:22 pm Post subject: Hand Riveter Heads |
Hi Dale,
Have no fear. You can grind your own recesses in riveter nose pieces.
There are many ways to do this. Perhaps the best way is to use a
round grind stone or round cutter in a small rotary tool - a
"Dremel". I mounted my nose pieces in the 3 jaw chuck of my lathe
and turned the piece slowly while grinding the recess. You might do
the same thing using a drill instead of the lathe.
The only "Trick" is deciding when you have ground enough. This can
be done by testing the nose piece with actual rivet setting. If you
feel you have gone too far you can reduce the depth of the recess by
filing a flat zone off the end of the nose piece.
You may need to buy some new tools to accomplish this task. But,
isn't building the airplane mostly just a good excuse to buy new tools?
Good luck,
Paul
XL getting close
At 12:05 PM 12/31/2008, you wrote:
Dale
Flying Cessna 170B
Building Zenith CH650
ronpollock(at)gmail.com Guest
Posted: Wed Dec 31, 2008 12:23 pm Post subject: Hand Riveter Heads |
I hope this isn't a foolish question but do you need separate dies for
A4 and A5? The A4 die I ground seems to also be the right one for the
A5 shafts but wouldn't have the right head profile (?).
Thanks, Ron in L.A. (Happy New Year!)
slook(at)mchsi.com Guest
Posted: Wed Dec 31, 2008 12:26 pm Post subject: Hand Riveter Heads |
I use the manual riveter that Zenith sells. It has worked well and
the heads are already ground when you get it.
Steve
At 02:05 PM 12/31/2008, you wrote:
Steve Look
Monticello, IL
www.ilrt66.com
"Dogs have owners, Cats have staff"
Gig Giacona
Posted: Wed Dec 31, 2008 12:53 pm Post subject: Re: Hand Riveter Heads |
Yes they are different.
| ronpollock(at)gmail.com wrote: | I hope this isn't a foolish question but do you need separate dies for
Thanks, Ron in L.A. (Happy New Year!) |
601XL Under Construction
NYTerminat(at)aol.com Guest
Posted: Wed Dec 31, 2008 12:58 pm Post subject: Hand Riveter Heads |
Dale
It would be a lot easier to re tap the treads in the rivet gun if you already have the nose pieces from Zenith.
Bob Spudis
N701ZX
In a message dated 12/31/2008 12:22:55 P.M. Pacific Standard Time, psm(at)att.net writes:
| Quote: | --> Zenith601-List message posted by: Paul Mulwitz <psm(at)att.net>
Hi Dale,
Good luck,
Paul
XL getting close
| Quote: | --> Zenith601-List message posted by: "dalemed" <dalemed(at)gmail.com>
Dale
Flying Cessna 170B
Building Zenith nbsp; sp; (And Get Some AWESOME FREE find you for -Matt Dralle, List e the es y - MATRONICS WEB FORUMS =========================
New year...new news. Be taolcom00000026">headlines.
JohnDRead(at)aol.com Guest
Posted: Wed Dec 31, 2008 2:05 pm Post subject: Hand Riveter Heads |
The formed rivet heads are different sizes. I think if you ask them Zenith will tell you the correct dimensions for the riveter heads.
John Read
CH701 - Elbert CO - Jabiru 3300
Phone: 303-648-3261
Fax: 303-648-3262
Cell: 719-494-4567
In a message dated 12/31/2008 1:24:08 P.M. Mountain Standard Time, ronpollock(at)gmail.com writes:
| Quote: | --> Zenith601-List message posted by: "Ron Pollock" <ronpollock(at)gmail.com>
Thanks, Ron in L.A. (Happy New sp; (And Get Some AWESOME FREE find you for -Matt Dralle, List e the es y - MATRONICS WEB FORUMS =========================
latest news - from fashion trends to celebrity break-ups and everything in between.
Tim Juhl
Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
Posted: Wed Dec 31, 2008 4:40 pm Post subject: Re: Hand Riveter Heads |
Send in the heads you got from menards. I was not happy with the ones I tried to grind myself so finally had them do it. Glad I did.
_________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
carlossa52(at)gmail.com Guest
Posted: Wed Dec 31, 2008 5:16 pm Post subject: Hand Riveter Heads |
See this video posted by ZAC on youtube:
http://www.youtube.com/watch?v=-FfdJPOM51A
(It's also posted, with better quality, on zenith.aero )
Carlos
2008/12/31 dalemed <dalemed(at)gmail.com (dalemed(at)gmail.com)>
[quote] --> Zenith601-List message posted by: "dalemed" <dalemed(at)gmail.com (dalemed(at)gmail.com)>
Posted: Wed Dec 31, 2008 5:25 pm Post subject: Hand Riveter Heads |
There is also a section on making and testing riveter heads in the Zenith construction standards document in the builder’s area on the Zenith site. But it doesn’t add much to what has already been posted.
-- Craig
From: owner-zenith601-list-server(at)matronics.com [mailto:owner-zenith601-list-server(at)matronics.com] On Behalf Of Carlos Sa
Sent: Wednesday, December 31, 2008 6:16 PM
Subject: Re: Hand Riveter Heads
Carlos
| Quote: | | http://www.matronics.com/contribution | 01234567890123
dalemed
naumuk(at)alltel.net Guest
Posted: Thu Jan 01, 2009 8:25 am Post subject: Hand Riveter Heads |
Dale-
Just a logical extension of the decision you made to build your own
airplane, isn't it!!
Bill
