dougsire
Posted: Mon Dec 29, 2008 2:07 pm Post subject: Yuba City Probable cause released |
NTSB released the probable cause for the 11/06 AMD accident in Yuba City. The smoking gun is....In-flight structural failure of the horizontal stabilizer and wings for undetermined reasons.
Doug Sire
Billings, MT
_________________ Doug Sire 601XL
Do Not Archive |
Gig Giacona
Posted: Mon Dec 29, 2008 2:50 pm Post subject: Re: Yuba City Probable cause released |
That makes things clear as mud. The one useful bit of info i gout out of it was this. "no oscillatory loading of the control surfaces was apparent." That would seem to be NTSB speak that rules out flutter.
That and they didn't rule out abrupt control input. Just that they couldn't see it on radar.
601XL Under Construction
Jeyoung65(at)aol.com Guest
Posted: Mon Dec 29, 2008 4:29 pm Post subject: Yuba City Probable cause released |
Giacona, why do you said "no oscillatory loading of the control surfaces was apparent"? Did I miss something in the post? I would think "In-flight structural failure of the horizontal stabilizer and wings for undetermined reasons." indicates they DO NOT KNOW why they failed! Jerry of Ga DO NOT ARCHIVE
In a message dated 12/29/2008 5:51:22 P.M. Eastern Standard Time, wrgiacona(at)gmail.com writes:
| Quote: | --> Zenith601-List message posted by: "Gig Giacona" <wrgiacona(at)gmail.com>
click here for the latest news that will have people talking.
Gig Giacona
Posted: Mon Dec 29, 2008 4:44 pm Post subject: Re: Yuba City Probable cause released |
I said "no oscillatory loading of the control surfaces was apparent" and put it in quotes because it is a direct quote from the report. I may be wrong but I would think that the phrase "oscillatory loading of the control surfaces" would be NTSB speak for flutter. If I'm wrong I'd like to know what it does mean.
[quote="Jeyoung65(at)aol.com"]Giacona, why do you said "no oscillatory loading of the control surfaces was apparent"? Did I miss something in the post? I would think "In-flight structural failure of the horizontal stabilizer and wings for undetermined reasons." indicates they DO NOT KNOW why they failed! Jerry of Ga DO NOT ARCHIVE
| Quote: | --> Zenith601-List message posted by: "Gig Giacona" <wrgiacona>
tonyplane(at)bellsouth.ne Guest
Posted: Mon Dec 29, 2008 4:58 pm Post subject: Yuba City Probable cause released |
The separation of the wings and horizontal stabilizer was in a downward
direction
..the possibility of an abrupt control input cannot be excluded. This
airplane is very responsive in pitch control. One of the handling quality
characteristics designed by the
airplane's manufacturer is that movement of the control stick produces large
and rapid changes in pitch attitude."
FWIW. I believe abrupt up elevator input caused horizontal stab downward
failure. Causes extreme nose down pitch and extreme neg gs on wing
resulting in wing failure in downward
direction. Saw this on a T-28A at the Crash Lab at March AFB many years ago
during aircraft accident investigation course.
Tony Graziano
601XL; N493TG; 454 hours
jaybannist(at)cs.com Guest
Posted: Mon Dec 29, 2008 4:59 pm Post subject: Yuba City Probable cause released |
Yes, you must have missed it. Quote from the report: "All observed fracture surfaces were overload, and no oscillatory loading of the control surfaces was apparent."
Another part of the report said that the failure was from static overload, not dynamic.
Jay in Dallas
Posted: Mon Dec 29, 2008 5:18 pm Post subject: Yuba City Probable cause released |
I guess I still don't understand the difference between static and dynamic loads. The report said that all the overloads were static, not dynamic. ZAC tested the 601XL wings for static loads twice and they passed with flying colors. So the static loads seen by the failed wings and horizontal stabilizer must have been greater than they were designed for.
Jay in Dallas
Posted: Mon Dec 29, 2008 5:41 pm Post subject: Yuba City Probable cause released |
That is why the stick is sometimes referred to a wing remover - you can remove the wings with ONE abrupt full deflection pull or push, with airspeed above Va.
Tony Graziano
planecrazydld(at)yahoo.co Guest
Posted: Mon Dec 29, 2008 7:16 pm Post subject: Yuba City Probable cause released |
Jay, you understand perfectly. Static overload can still happen if controls are used too suddenly or even in extreme wind shear. The other this is that low cycle fatigue/iterative static overload is accumulative. Each load past yield deforms the structure and particularly attach points. I also agree that this is a nice nail in the flutter coffin for this case at least.
David L. Downey
Harleysville (SE) PA, USA
--- On Mon, 12/29/08, jaybannist(at)cs.com <jaybannist(at)cs.com> wrote:
[quote]From: jaybannist(at)cs.com <jaybannist(at)cs.com>
Subject: Re: Re: Yuba City Probable cause released
Date: Monday, December 29, 2008, 8:15 PM
Jay in Dallas
leinad
Joined: 19 Sep 2006 Posts: 283 Location: Central Virginia
Posted: Tue Dec 30, 2008 10:20 am Post subject: Re: Yuba City Probable cause released |
I just checked the NTSB database and didn't see the report. Where are you guys reading this? Could someone post a link?
| dougsire wrote: | NTSB released the probable cause for the 11/06 AMD accident in Yuba City. The smoking gun is....In-flight structural failure of the horizontal stabilizer and wings for undetermined reasons.
Doug Sire
Billings, MT |
_________________ Scratch building XL with Corvair Engine |
Iberplanes
Joined: 10 Dec 2007 Posts: 174 Location: Igualada - Barcelona - Spain
Posted: Tue Dec 30, 2008 10:37 am Post subject: Yuba City Probable cause released |
[url=http://www.ntsb.gov/ntsb/brief.asp?ev_id 061115X01677&key=1]http://www.ntsb.gov/ntsb/brief.asp?ev_id 061115X01677&key=1[/url]
[url=http://www.ntsb.gov/ntsb/brief2.asp?ev_id 061115X01677&ntsbno=LAX07FA026&akey=1]http://www.ntsb.gov/ntsb/brief2.asp?ev_id 061115X01677&ntsbno=LAX07FA026&akey=1[/url]
Alberto Martin
www.iberplanes.es
Zodiac 601 XL Builder
Serial: 6-7011
Tail Kit: Finished
Wings: Not Started
Fuselage: Ordered
Engine: Jabiru 3300
_________________ Alberto Martin
601 XL - Jabiru 3300
http://www.iberplanes.es
Igualada - Barcelona - Spain |
Ron Lendon
David X
Joined: 10 Jan 2006 Posts: 154 Location: Princeton, NJ, USA
Posted: Thu Jan 01, 2009 10:38 am Post subject: Re: Yuba City Probable cause released |
I do not recall that ZAC ever did a negative G static test on this aircraft.
| jaybannist(at)cs.com wrote: | I guess I still don't understand the difference between static and dynamic loads. The report said that all the overloads were static, not dynamic. ZAC tested the 601XL wings for static loads twice and they passed with flying colors. So the static loads seen by the failed wings and horizontal stabilizer must have been greater than they were designed for.
Jay in Dallas
_________________ Zodiac 601 XL - CZAW Built - Rotax 912S
DO NOT ARCHIVE |
bryanmmartin
Posted: Thu Jan 01, 2009 11:05 am Post subject: Yuba City Probable cause released |
See: http://www.zenithair.com/zodiac/6-photo-testing.html
The pictures shown near the top of the page show negative G static
load testing. Positive G load testing would be done with the airframe
upside down with the sandbags stacked on the bottom of the wings.
Positive G load testing is shown in some of the photos in the lower
part of the page.
On Jan 1, 2009, at 1:38 PM, David X wrote:
aircraft.
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
_________________ --
Bryan Martin
do not archive. |
Posted: Thu Jan 01, 2009 11:24 am Post subject: Yuba City Probable cause released |
Go to the Zenithair.com site, click on 601 series, go clear to the bottom of the page and search 601 wing load test. You will find two separate series of test photos, both negative and positive.
Jay in Dallas
