brian
Joined: 02 Jan 2006 Posts: 643 Location: Sacramento, California, USA
Posted: Tue Jan 31, 2006 6:51 am Post subject: CJ6A: stations for CG calculation |
I am doing the W&B on a CJ6A for a friend. I am trying to find a full
set of stations for doing the calculation without having to go back to
the Chinese book and figure it out all over again.
I was looking through the archives where we had a big discussion of this
(and one of the famous McCoy/Lloyd flamefests) in May of '02. The
problem is, I can't find a complete set of stations from a standard
datum plane that includes the rear skid or tailcone for the placement of
lead to get the CG back in range.
Yes, I could go back out to the airplane with a tape measure and plumb
bob to figure it out but I suspect that there are a couple of people on
this list who could just answer the question and save me the time and trip.
Brian Lloyd 361 Catterline Way
brian-yak at lloyd dot com Folsom, CA 95630
- Antoine de Saint-Exupery
_________________ Brian Lloyd
- Antoine de Saint-Exupery |
cjpilot710(at)aol.com Guest
Posted: Tue Jan 31, 2006 9:20 am Post subject: CJ6A: stations for CG calculation |
Some 11 year ago when I got the CJ- IA Bill Freeze at DRV did mine and I have used this ever since.
The Zero Datum is 70 inches in front of the first vertical bulk head ("second firewall")
Oil tank at +57"
Pilot at +114"
Pax at +161"
Fuel at +133.5"
L main gear +128.75
R main gear +128.75
Nose gear +40.25
Tail cone (where I keep the ballast ) +335"
C/G range +111.2" to +116.1"
Hope that's a help.
Jim "Pappy" Goolsby
--> Yak-List message posted by: Brian Lloyd <brian-yak(at)lloyd.com>
Ernie
Posted: Tue Jan 31, 2006 9:40 am Post subject: CJ6A: stations for CG calculation |
I have a datum 24" forward of the prop axial plane. You could easily
just use the prop as the datum and subtract 24" from all the stations.
Prop = 24"
engine = 45"
Nosewheel=57"
accessory section=60"
oil = 69"
front seat=123"
jack point = 129"
front spar = 131.5"
main wheels = 146.5"
fuel = 149"
rear seat = 174"
avionics rack = =188"
battery box = 199"
adf rack = 214"
tail skid = 338"
Forward CG limt 127.93" (Front of MAC +11.7")
Aft CG limit = 132.80" (fron of MAC + 16.57")
front of MAC = 116.23"
CG range = 4.9"
Ernie
brian
Posted: Tue Jan 31, 2006 12:44 pm Post subject: CJ6A: stations for CG calculation |
Ernest Martinez wrote:
| Quote: | Prop = 24"
engine = 45"
Nosewheel=57"
oil = 69"
front seat=123"
jack point = 129"
front spar = 131.5"
fuel = 149"
rear seat = 174"
battery box = 199"
adf rack = 214"
tail skid = 338"
CG range = 4.9"
Well, so far everyone looks consistent.
Brian
brian
cjpilot710(at)aol.com wrote:
| Quote: | */The Zero Datum is 70 inches in front of the first vertical bulk head
("second firewall")/*
*/Oil tank at +57"/*
*/Pilot at +114"/*
*/Pax at +161"/*
*/Fuel at +133.5"/*
*/L main gear +128.75/*
*/R main gear +128.75/*
*/Nose gear +40.25/*
*/Tail cone (where I keep the ballast ) +335"/*
*/C/G range +111.2" to +116.1"/*
*/Hope that's a help./*
Works beautifully. Thank you.
mgdimarco
Joined: 20 Apr 2006 Posts: 23 Location: Kissimmee, FL
Posted: Sun Dec 28, 2008 12:37 am Post subject: Re: CJ6A: stations for CG calculation |
I have to admit some confusion on this issue. The w/b I had done has most of the station numbers matching the 70" from firewall datum. However the oil my guy used is at 48". The pilot station seems a bit aft when using 114.3. Seems to measure out at around 104. Etc., Etc. and none of this matches the CJ manual which seems to use the nose gear axle or the Leading edge of MAC.
What is the real answer on stations?
What is the MAC?
What is the LE of MAC station?
And what are the % LE of MAC limits really?
Thanks in advance
_________________ Michael Di Marco
China Blue
mgdimarco@yahoo.com
407-608-3290 |
Posted: Sun Dec 28, 2008 7:22 am Post subject: CJ6A: stations for CG calculation |
Mike,
I am away from home right now and not near my books. But the 70" measurement is from the vertical (or second) firewall. IF my memory services me right the oil tank is about the 48" mark. The Chinese used a different method of figuring C/G. I get home on the 1st or 2nd and will be able to help you. But I'm sure others on this list have gone though this before.
Jim "Pappy" Goolsby
In a message dated 12/28/2008 3:38:24 A.M. Eastern Standard Time, mgdimarco(at)yahoo.com writes:
| Quote: | --> Yak-List message posted by: "mgdimarco" <mgdimarco(at)yahoo.com>
What is the MAC?
Thanks in advance
Michael Di Marco
China Blue
407-348-4798
http://forums.matronics.com/viewtopic.php?p=221448#221448
One site keeps you connected to all your email: AOL Mail, Gmail, and Yahoo Mail=emlcntaolcom00000025">Try it now.
Dabear(at)damned.org Guest
Posted: Sun Dec 28, 2008 8:52 am Post subject: CJ6A: stations for CG calculation |
Michael,
There is some discussion on the stations. However the MAC location, LE of
MAC, and limits really provided. I did a spreadsheet and put it on the RSPA
website if you want to down load it (and are a member). I built that after
gathering W/B information from 10 CJ pilots and a few A/Ps. I also did some
more measurements on the scales with known weights and positions. The
Spreadsheet also allows you to calculate the w/b of your aircraft from scale
points. Call me to discuss the process if you want.
Randy "DaBear" DeVere
571.213.4344
wlannon(at)persona.ca Guest
Posted: Sun Dec 28, 2008 2:58 pm Post subject: CJ6A: stations for CG calculation |
Mike:
MAC is the "mean aerodynamic chord" of the wing. If the wing has no taper,
no sweep and no variation in airfoil properties over the span the MAC and
the measured chord are one and the same. If the same plank wing is swept
the effective chord length is increased (relative to airflow direction). The
MAC is therefore longer and the position of the MAC leading edge has moved
aft. Taper also changes position and length of the MAC.
In the plan view the MAC location of a tapered and/or swept wing will be
located somewhere around the mid half-span point. This is of no interest for
weight and balance. We are concerned only with it's location in the
elevation view.
That location is shown by fig. 1.3, pg. 6 of the CJ6 Tech. Specs. manual.
The MAC leading edge is located 769 mm (30.27") forward of the main wheel
center line. It's length is 1747 mm (68.78").
The MW center is the primary reference point. It is not convenient to use as
the DATUM point for W&B which can be at the reference or at any point
established from it.
I use 125" forward of the MW center line as the DATUM. That keeps all
moments positive and greatly simplifies the math.
With that DATUM the LE of the MAC is at + 94.73" (125-30.27)
The forward limit (17% of MAC or 11.69") is at + 106.4" with the landing
gear DOWN
The aft limit ( 24.1% MAC or 16.57") is at + 111.3" " "
" " UP
With the gear UP the CG moves aft by 0.48".
As noted you can use any datum point but you MUST determine the MAC L/E
point from that datum.
The aircraft must be level (canopy rails). Should be levelled by jacking
NOT by deflating the nose oleo. That changes the MW to NW dimension which
you need for calculation. That dimension is given in Fig. 1.3 as 2233 mm
(87.9")
Use a clean floor, chalk line, masking tape and plumb bob, etc. Transfer MW
C/L to the aircraft C/L on the floor and establish DATUM from there.
Transfer cg of all load items to the floor for accurate measurement.
Cheers;
Walt
mgdimarco
Posted: Sun Dec 28, 2008 5:23 pm Post subject: Re: CJ6A: stations for CG calculation |
My understanding is making real progress. Thanks for the definition of MAC, but I was looking for a value and the best I could determine was 68.8 which is right in line with the 68.78 answer.
Is the 94.7 LE of MAC the same as the datum of 70" forward of the firewall?
Anyone see the Pilot station as being closer to 104" than 114.3" from that datum?
Thanks for the confirmation of the oil tank at 48" on the 70" datum.
How about the "cargo" compartment. Would you use the battery location or just aft of it as the center?
In case anyone is interested, what started this was my head scratching as to why I could not but a 240# pilot and a 280# co-pilot in a 2412# airplane with only 140# of gas and 25# of oil. I kept getting a 116.7" C.G. (out of limit aft). It is not the case if the pilot station is at 104 (as I measure it) vs. 114.3 which seems to be the standard answer.
Thanks again in advance for the help and your replies.
China Blue
mgdimarco@yahoo.com
407-608-3290 |
Posted: Mon Dec 29, 2008 7:33 am Post subject: CJ6A: stations for CG calculation |
Michael,
Who wieghed your CJ? Who did the initial W/B calcualtions or are you just
using the information in the manual without actually putting the CJ on
scales? Also, please check the past conversations on the yak-list as you
will find that many people had the exact same W/B calculation sheet (same
weights for everything) down to the same signature in the xerox copy. That
led many here to re-do their W/B themselves or have their local shop do it.
If you haven't done it yourself or had a good shop do it, please go get it
done before your next flight.
If you are using the 94.7 inches in front of the Main Nose Wheel then the
pilot station I have is 101.81. I've seen as much as 9 inches difference
from the other cj pilots calculations. Now, you will also find if you put 2
different known weight pilots in the front seat and re-weigh the airplane,
you will find there will be difference in the pilot station due to the
weight difference of the "legs vs. body" between the two pilots. I took an
average of 3 people (170lbs, 210lbs, and 250lbs) in my caluclation. Rather
than just a measurement off the seat pan.
I don't believe (but can not confirm because I didn't measure) the inner
firewall station being 70" It sounds wrong.
Walt using 125 MWcenter, what do you have as the firewall station?
Using the 94.7" forward of the MW Center as the DATUM, the oil station
becomes 47.81
Using the 94.7" forward of the MW Center as the DATUM you get the following
stations depending on the length of your baggage compartment:
Avionics bay 161.28
Battery Box 178.19
ADF Electronics Tray 200.19
Again, if the CJ W/B is still a xerox copy of someone else's information,
you haven't watched the shop do the W/B from scratch, then please have it
re-done before you fly.
I'll forward the spreadsheet I did in case you are interested. However it
is only good if you weigh your airplane and input the 3 wheel weights and
initial measurements.
Version 3 of the sheet will be coming out in the next few weeks as I've
found out I didn't put a "DATUM" location explaination in the sheet. Some
may want that. If there is anyone out there that would like to see changes
to the sheet, please let me know before Feb 1.
DaBear
 Download |
| Filename: |
CJ_WB.xls |
38.5 KB |
| Downloaded: |
602 Time(s) |
mgdimarco
Posted: Mon Dec 29, 2008 6:56 pm Post subject: Re: CJ6A: stations for CG calculation |
This latest reply from Mr. Dabear has really muddied the waters.
When I say 70" Datum, I'm referring to what many are using as datum to be 70" forward of the vertical firewall. And yes the airplane was put on scales but the stations were from the commonly publicized 70" datum.
Examining your spreadsheet it is great for dynamic calculations, but the numbers/stations are way different from the "standard" I've been finding and not consistently different. Stations vary from 4" to over 10" from what I've been seeing. What you quote as the C.G. range also deviates significantly from everything I've seen so far.
So it is back to the drawing board for finding a consistent answer/standard. Oh the joys of experimental aircraft.
China Blue
mgdimarco@yahoo.com
407-608-3290 |
Posted: Mon Dec 29, 2008 7:13 pm Post subject: CJ6A: stations for CG calculation |
Randy & Mike;
I use a DATUM point of 125" forward of the manufacturers specified reference
point which is the MAIN wheel C/L.
All measurements are taken from the DATUM. For weight and balance purposes
the DATUM is located at STATION "0"
The figure 94.7" is not a datum, it is the station at which the leading edge
of the MAC is located.
That information is necessary ONLY to translate %MAC fore and aft limits
into hard dimensions
relative to the DATUM. Beyond that it is meaningless and irrelevant.
| Quote: | From the above DATUM I get the following;
Oil (est. cg) -- 47"
Pilot " -- 101.5"
Pass. " -- 150.5"
The "standard" man in the "standard" aircraft seat has his CG located at his
belly button. Hmmm-- that was the 165 lb standard man of many years
ago-----??????
Walt
