Dennis Johnson
Posted: Sun Dec 28, 2008 1:14 pm Post subject: Twisted Wires vs. Parallel |
We often see instructions to twist the positive and negative wires together to reduce noise problems. Instructions from B&C for their voltage regulator even specified the number of twists per inch.
But I'm wondering about the physics. From studying the 'Connection, it seems that paralleling the positive and negative wires tightly together would have the same effect as twisting them together. Is twisting the wires together recommended because it is a convenient way to keep the wires in close contact? Or is there something about the nature of the electromagnetic fields that makes twisting more effective?
Dennis
Legacy, 220 hours, mostly twisted positive and negative wires
brucebell74(at)sbcglobal. Guest
Posted: Sun Dec 28, 2008 2:12 pm Post subject: Twisted Wires vs. Parallel |
Hi All,
Years ago I replaced the windshield on my A35 Bonanza and found the wires to the Mag compass light twisted. This was done by the beech factory. Must be something to it!
Regards, Bruce Bell RV-4, N23BB, B&C Alternator and starter. All wiring to Aeroelectric Specs. No smoke!
DO NOT ARCHIVE!
CamLight
Posted: Sun Dec 28, 2008 2:41 pm Post subject: Re: Twisted Wires vs. Parallel |
Twisting reduces the wiring's susceptibility to interference due to the way it can cancel out certain external signals by reducing the wire's loop area (which reduces its degree of coupling to the interference). It also reduces crosstalk between nearby pairs of wire, but you need different twist rates for each pair to minimize coupling between them.
What I'm not sure of is the difference in effectiveness between pairs carrying single-ended signals (signal and ground) vs. differential signals (signal+ and signal-. used in telecomm and computer equipment).
_________________ John M.
Owner
CamLight Systems |
Posted: Sun Dec 28, 2008 4:06 pm Post subject: Twisted Wires vs. Parallel |
| Quote: | We often see instructions to twist the positive and negative wires together to reduce noise problems. Instructions from B&C for their voltage regulator even specified the number of twists per inch.
But I'm wondering about the physics. From studying the 'Connection, it seems that paralleling the positive and negative wires tightly together would have the same effect as twisting them together. Is twisting the wires together recommended because it is a convenient way to keep the wires in close contact? Or is there something about the nature of the electromagnetic fields that makes twisting more effective? |
A single conductor in relatively "free" space has some
behaviors of an antenna. I.e, it can radiate as well
as gather some portion of any electro-magnetic energy
in the vicinity. When electrons move relative to some
local point one can measure both an electric (electro-static)
force as well as a magnetic (electro-magnetic) force
as a result of that motion.
For example, a beam of electrons shot from the rear
of a cathode ray tube toward a screen can be deflected
or pointed because we can exploit EITHER the electro-static
or electro-magnetic properties of a moving stream of electrons.
It matters not whether those electrons move through a
conductor or through a vacuum. In a CRT television display
http://aeroelectric.com/Pictures/Misc/Electro-Magnetic_Deflection.jpg
electro-magnets on the neck of the tube were used to
control direction of the electron beam to produce spots
of light over the surface of the screen. In an oscilloscope,
electro-static deflection . . . .
http://aeroelectric.com/Pictures/Misc/Electro-Static_Deflection.jpg
. . . was preferred for its much higher frequency response.
Not only can electron streams be magnetically and
statically influenced as described above, they exert
their own, similar influences.
Suppose we start with a circular loop of wire say 10'
in diameter. This is an excellent example of a loop
antenna with an ability to efficiently radiate or
intercept energy at some frequency.
Now, let's squash the loop in one dimension. As
it moves toward an elliptical shape, the AREA of the
loop goes down and the radiation/reception efficiency
goes down. The obvious end point happens when the
area approaches zero and the circle becomes a parallel
pair of wires.
It's intuitively obvious that electrons flowing in one
wire are exactly balanced by opposite direction flow
in the opposite wire thus cancelling their individual
electro-magnetic and electro-static effects . . . mostly.
At higher frequencies it can be shown that parallel
lines do not exactly cancel mutual magnetic effects
because of the non-zero distance between their centers.
Here it becomes valuable to twist the two conductors
such that what ever leakage exists perpendicular
to the conductors tends to be washed out by the reverse
polarity of effects longitudinally displaced 1/2 twist
away.
Another very effective technique is to use shielded
wire. Use the center conductor for the outbound electron
flow and the shield for the inbound flow. Here the two
fields ARE centered on each other and cancel each other
exactly.
In the case of the compass light wire, the goal is to
null the magnetic field around a wire that MUST be
positioned in close proximity to the system most
vulnerable to interference from variable and stray
magnetic fields.
Some manufacturers twisted their outbound and return
wires. Others ran the wire up a small i.d. copper
tube to make inbound/outbound paths. Similarly,
shielded wire would be equally effective in this
regard.
Twisting the B&C Alternator wires was done at my
suggestion back when plastic and glass canard
pushers were king. The effects of poorly managed
inbound/outbound conductor pairs had some profound
effects on compass as well as audio systems. But
again, this practice IS NOT generally recommended
for ALL inbound/outbound pairs in an airplane.
Like my oft repeated admonition for "follow the
manufacturer's instructions" for shielding practices,
the same advice applies to things like twisting for
PM alternator installations in plastic airplanes
and compass lights. Twisting makes a wire bundle
more bulky and more $time$ consuming to fabricate
and install.
Bob . . . [quote][b]
Posted: Sun Dec 28, 2008 4:08 pm Post subject: Twisted Wires vs. Parallel |
At 04:41 PM 12/28/2008, you wrote:
Paralleled or twisted conductors get you benefit
only when they carry equal magnitude and opposite
polarity signals. This is why RS232 single-ended
data was quickly replaced by RS422 twisted pairs
under shields for the greatest noise immunity.
( -Thomas Paine 1776- )
simon(at)synchdes.com Guest
Posted: Sun Dec 28, 2008 7:19 pm Post subject: Twisted Wires vs. Parallel |
Dennis,
There is no difference electrically between two wires that are kept at the same distance in parallel and two wires that are twisted together to stay parallel. The reason they are twisted together is that it is the simplest way to keep them in parallel while the cable (a combination of wires, shields, insulation, etc.) bends and distorts.
When an RS-422 transmitter generates a signal, it has two circuits that drive the twisted wire pair. One circuit sources current, while the other circuit sinks current. When a differential twist wire pair carries two currents from the transmitter to the receiver, they travel from the source driver to the load (a termination resistor next to the receiver), then back to the current sink. Along each wire, the current generates an electromagnetic field defined by the right hand rule, where the direction of the field is per the direction of the hand’s fingers when the thumb is pointing toward the direction of current flow. Since the current in one wire is traveling opposite the current in the other wire, the fields oppose each other and ideally cancel each other out. They also ideally cause no noise to be radiated.
Perhaps the greatest benefit of RS-422 and differential signaling is immunity from external noise in the receiver. RS-422 receivers are built to reject “common-mode noise, which is noise that is of the same amplitude on both the + and – terminals of the receiver. This is where the twisted wire pair comes in. It connects to the receiver’s + and – terminals and brings in both the real signal and common-mode noise. While the twisted-wire pair is shielded, some noise will leak in, but the electromagnetic and electrostatic fields will cut across wires at the same amplitude, because the wires are so close together. Thus, the noise’s amplitude will appear at the receiver’s + and – terminals equally and will be rejected by the receiver, since it is designed to reject common-mode noise. As an example, the AM26LV32 is a commonly used differential line 3.3V receiver. It has a common mode input voltage range from -0.3 to 5.5V and will reject any voltage that appears on both terminals in this range. The voltages on its terminals must have a delta of greater than 0.2V for it to change its outputs. You probably have to be involved in the measurement of real world signals and problems to appreciate just how good the AM26LV32 works to reject common-mode noise. One of the things that I haven’t mentioned is that the termination resistor not only serves to terminate the twisted wire pair’s characteristic impedance but also provides a low impedance to prevent electrostatic and electromagnetic fields from developing high voltages in twisted wire pairs.
So to reiterate, there is nothing magical about twisted wire pairs other than they keep the wires in close proximity to each other and that’s it. Everything else I said above is just fluff!
Simon Ramirez
Copyright 2008
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Dennis Johnson
Sent: Sunday, December 28, 2008 12:29 PM
Subject: Twisted Wires vs. Parallel
Dennis
| Quote: | | http://www.matronics.com/contribution | 01234567890123
CamLight
Posted: Sun Dec 28, 2008 11:33 pm Post subject: Re: Twisted Wires vs. Parallel |
| simon(at)synchdes.com wrote: | | There is no difference electrically between two wires that are kept at the same distance in parallel and two wires that are twisted together to stay parallel. The reason they are twisted together is that it is the simplest way to keep them in parallel while the cable (a combination of wires, shields, insulation, etc.) bends and distorts. |
But don't pairs in untwisted pair cabling suffer from more crosstalk and susceptibility to interference than in twisted-pair cabling? And, IIRC, can't you do a longer run with twisted-pair than with untwisted-pair cable?
Owner
CamLight Systems |
raymondj(at)frontiernet.n Guest
Posted: Mon Dec 29, 2008 12:11 am Post subject: Twisted Wires vs. Parallel |
I think this paragraph from Bob N. earlier this week bears on this
discussion.
away.
Raymond Julian
Kettle River, MN
"Hope for the best,
but prepare for the worst."
tiethoff
Posted: Mon Dec 29, 2008 3:41 am Post subject: Twisted Wires vs. Parallel |
When wiring a tube amplifier it is common practice to twist the filament
lines to the tubes. Reason is that they are AC fed with a relative high
amperages (6,3 volt and 2 or 3 amp). The rest of the wiring is or signal or
DC. When the filament lines are NOT twisted they introduce humm (50 or 60
Hz) in the system. Since in an aircraftsystem there is no AC feed (except
the output of the alternator field tot the regulator) the only usance is to
keep the lines together.
Sent: Monday, December 29, 2008 9:09 AM
To: <aeroelectric-list(at)matronics.com>
Subject: Re: Twisted Wires vs. Parallel
<raymondj(at)frontiernet.net>
discussion.
away.
Raymond Julian
Kettle River, MN
"Hope for the best,
sglynn(at)us.ibm.com Guest
Posted: Mon Dec 29, 2008 9:33 am Post subject: Twisted Wires vs. Parallel |
Please how do I remove this email from receiving informative notes like the ones below?
thanks
Steven Lynn
Global Business Services
IBM Americas
Cell: 425-280-4404
Fax: 360-851-2211
[img]cid:1__=07BBFFBDDFF3B99D8f9e8a93df938(at)us.ibm.com[/img]"raymondj" <raymondj(at)frontiernet.net>
[img]cid:3__=07BBFFBDDFF3B99D8f9e8a93df938(at)us.ibm.com[/img]
To
<aeroelectric-list(at)matronics.com> [img]cid:3__=07BBFFBDDFF3B99D8f9e8a93df938(at)us.ibm.com[/img]
cc
Subject
Re: Twisted Wires vs. Parallel [img]cid:3__=07BBFFBDDFF3B99D8f9e8a93df938(at)us.ibm.com[/img][img]cid:3__=07BBFFBDDFF3B99D8f9e8a93df938(at)us.ibm.com[/img]
--> AeroElectric-List message posted by: "raymondj" <raymondj(at)frontiernet.net>
discussion.
away.
Raymond Julian
Kettle River, MN
"Hope for the best,
105 Bytes |
15893 Time(s) |
1.23 KB |
15891 Time(s) |
45 Bytes |
15892 Time(s) |
Posted: Mon Dec 29, 2008 6:04 pm Post subject: Twisted Wires vs. Parallel |
Yes and yes, John. Untwisted pair cables suffer from more crosstalk and are
more susceptible to interference because during their run, they tend to be
farther apart in places than their twisted pair counterparts. Per my
earlier post, when an electromagnetic or electrostatic field crosses their
path and induces a current or voltage into them, it will be a different in
each wire because they are at different relative distances from the source
wire, which is probably running parallel but not necessarily. Then the
common-mode receiver will not be able to reject this noise as effectively as
if the noise at its two terminals were more "equal."
Also, if a differential transmitter is generating + and - currents through
the two non-twisted wires, they will not cancel each other out as
effectively as their twisted wire counterparts, because they will be farther
apart in places, and their electromagnetic fields will not be mutually
inductively coupled into each other as well along the wires' runs.
Furthermore, it is easier to maintain characteristic impedances more
accurately when the wires are twisted together and their distances apart are
more accurately maintained. By providing a termination resistor at the
receiving end of the twisted wire pair, reflections are more carefully
controlled, if not cancelled. For this reason and for the reasons cited
above, longer runs are possible with twisted wire pairs than with untwisted
wire pairs.
BTW, the same theory that applies to keeping the distances equal between
wires in twisted wire pairs also is used in printed circuit boards to
propagate signals along traces. There the traces are geometrically
controlled so that their widths and distances from each other and from other
traces, ground and power planes are maintained, as well as the separation
material, to do a much better job than wires in cables, especially in
Gigabit applications.
Simon Ramirez
Copyright 2008
