Fuselage side stringers
jlfernan
PostPosted: Sun Dec 28, 2008 12:49 pm    Post subject: Fuselage side stringers Reply with quote
Can someone post a photo of how the side stringers are done at the forward end by the doors. In the drawings first it looks like they are tucked in between the frame tubes, then it appears they just bond to the door frame and are outside the fuselage tubes. I'm really confused. Sometimes what seems simple takes the longest.
Jorge Fernandez
Supersport
Fuselage/Forward Controls
http://websites.expercraft.com/jlfernan/
kitfox7(at)verizon.net
PostPosted: Mon Dec 29, 2008 1:10 pm    Post subject: Fuselage side stringers Reply with quote
Jorge, Pictures are not super but hopefully give you the idea I cut them to fit up in between the tube and stuck up against the inner side of the door frame. You will want to bend the door frame to have a smooth rounded transition to stringer. I drilled a small hole for a small rivet through the frame and into stringer then epoxied and riveted. Make sure door frame corners are bent smooth as it transition to the fabric all around.
George
original sport model / painting
Sent: Sunday, December 28, 2008 12:49:54 PM
Subject: Fuselage side stringers
--> Kitfox-List message posted by: "jlfernan" <jlfernan(at)bellsouth.net (jlfernan(at)bellsouth.net)>
Jorge Fernandez
Supersport
<A
 Filesize:  74.94 KB
 Viewed:  547 Time(s)
 Filesize:  77.79 KB
 Viewed:  565 Time(s)
