Guy Buchanan
Posted: Fri Dec 26, 2008 7:59 am Post subject: [!! SPAM] Main Jets on 582 |
At 08:25 PM 12/25/2008, you wrote:
| Quote: | Question 2) When I remove the lower bowl what parts will drop out? 2
floats, fuel stabilizer, float arm? Can I just them replace the 165
jets with the 160 jets while the carb is still on the aircraft? Will
I likely have to tweak the carbs? This looks like a 1 minute job.
Any potential problems/issues?
Jack,
I can't answer your first question, (yes I know it will lean
the engine, but how much?) but I can definitely say you can swap
mains on the engine. The only loose parts are the bowl, two floats,
and the little cylindrical filter over the jet housing. The only
fiddly thing is that filter which you want to make sure gets on
straight and doesn't get crushed. Not a big problem, just a little
fiddly. (Obviously you want to make sure you've got a good bowl
gasket before you put it back on.)
Guy Buchanan
San Diego, CA
K-IV/1200 w/ 582 C-box & Warp 3 blade
100% and flying thanks mostly to Bob Ducar
Deceased K-IV 1200
A glider pilot too. |
