Lynn Matteson
Posted: Tue Dec 23, 2008 2:26 pm Post subject: Skis - Solve the "Wide or Narrow" problem...partly off topi |
The second part of this response is OFF TOPIC, so bail out after the
ski part, if you wish....
Randy, I am SO glad that you posted this picture....on more than one
level (no pun intended...because the skis LOOK like there are two
different levels on the bottoms), and the two levels that I'd like to
address are the skis, of course, and the propellor. These are the
same skis that I photographed at Osh this year...the Wipaire Air
Glides. I did not get down to the floor level (there's that word
again) to inspect the bottoms, but I'm guessing that the bottoms are
pretty flat, that is, I don't think they are "stepped" like the photo
makes them appear. I think it's an optical illusion because those
skis are the hydraulically operated wheel skis, and the outer
"bottom" is shorter than the inner bottom. Throw in a little curve to
the bottoms, and you have a perfect illusion of a two tiered ski
bottom. Now I may be full of crap...it's happened before....but I
*think* this is what's going on here. I hope somebody has seen these
skis up close and can report exactly what the bottoms are shaped like.
My second point is the propellor...and Noel will love this....I wish,
Randy, you hadn't cropped the top off so much, because you can see
both prop stripes in the picture, yet we don't even see the center of
the spinner. Both prop blades are lower than below center. How is
this possible? (and do you care?) It is NOT a three-bladed prop. You
would know that if you saw the whole advertisement (it's and ad for
the Aviat Husky). If you look at the whole picture, it looks like the
prop is bent downwards, like a drooping mustache. This is another
case of optical illusion, caused by shooting the picture with a slow
shutter speed (or a high engine speed) and a horizontal focal plane
shutter. What happens is the narrow slit that lets light into the
camera passes the right side of the prop which we'll say is at the 4
o'clock position when the slit passes it, and by the time it crosses
the film plane (or the digital screen whatever digital cameras do)
and gets to the opposite side of the propellor, the prop has rotated
to a different position (this side of the prop would have been at the
10 o'clock position when the right side was at 4 o'clock of course)
and the image is burned onto the film/digital screen, and appears as
though the prop is distorted, bent, whatever. I've found this image
fascinating ever since I first saw it. To see the whole image go to
http://www.aircraftowneronline.com/45/index.cfm
This image tells a lie, unlike the old saying, "the camera never
lies" : )
Sorry to get off in left field, Guy and Mike, and others, but this
stuff interests me...and Noel. We'll take it off line if anybody
wants to yak about it, or has other ideas about this picture.
Lynn Matteson
Jabiru 2200, #2062, 596+ hrs
Sensenich 62x46
flying again after rebuild, and new Electroair direct-fire ignition
system;
also building a new pair of snow skis
On Dec 23, 2008, at 1:35 PM, Randy Daughenbaugh wrote:
Here is one solution from Wipaire.
Leonard says you need wide skis for floatation in deep powder. The
problem
is that you get more friction with wide skis so they are not so
good under
warm, packed conditions. The Wipaire skis are wide and narrow.
Look at the picture, I think it will be obvious.
Thanks to Deke for the encouragement and to Lynn for the 1 lb per
sq inch
concept and some good pictures and to Leonard and others who have
added
enlightenment. Good discussion!
Randy - Series 5/7 912S
Looking for a matched pair of snow boards.... My son suggested the
ski
rental places at the end of the season.
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
akflyer
Posted: Tue Dec 23, 2008 3:27 pm Post subject: Re: Skis - Solve the |
Lynn,
I will try and get you pics of the ski's tomorrow, I think they have a few of them out at the airport.
You are thinking way too much on the shape of the bottoms and how they actuate. It is much simpler, unless I am way off in left field ( I spend alot of time there these days) and you lost me on what you were trying to describe.
_________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
Float Flyr
Posted: Tue Dec 23, 2008 5:17 pm Post subject: Skis - Solve the "Wide or Narrow" problem...partly off topi |
My only answer to this is Lynn is spot on and I spent over twenty years as
the biggest liar I know with a camera. Even today I have to be careful when
taking pictures to illustrate something It can be too easy to make the
picture show something that isn't there.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Float Flyr
Posted: Tue Dec 23, 2008 5:32 pm Post subject: Skis - Solve the "Wide or Narrow" problem...partly off topi |
I just had another look at that picture and something comes to mind. The
step up and the wheels are on the outboard part of the skis. That would put
quite a twist on the skis on hard pack snow. Also the wheels would have to
drop down further to allow the inboard part of the skis to lift off the
runway... If I was going to try to design a stepped ski, I'm not, I would
have the low part of the step under the wheel so there would be any undue
twisting of the ski on hard snow and I would have the wheel protrude through
the low step so it wouldn't have to penetrate so far. Doing that would mean
that I would have to put the wide step part of the ski outboard of the
wheels to stop the skis from tripping in a turn. Outboard would also give
you something to step on in all that deep powder.
Noel
Kitfox III-A
Lynn Matteson
Posted: Tue Dec 23, 2008 6:02 pm Post subject: Skis - Solve the "Wide or Narrow" problem...partly off topi |
There is a very famous picture of an old race car that was taken as
the car went by. The cameraman panned with the car and he was using a
vertical-shutter camera. As he panned with the race car...using a
slightly faster or slower pan speed as compared to the car....a
telephone pole in the background slants one way while the rear tire
on the car goes oval shaped, and is slanted the other way...very
unusual.
Lynn Matteson
Sensenich 62x46
system;
On Dec 23, 2008, at 8:16 PM, Noel Loveys wrote:
years as
careful when
the
Noel
N369LM |
Lynn Matteson
Posted: Tue Dec 23, 2008 6:52 pm Post subject: Skis - Solve the "Wide or Narrow" problem...partly off topi |
Noel-
I don't think it IS a step at all...see my other post for how to make
a paper shape and I think you'll agree that the "step" MIGHT be an
optical illusion. Let me know what you think after making the "paper
ski."
Lynn Matteson
Sensenich 62x46
system;
On Dec 23, 2008, at 8:31 PM, Noel Loveys wrote:
mind. The
would put
have to
off the
I would
undue
protrude through
would mean
also give
Noel
N369LM |
Float Flyr
Posted: Wed Dec 24, 2008 10:54 am Post subject: Skis - Solve the "Wide or Narrow" problem...partly off topi |
Lynn all this talk of photography is like getting a kick in the duff. So aI went out ant ook a few "snaps" of my skis The very first one has a perspective that makes the axel look tilted, its not. Thge reverse inserts may give you a few ideas.
Picture 1. These skis are no doubt foam cored as they are quite stiff and weigh a lot less than the wheel and tire they replace.
Picture 2. This is the picture I mentioned with the perspective shift on the axel.
Picture 3. This angle shows the axel is straight and it also shows the two thin Teflon plastic runners on the bottom of the ski. Notice no whear bars as the skis are not to be used on bare pavement.
Picture 4.Ski right side up reversing insert upside down.
Picture 5.Reversing insert in place on ski. Insert is held in p[lace by a cmall bungee that goes through the I screw and around the axel. ( retainer is not in palce.)
Picture 6.
Rear view of the ski with the reversing insert in place
Picture 7. This angle shows why the reversing inserts should be removed before forward taxiing let alone flight.
Picture 8. Insert in place taken bottom up from the rear.
All these pictures were almost 2M in size I crop0ped and reduced them for E-mail
What I tried to hide is except for a small drift there really isn’t that much snow around here... Certainly not enough to think about landing in bogs on skis. No sign of ice this month.. I have an ocean of water outside my door.
Re the length of the skis Longer will get you on top of the snow faster, as there is less frontal area to plough per sq inch of loading area... but they will also help keep you straight... this is great until you want to turn. Wider skis will give more lift on the snow but with the wide frontal area will be harder to get to lift you to the top of the snow. Wider skis won’t hold your plane as straight as longer skis.. It’s all a matter of compromise.
When I was in high school I used to ski on a set of head 215 downhill racing skis. Speed and stability were no problem...
Turning was! Today the average ski is a lot shorter ability to do fast turns is increased but some of the stability especially in powder snow is gone.
Sorry if the whole e-mail is a bit on the large size for dialup I think it’s less than ½ MB.
Three guesses how I like to fly ( the first two don’t count)
Merry Christmas
Noel Loveys
Campbellton, NL, Canada
CDN AME intern, PP-Rec
C-FINB, Kitfox III-A
912 almost installed
Aerocet 1100 floats
[url=noelloveys(at)yahoo.ca]noelloveys(at)yahoo.ca[/url]
7.29 KB |
6287 Time(s) |
16.77 KB |
379 Time(s) |
22.26 KB |
372 Time(s) |
25.17 KB |
390 Time(s) |
8.9 KB |
353 Time(s) |
21.55 KB |
374 Time(s) |
19.46 KB |
336 Time(s) |
28.43 KB |
368 Time(s) |
20.63 KB |
372 Time(s) |
Kitfox III-A
Float Flyr
Posted: Wed Dec 24, 2008 11:02 am Post subject: Skis - Solve the "Wide or Narrow" problem...partly off topi |
I agree I think it is an optical illusion probably caused by the plane being
close to clean bright snow on the ground and there being more light on the
outside of the skis. Look real close and you can just make out the line of
the "stepped" area of each ski. Look at that line and the step disappears.
Noel
Kitfox III-A
Lynn Matteson
Posted: Wed Dec 24, 2008 1:07 pm Post subject: Skis - Solve the "Wide or Narrow" problem...partly off topi |
Are you sure the axle mount is not tilted, Noel? I have an author's
write-up for mounting Federal skis A-1500A through A-2000A, and in it
is the mention:
"How many ski fliers using Federal skis know that there is a right
and a left ski? I was always under the impression that the skis were
interchangeable from side to side. This is definitely not true!"
It goes on to say (and this is written on a drawing from Federal
Instructions):
"Inspect your ski pedestals carefully to determine the left and right
ski. The high side of the pedestal cross tube is always placed on the
inside."
In looking at the drawings of the Federal skis, Noel, there is
definitely a high and a low side, just like your skis appear to have.
I'm not saying that yours do, but it might be worth looking at again.
After all, there might be some compensation for camber built into
your skis....Federal seems to have done that in the ski that these
instructions pertain to. Another caption reads:
"To compensate for the camber of the landing gear, Federal Skis are
made Left and Right. The high side of the pedestal cross tube must be
placed on the inside of the gear."
If your axle aren't tilted, it appears that the ski was built so that
a tilted axle insert could be done.
Noel: I really like the reversing inserts! That's a neat idea.
Definitely want those puppies off, when you go forward!
The whole email came into me at 170KB, Noel, and thanks for shooting
them.
There was just a knock on my door and it was the UPS guy with all my
new ski material...chrome-moly, cables, shock cord, thimbles,
shackles, etc. Even got a book on operating a plane on floats and
skis. Man, I ordered that stuff (Aircraft Spruce) on Monday, and it's
here already...man, Santa Claus is a helluva guy! YEEEE-HAWWWW!
Lynn Matteson
Sensenich 62x46
system;
On Dec 24, 2008, at 1:53 PM, Noel Loveys wrote:
| Quote: | Lynn all this talk of photography is like getting a kick in the
shift on the axel.
Picture 6.
them for E-mail
Merry Christmas
Noel Loveys
N369LM |
infow(at)mts.net Guest
Posted: Thu Dec 25, 2008 11:24 am Post subject: Skis - Solve the "Wide or Narrow" problem...partly off topi |
You are right Lynn...
There is a left and a right ski. We used to do that when we were building skis for our RC models. The pedestal was always higher on the inside and canted the ski up about 10 degrees on the outside edge. In the enclosed photos from my 15 lb Beaver the skis are 3" wide and 14" long. I used 1/8" plywood and sanded to nothing on the outside edge of the pedestal. Also used a 1/8" x 1/8" spruce spine on the bottom for directional control. My tail ski was 3" long and 1-1/2" wide with the 1/8 x 1/8 spine also...
View showing the left and right pedestal as viewed from the front...
Rear horizontal level view of the left ski with the outside of the pedestal 1/8 plywood sanded down to zero...
Hope these photos are clear enough...
R.D.(Ron) Leclerc
CH701 Plans(Scrap) Builder #7-6699
Porsche Power Geared Redrive
Winnipeg, MB Canada
infow(at)mts.net
12/25/2008 1:03:34 PM
This E-Mail scanned with AVG Anti-Virus Ver: 7.5!
--> Kitfox-List message posted by: Lynn Matteson
author's write-up for mounting Federal skis A-1500A through A-
2000A, and in it is the mention:
right and a left ski? I was always under the impression that the
skis were interchangeable from side to side. This is definitely
not true!" It goes on to say (and this is written on a drawing
from Federal Instructions):
right ski. The high side of the pedestal cross tube is always
placed on the inside."
have. I'm not saying that yours do, but it might be worth looking
at again. After all, there might be some compensation for camber
built into your skis....Federal seems to have done that in the
ski that these instructions pertain to. Another caption reads:
are made Left and Right. The high side of the pedestal cross tube
must be placed on the inside of the gear."
that a tilted axle insert could be done.
shooting them.
my new ski material...chrome-moly, cables, shock cord, thimbles,
it's here already...man, Santa Claus is a helluva guy! YEEEE-
HAWWWW!
Lynn Matteson
Sensenich 62x46
ignition system; also building a new pair of snow skis
33.3 KB |
356 Time(s) |
30.47 KB |
354 Time(s) |
28.95 KB |
375 Time(s) |
Jimz
Posted: Thu Dec 25, 2008 12:02 pm Post subject: Skis - Solve the "Wide or Narrow" problem...partly off topi |
If your Federal skis don't have the hole in the pedestal at an angle then
they are made for an Ercoupe. I have seen several airplanes with 2 left or 2
right skis on them. Also left and rights put on backwards. On Federals the
tag is on the low or outside side of the ski pedestal. I have a set of the
Federal 1400's on my Champ. They are shorter and wider than the old 1500's.
I have had both and like the short wide ones better.
Series 5, 0-200 under construction.
Lake Elmo MN.
Lynn Matteson
Posted: Thu Dec 25, 2008 1:10 pm Post subject: Skis - Solve the "Wide or Narrow" problem...partly off topi |
Thanks, for the photos, Ron, absolutely clear....brings back the days
of flying RC across the road on the lake when it froze over. I can
still see my Astro Hog (on skis) banking left and auguring in, as it
either got out of range, or batteries failed...RIP, ol' Hog....man,
that was a fun airplane.
Lynn Matteson
Sensenich 62x46
system;
On Dec 25, 2008, at 2:24 PM, R.D.(Ron) Leclerc wrote:
| Quote: | You are right Lynn...
R.D.(Ron) Leclerc
Winnipeg, MB Canada
infow(at)mts.net
N369LM |
Lynn Matteson
Posted: Thu Dec 25, 2008 1:15 pm Post subject: Skis - Solve the "Wide or Narrow" problem...partly off topi |
Interesting...thanks for the input, "Zim". This is good stuff to
know...I wonder why the Federal people didn't mark the skis left and
right. I had a Fed 1500 at home here and I cleaned off the data plate
(which was at the rear of the ski) and could not determine any L or R
designation. Maybe I didn't know what I was looking for....OR they
were for a 'coupe, like you said. ....no, these were slanted, so that
can't be.
Lynn Matteson
Sensenich 62x46
system;
On Dec 25, 2008, at 3:01 PM, Zimmermans wrote:
angle then they are made for an Ercoupe. I have seen several
airplanes with 2 left or 2 right skis on them. Also left and rights
put on backwards. On Federals the tag is on the low or outside side
of the ski pedestal. I have a set of the Federal 1400's on my
Champ. They are shorter and wider than the old 1500's. I have had
Lake Elmo MN.
N369LM |
