Engine Cooling
Goto page 1, 2  Next
BobbyPaulk(at)comcast.net
PostPosted: Thu Dec 18, 2008 6:47 am    Post subject: Engine Cooling Reply with quote
List,
i have the 601 XL with 3300 Jabiru & original fiberglass ram air ducts. i have cut and modified the ram air ducts, added little dams and even increased the size on one side to compare with the other. my back two cylinders are still running 335 - 345 at cruise power settings. at max power 5 & 6 hit 356 at a 600' climb from near sea level. the other four cyl. are 300 or under. my question is - has anyone used the old style Lyc. or Cont. baffeling that has worked for a hundred years and got better CHT's on Cyl. 5 & 6.
i am thinking of trying the Sonex type of baffles. anybody got a clue.
bobby
70 hrs and still fixin stuff
rpf(at)wi.rr.com
PostPosted: Thu Dec 18, 2008 1:21 pm    Post subject: Engine Cooling Reply with quote
Bobby,
Did you epoxy a little deflector above the rear cylinders (actually above
the rear and middle cylinders) like Jabiru USA advises? I have the same
setup as you and all my cylinders run under 300 degrees. Even when I flew
out west to visit my brother with temperatures approaching 100 degrees.
Randy
601xl, Jab 3300, 235hours
amyvega2005(at)earthlink.
PostPosted: Fri Dec 19, 2008 7:21 am    Post subject: Engine Cooling Reply with quote
sounds likre the baffles over the back cylinders are not pushing enough air through into the cilinder vents. the deflection peice should go from the top of the duct to block off all air from flowing over the top of the cilinder but down through the cooling vents. use some metal and fit to cut so there is no room hardly for air to gow over but only through the cilinder cooling vents.
Or your temperature sensor is off.
Juan
DaveG601XL
PostPosted: Fri Dec 19, 2008 10:38 am    Post subject: Re: Engine Cooling Reply with quote
Bobby,
I am in the same boat as you. I have played with my baffles some, but still get warm temperatures in the back cylinders. Within limits, sure, but it would be better to have a more even distribution. #1-#4 are in the 280's to 300's F and the back ones see 350's F.
If you find the holy grail, let me know. I will play with this some more next spring and summer.
Good luck,
David Gallagher
Cincinnati, OH area
Brady
PostPosted: Fri Dec 19, 2008 10:46 am    Post subject: Re: Engine Cooling Reply with quote
Bobby,
Be sure not to over look the exit.
All the intake in the world won't do you any good if it has nowhere to go.
Try to "suck" the cooling through.
I have seen studies that say the intake is far less important than the exhaust side of the cooling system.
Also be sure you oil cooler is getting fresh air.
the oil cooler is at least as important because it is an integral part of the whole cooling picture.
Just food for thought.
Good luck.
Brady McCormick
Poulsbo, WA
www.magnificentmachine.com
jaybannist(at)cs.com
PostPosted: Fri Dec 19, 2008 10:56 am    Post subject: Engine Cooling Reply with quote
I can't remember where I read it, but the prevailing thought was that the cooling air outlet area needs to be 2 or 3 times the inlet area.
Jay in Dallas
dbrown(at)avecc.com
PostPosted: Fri Dec 19, 2008 12:42 pm    Post subject: Engine Cooling Reply with quote
I had the same problem and also tinkered with the baffles. However, Jabiru on their web site shows how to extend the bottom of the cowl depending on the extent of your problem. I riveted a .025 aluminum strip, one inch extension on lip of the cowl. Problem solved.
David N601EX
tjs22t(at)verizon.net
PostPosted: Fri Dec 19, 2008 1:21 pm    Post subject: Engine Cooling Reply with quote
Bobby,
Aside from what's has been said about the baffles between the cylinders AND the deflectors in the RamDucts just ahead of cylinders 5 and 6; keep in mind that the lower the pressure in the bottom portion of the cowl the greater the airflow down through the heads. To do this make sure that the front of the air intakes to the ducts through the cowling have NO (or as little as possible) air leaking under cylinders 1 and 2 and thus into the bottom of the cowl (pics attached). Also, the air coming into the oil cooler through its duct/intake should ONLY go through the oil cooler. Any air leaking around the the edges of the intake greatly, greatly defeats your low pressure area in the lower cowl. The difference in pressure between the top and bottom cowling segments is as important as total exit area at the rear of the bottom cowl lip.
tailwinds jeff HDS/3300 (no CHTs over 285F)
 Filesize:  40.5 KB
 Viewed:  560 Time(s)
 Filesize:  42.27 KB
 Viewed:  587 Time(s)
pete(at)usjabiru.com
PostPosted: Fri Dec 19, 2008 2:13 pm    Post subject: Engine Cooling Reply with quote
Attached is the procedure for installing cooling ducts from the Jabiru manual available on the Jabiru Australian web site. We do block off the air from going in the bottom cowl but use a vertical air dam instead of the horizontal pieces that Jeff used.
Jabiru makes the dam from fiberglass but there is no reason that scrap aluminum sheet if Zenith builders don’t want to mess with the fiberglass.
Pete
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of THOMAS SMALL
Sent: Friday, December 19, 2008 4:43 PM
To: zenith-list; BobbyPaulk(at)comcast.net
Subject: Re: Engine Cooling
Bobby,
Cooling_Duct_Installation.pdf
 Filename:  Cooling_Duct_Installation.pdf
 Filesize:  393.26 KB
 Downloaded:  752 Time(s)
dbrown(at)avecc.com
PostPosted: Fri Dec 19, 2008 2:50 pm    Post subject: Engine Cooling Reply with quote
Here is the one I was referring to.
Jabiru Service Bulletin JSB 016
http://www.jabiru.net.au/Service%20Bulletins/Engine%20files/Engine%20Coo
ling%20JSB016-1.pdf
hills(at)sunflower.com
PostPosted: Fri Dec 19, 2008 3:44 pm    Post subject: Engine Cooling Reply with quote
Don’t forget, the air picks up heat and expands after entering the cooling intake, hence the exhaust hole in the cowling must be larger than the cooling intake hole.
Roger
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of jaybannist(at)cs.com
Sent: Friday, December 19, 2008 12:55 PM
Subject: Re: Re: Engine Cooling
Jay in Dallas
-----Original Message-----
Sent: Fri, 19 Dec 2008 12:46 pm
--> Zenith-List message posted by: "Brady" <brady(at)magnificentmachine.com (brady(at)magnificentmachine.com)>
Bobby,
Good luck.
Brady McCormick
Poulsbo, WA
size=2 width="100%" align=center>
Email message sent from CompuServe - visit us today at http://www.cs.com
Afterfxllc(at)aol.com
PostPosted: Fri Dec 19, 2008 10:09 pm    Post subject: Engine Cooling Reply with quote
Brady
With all due respect, how many aircraft have you built? You are starting to be the WW of the Zenith list. I think you are a smart guy and like what you are trying to do but wouldn't it be better to have built at least 1 airplane before you hand out answers to others problems? Having worked on a Jab that overheats it is a pain in the ass engine when it comes to cooling. Jab will tell you they don't have a problem but I have seen too many posts about overheating to believe that.
BTW if the intake is small where is it going to "Suck" the air from? The Jab uses small deflectors inside the baffles and if they are too big or small the rear cylinder will overheat.
Jeff
Bobby,
Good luck.
One site keeps you connected to all your email: AOL Mail, Gmail, and Yahoo Mail. Try it now.
PostPosted: Sat Dec 20, 2008 5:53 am    Post subject: Engine Cooling Reply with quote
Jeff;
It is always better to have built “one airplane” before advising folks on their airplane problems, or for that matter, 10 airplanes. But skills in cutting metal and driving rivets has little to do with intellectual skills such as analyzing studies and applying knowledge to abstract problems such as thermal conduction (that’s what engineers do).
Take it easy on Brady, he is on the right track and just trying to help (no good deed goes unpunished !!!!)
Roger
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Afterfxllc(at)aol.com
Sent: Saturday, December 20, 2008 12:08 AM
Brady
Jeff
Bobby,
Good luck.
PostPosted: Sat Dec 20, 2008 6:44 am    Post subject: Engine Cooling Reply with quote
Roger,
You are right to a point but there is no better teacher than experience. I didn't want to sound harsh with my comment to Brady but after reading it again it was just that. I am working on ram air ducts for the 601 and 650 to fit our new cowling and while it looks like it should work in theory will it work in the air?
Jeff;
Roger
 Filesize:  17.19 KB
 Viewed:  548 Time(s)
 Filesize:  10.02 KB
 Viewed:  556 Time(s)
 Filesize:  18.14 KB
 Viewed:  557 Time(s)
 Filesize:  19.49 KB
 Viewed:  524 Time(s)
 Filesize:  9.69 KB
 Viewed:  543 Time(s)
bryanmmartin
PostPosted: Sat Dec 20, 2008 11:44 am    Post subject: Engine Cooling Reply with quote
If the heated air can't get out of the cowling, it doesn't matter how
well designed the inlets and baffling are. In the ideal cooling
design, the outlet area should be about 1 1/2 times the inlet area. In
any case, the outlet must be at a lower pressure than the inlet.
Putting a lip projecting down into the airstream ahead of the outlet
will often greatly improve the effectiveness of the cooling. The
turbulence caused by the lip creates a low pressure area at the outlet
that improves airflow.
On Dec 20, 2008, at 9:42 AM, Afterfxllc(at)aol.com wrote:
Roger,
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
Bryan Martin
do not archive.
PostPosted: Sun Dec 21, 2008 3:17 pm    Post subject: Engine Cooling Reply with quote
all,
many thanks to Jeff for the photos and logic to help solve the high temps on the rear cylinders. also to Randy who has the same problem. i had tried adding an 1 1/2" skirt to the bottom of the cowl to no avail. i have also tried large deflectors in the ram air ducts. i also trimmed them 1/8" at a time until i wound up with small deflectors. the oil cooler is sealed tightly as is the ram air ducts to the cowl openings. i will keep experimenting to find the right combination.
thanks to all who offered help. i will post the findings when you or i solve the problem.
thanks again
bobby
70.8 hrs.
601 XL Jab. 3300
planes_by_ken(at)bellsout
PostPosted: Tue Dec 30, 2008 10:33 am    Post subject: Engine Cooling Reply with quote
Better than ram air is a defuser. If you look at modern versions of older designs the cooling air inlet area is now about 30% of what they were. The air path forms a divergent duct. By Bernoulli's principle the air slows down and pressure goes up. Manufactures look for a pressure drop from top to the bottom of the engine. One plane I have worked on needed a 6" of water pressure difference. Some aircraft use an augmenter exhaust to lower the pressure in the lower cowl. This uses the exhaust flow to create a venturi effect. The images are of a Diamond DA-40 with a 180HP Lycoming. The air inlets are about 6" in diameter. They feed into a plenum defuser. Air must be prevented from getting past the baffle seals. Also air will try to leak around the propshaft.
Teaching turbine engines at the moment,
Ken Lilja
[img]cid:part1.00060403.04080208(at)bellsouth.net[/img][img]cid:part2.06040207.02050603(at)bellsouth.net[/img][img]cid:part3.05010801.04090100(at)bellsouth.net[/img][img]cid:part4.02090707.09060908(at)bellsouth.net[/img]
Afterfxllc(at)aol.com (Afterfxllc(at)aol.com) wrote:
Brady
Jeff
Bobby,
Good luck.
 Filesize:  104.28 KB
 Viewed:  485 Time(s)
 Filesize:  183.08 KB
 Viewed:  495 Time(s)
 Filesize:  188.18 KB
 Viewed:  526 Time(s)
 Filesize:  172.78 KB
 Viewed:  517 Time(s)
ideaz1(at)sbcglobal.net
PostPosted: Thu Jan 01, 2009 10:48 am    Post subject: Engine Cooling Reply with quote
Would you please explain what a defuser consists of and what you mean by a divergent duct. I am interested in learning more on this topic.
If you would rather email me direct to avoid having your body parts chewed off by those on the list who insist on being righter than anyone else, please do.
Dirk Zahtilla ideaz1(at)sbcglobal.net (ideaz1(at)sbcglobal.net)
Interem Airport Manager, CXP
Carson City, Nv.
bryanmmartin
PostPosted: Thu Jan 01, 2009 11:28 am    Post subject: Engine Cooling Reply with quote
A definition From the web: "A diffuser is a passage so shaped (usually
in the form of a divergent duct) that it will change the
characteristics of a fluid flow from a certain pressure and velocity
at the inlet to a lower velocity and higher pressure at the outlet.
Generally, the diffusion must be carried out in a well-streamlined
passage having smooth interior surfaces, and sides not diverging at so
great an angle as to cause the fluid to leave the sides of the
diffuser. By reducing the velocity through increasing the cross-
sectional area of flow, the pressure may be built up as the velocity
head is diminished. Diffusers are used to conserve energy by
efficiently converting velocity head into pressure."
A divergent duct is simply a duct whose cross sectional area increases
in the down stream direction. Because slower moving air remains in
contact with the cooling fins for a longer period of time, it can soak
up more heat from the engine to carry away. You still have to make
sure the cooling exit duct is larger than the inlet duct and is
located in a area of lower pressure.
topic.
Bryan Martin
N61BM, CH 601 XL,
Bryan Martin
do not archive.
psm(at)att.net
PostPosted: Thu Jan 01, 2009 11:48 am    Post subject: Engine Cooling Reply with quote
Hi Dirk,
There is a really great magazine article describing this new technology. Title: Cooling Drag. Page 106. EAA Sport Aviation. December 2007. Author Christopher Zavatson.
I strongly recommend this article. I have read it a few times and keep it handy for reference.
Good luck,
Paul
XL getting close
At 10:45 AM 1/1/2009, you wrote:
[quote]Would you please explain what a defuser consists of and what you mean by a divergent duct. I am interested in learning more on this topic.
Carson City, Nv.
[/b]
Goto page 1, 2  Next
Page 1 of 2
