rparigor(at)SUFFOLK.LIB.N Guest
Posted: Wed Dec 17, 2008 8:51 am Post subject: Red start button and fuse. |
I have a red start button form Steinair (with one heavy bezel):
http://www.steinair.com/switches.htm
I like the switch. The tag on it says 120V AC 3A res.
I want to use it on a Rotax 914. I didn't find any info in the Rotax
documentation I have as to recommended rating of switch that should be
used.
Europa does recommend having a 5 amp fuse. Rotax shows a 2 amp fuse being
used. And Z-16 shows a 7 amp fuse being used.
I measured the resistance of the relay coil and it is 4.7 ohms. So if
there was a full 14 volts going to it it would draw a tad under 3 amps.
Often I see switches with a lesser rating for DC and inductive loads.
Practical questions:
Is the red button switch OK to use?
What circuit breaker rating should I use?
Thx. in advance.
Ron Parigoris
Gilles.Thesee(at)ac-greno Guest
Posted: Wed Dec 17, 2008 8:58 am Post subject: Red start button and fuse. |
rparigor(at)SUFFOLK.LIB.NY.US a écrit :
| Quote: | I measured the resistance of the relay coil and it is 4.7 ohms. So if
Ron,
I've been using a 5 amp fuse for the starter relay on our Rotax 914
project. Added a diode across the coil terminals.
Best regards,
Gilles
http://contrails.free.fr
Posted: Wed Dec 17, 2008 9:25 am Post subject: Red start button and fuse. |
At 10:46 AM 12/17/2008, you wrote:
used.
Fuses or breakers in ANYBODY's diagrams should be
evaluated against realities of the accessories
being installed.
Don't know of any batteries that put out 14 volts to crank
engines . . . but I suppose you could be jump starting
from your car with the engine running. But good for you.
Your deduction of current draw is the all importan first
step.
| Quote: | Often I see switches with a lesser rating for DC and inductive loads.
Once you add the diode across the coil, it is no longer
inductive from the perspective of switch life issues.
| Quote: | Practical questions:
Yes.
| Quote: | What circuit breaker rating should I use?
What ever you like that is equal to or greater than
3 amps and commensurate with the size of wire used.
22AWG and 5A is fine. 20AWG and 5A is fine too.
( -Thomas Paine 1776- )
stein(at)steinair.com Guest
Posted: Wed Dec 17, 2008 10:16 am Post subject: Red start button and fuse. |
Bob is of course right...and it sounds eerily similar to what I said on the
phone 30 minutes earlier!
Stein
[quote]--
marcausman
Posted: Thu Dec 18, 2008 8:20 am Post subject: Re: Red start button and fuse. |
OK, who is pushing Stein's buttons? ha ha Sorry, couldn't resist.
Merry Christmas and best wishes.
| stein(at)steinair.com wrote: | Bob is of course right...and it sounds eerily similar to what I said on the phone 30 minutes earlier!
Stein
_________________ Marc Ausman
http://www.verticalpower.com "Move up to a modern electrical system"
RV-7 IO-390 Flying |
