dvanlanen
Posted: Fri Dec 12, 2008 8:03 am Post subject: Grounding Of Fuel Senders |
I am installing VDO fuel senders in the metal fuel tanks of my all-metal kit aircraft. These senders do not have a ground lug, and the sender, by design, is not isolated from the fuel tank because the mounting screws are inserted into a metal mounting ring which is in metal-to-metal contact with the inside of the fuel tank. The construction manual calls for grounding the sender to the airframe using a wire from the airframe to a ring terminal under one of the mounting screws. My concern with this approach is that I might inadvertently introduce a “ground loop” into the system by grounding in this fashion. I would prefer to isolate the sender from the airframe and run a return wire to the universal ground buss on the firewall, but because of the design of the sender this would be difficult to do. Has anyone else dealt with installation of these senders, and if so, can you offer me any advice?
Dave Van Lanen [quote][b]
Posted: Fri Dec 12, 2008 8:46 am Post subject: Grounding Of Fuel Senders |
I added these wires to my RV6A (metal tanks) to ground the senders to the main spar which has a bonding strap to the field of tabs ground bus.
Works fine so far - no adverse effects - will be flying first flight in a couple of weeks - just got my airworthiness cert.
Ralph Capen
RV6A N822AR 0 hrs
ftyoder(at)yoderbuilt.com Guest
Posted: Fri Dec 12, 2008 10:18 am Post subject: Grounding Of Fuel Senders |
Congratulations on the FAA Cert....... Enjoy that first flight!!!
Posted: Fri Dec 12, 2008 7:06 pm Post subject: Grounding Of Fuel Senders |
At 10:02 AM 12/12/2008, you wrote:
| Quote: | | I am installing VDO fuel senders in the metal fuel tanks of my all-metal kit aircraft. These senders do not have a ground lug, and the sender, by design, is not isolated from the fuel tank because the mounting screws are inserted into a metal mounting ring which is in metal-to-metal contact with the inside of the fuel tank. The construction manual calls for grounding the sender to the airframe using a wire from the airframe to a ring terminal under one of the mounting screws. My concern with this approach is that I might inadvertently introduce a “ground loop” into the system by grounding in this fashion. I would prefer to isolate the sender from the airframe and run a return wire to the universal ground buss on the firewall, but because of the design of the sender this would be difficult to do. Has anyone else dealt with installation of these senders, and if so, can you offer me any advice? |
Metal tanks in a metal airplane will provide sufficient
ground for these senders to work as advertised. Adding
the wire as directed in the instructions will not hurt
anything either. Go ahead and install the requested wire
( -Thomas Paine 1776- )
dvanlanen
Posted: Sat Dec 13, 2008 8:44 am Post subject: Grounding Of Fuel Senders |
Bob,
Can you explain why I don’t need to worry about a ground loop in this situation, (reference the explanation of ground loops on p. 5-6 of the AeroElectric manual)?
Dave
Date: Dec 12, 2008
From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com>
Subject: Re: Grounding Of Fuel Senders
| Quote: | I am installing VDO fuel senders in the metal fuel tanks of my
the sender, by design, is not isolated ………
Bob . . . [quote][b]
Posted: Sat Dec 13, 2008 12:52 pm Post subject: Grounding Of Fuel Senders |
At 10:38 AM 12/13/2008, you wrote:
| Quote: | Bob,
Dave |
Because the loop is small. The tank grounds to the
airframe through mounting straps and brackets and
with a resistance that is a tiny fraction that of
any piece of wire you might install. Yeah, technically
there's a "loop" but so tiny both in architecture and
in terms of antagonistic currents as to be insignificant.
