tc1917(at)bellsouth.net Guest
Posted: Fri Dec 12, 2008 4:43 am Post subject: 912 enrichers |
I may be misunderstanding what John H was saying but my 912 ul 80 hp does
not have enrichers in the carbs. They have full butterly chokes in them. I
know for sure because I looked in there. Butterfly type is way better than
the rubber based enricher valve. I used my enricher valve to save my butt
once. I had icing (I believe it was) and pulled the enricher lever and it
coffed and stumbled and lit it back up. It actually blew the ice off the
jet and away I went. Really sounded bad from the ground according to my
friend down there but I told him it sounded worse when a plane hits the
ground. I have had a recent chance to find out if the plunger style gas
unit works the same in an emergency on a challenger -- it does not keep the
engine running!!!!! Did a really great two point landing. Had to take the
nose wheel out to stop in time but thanks to the fragil nose wheel of a
challenger, it folded just as I thought it would and I stopped in plenty of
time. Limited damage. My Kolb would have stopped in plenty of time. Ted
Posted: Fri Dec 12, 2008 5:39 am Post subject: 912 enrichers |
| Quote: | not have enrichers in the carbs. They have full butterly chokes in them. I
Ted
Ted:
Check to see if your choke butterfly vavles are connected to your throttle cables.
The Bings on the 912 series engines use a rotary valve system for enrichener, rather than the plunger valve used by the two stroke Rotax. There are a couple o ring seals in them that need to be checked periodically. They could possibly leak if they go bad.
_________________ John Hauck
Titus, Alabama |
aslsa.rng(at)gmail.com Guest
Posted: Sat Dec 13, 2008 7:39 am Post subject: 912 enrichers |
Ted, I'm going to assume you have the stock Bing 64's on your 912 and you haven't hung a Holley double pumper on it.That butterfly you saw when you looked in the carb throat is NOT a choke, it's the throttle. In the 64 this sets the vacuum level in the carb which pulls the piston up and sets the mixture. Unlike the two stroke Bings, the throttle cable is NOT connected to the piston. In the 64 the piston is suspended from a diaphragm inside that big cover on top of the carb.
What may be confusing you is that the linkage on the throttle cable should be set up so that the throttle butterfly goes full open should the cable fail. The throttle cable pulls the butterfly closed, not open.
NOTE: this could be changed as the 64's on my HKS do not have this linkage setup. On the HKS the throttle is closed by the spring, just like it would be on a BMW motorcycle, but a 912 should have the aviation linkage that fails open.
Rick
On Fri, Dec 12, 2008 at 7:34 AM, <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)> wrote:
[quote]--> Kolb-List message posted by: <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)>
Ted
Ted:
