Sbennett3(at)aol.com Guest
Posted: Thu Dec 11, 2008 7:24 am Post subject: Cold weather starting |
I never try to start my 912 when temps are under 30 F. I'm sure I know the problem, When I take the air cleaner off and cup the opening of the carb it fires rt up. I have a sticky choke cable. I guess a couple quick squirts of the start fluid is easy and I don't have to remove the air cleaner. My hangar is not heated, It also doesn't have electricity so cold starting is my only option. I will get the choke cable replaced soon.
Steve Bennett 4/1200 912ul North Carolina.
In a message dated 12/11/2008 9:40:25 A.M. Eastern Standard Time, noelloveys(at)yahoo.ca writes:
His advice sounds more than reasonable... The very worst thing you can do to an engine is start it. That being true, when you do start it you want to make the start as smooth and easy as possible. It’s easy to remove metal form the inside of your engine... neigh on impossible to put it back!
Noel Loveys
Campbellton, NL, Canada
CDN AME intern, PP-Rec
C-FINB, Kitfox III-A
912 almost installed
Aerocet 1100 floats
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Randy Daughenbaugh
Sent: Wednesday, December 10, 2008 12:41 PM
Subject: Kitfox-List: Cold weather starting
At our local EAA chapter (37) meeting last night a local A&P said we really need to heat everything – not just heads or oil or cylinders but EVERYTHING! – when we fire up the engine in cold weather. He singled out the Rotax 900 series engines because of their very tight fit compared to Continentals or Lycomings. He said that even if you turn the engine over by hand at 10 F or lower temps, you will be scraping some metal off and starting the end of the engine.
I have never worried about this. If it is not windy, I fly without regard to the temperatures. Am I destroying my 912S by starting it cold?
Randy - flew yesterday in teens and low 20’s F – over Mount Rushmore
Series 5/7 912S Warpdrive taper tip | Quote: | | http://www.matronics.com/contribution | 0123456789012
Make your life easier with all your friendstin=new-dp&icid=aolcom40vanity&ncid=emlcntaolcom00000010">Try it now.
7.29 KB |
8281 Time(s) |
Float Flyr
Posted: Thu Dec 11, 2008 7:54 am Post subject: Cold weather starting |
<snip>
Light bulbs are too dangerous, IMHO, and too hard to manipulate from the
bottom of the cowl.
Lynn Matteson
You ain't just whistling Dixie to that!
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
peteohms
Posted: Thu Dec 11, 2008 8:43 am Post subject: Cold weather starting |
Yea Dick, and I've been thinking of getting skis so I can land on the sand at White Sands National Monument.
Pete
Hell Paso, TX
_________________ Pete
Leander, TX
Kitfox III, 912ul, Grove |
Lynn Matteson
Posted: Thu Dec 11, 2008 9:31 am Post subject: Cold weather starting |
You guys are killing me! I gotta go hang a prop on my plane in a 14°
hangar....and those are real degrees...F's, not those wimpy-ass C
things. : )
Lynn Matteson
Jabiru 2200, #2062, 593hrs
Sensenich 62x46
flying again after rebuild, and new Electroair direct-fire ignition
system;
also building a new pair of snow skis
On Dec 11, 2008, at 11:41 AM, Pete Christensen wrote:
[quote] Yea Dick, and I've been thinking of getting skis so I can land on
Pete
Hell Paso, TX
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
icubob(at)newnorth.net Guest
Posted: Thu Dec 11, 2008 10:31 am Post subject: cold weather starting |
so many ways to preheat. here is an angle i am looking into. devices are available that will turn on an electric appliance with a call to a landline phone. safe aviation preheat systems are available. fleet farm also carries 150 watt oil pan heaters similiar to the aviation stuff. use your imagination on this............ a phone call to your hangar turns on your preheat or a call turns it off. life would be perfect if a unit worked with a cell phone!
bob noffs
Lynn Matteson
Posted: Thu Dec 11, 2008 1:15 pm Post subject: cold weather starting |
....and a wrong number call to your hangar in the middle of the
night, cutting off your warming and thus delays your attempt at a new
worlds record for...(insert your own dream)
(this must be the silly season) please do not archive
Lynn Matteson
Sensenich 62x46
system;
On Dec 11, 2008, at 1:28 PM, bob noffs wrote:
| Quote: | so many ways to preheat. here is an angle i am looking into.
a cell phone!
bob noffs
N369LM |
gary.algate(at)sandvik.co Guest
Posted: Thu Dec 11, 2008 1:17 pm Post subject: Cold weather starting |
That's what it was called!
Gary Algate
SMC, Exploration
Office Phone: +61 8 8276 7655
This e-mail is confidential and it is intended only for the addressees. Any review, dissemination, distribution, or copying of this message by persons or entities other than the intended recipient is prohibited. If you have received this e-mail in error, kindly notify us immediately by telephone or e-mail and delete the message from your system. The sender does not accept liability for any errors or omissions in the contents of this message which may arise as a result of the e-mail transmission.
“This year, instead of sending you a Christmas card in the mail, we have made a contribution to [url=Arial]UNICEF Australia[/url]. We wish you a safe and happy Christmas".
Lynn Matteson <lynnmatt(at)jps.net>
Sent by: owner-kitfox-list-server(at)matronics.com
11/12/2008 10:13 PM
Please respond to
kitfox-list(at)matronics.com To
kitfox-list(at)matronics.com cc
Subject
Re: Cold weather starting
--> Kitfox-List message posted by: Lynn Matteson <lynnmatt(at)jps.net>
Sounds like flashing material for roof work.
Lynn Matteson
Sensenich 62x46
system;
On Dec 11, 2008, at 3:55 AM, gary.algate(at)sandvik.com wrote:
> I made my own Jim from some scrap aluminum - basically I made two x
> 4" tubes and riveted them to an aluminum enclosure which I just
> taped to the heater using aluminum duct tape.
> I used that really light aluminum that you buy in a roll from
> hardware stores
> Gary
patreilly43(at)hotmail.co Guest
Posted: Thu Dec 11, 2008 1:27 pm Post subject: Cold weather starting |
Lynn C The guy lives in NC. He thinks cold is 50 degrees F C and skis were invented to use on water.
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
| Quote: | From: lynnmatt(at)jps.net
Subject: Re: Cold weather starting
Date: Thu C 11 Dec 2008 06:43:30 -0500
Ok C Steve C bend over....I would think that starting fluid just gets
the engine started C without giving any warmth to the oil and the rest
of the engine. I'm sure that even the most greedy of the engine
dealers...no names C please...would suggest that you warm the engine
to allow for free oil flow and less scraping/friction/damage when it
does start. I'm thinking that if you NEED starting fluid C something
isn't right...too much friction C too much drag on the starter C
bringing the battery down C cold fuel C etc.
Lynn Matteson
Kitfox IV Speedster C taildragger
Jabiru 2200 C #2062 C 593hrs
Sensenich 62x46
flying again after rebuild C and new Electroair direct-fire ignition
system;
On Dec 10 C 2008 C at 9:52 PM C Sbennett3(at)aol.com wrote:
> My engine heater is a can of start fluid on those cold mornings...
> (30 to 35f) I've been spanked on this group before so have at it.
> Steve Bennett NC USA 4/1200 912ul
> In a message dated 12/10/2008 9:40:31 P.M. Eastern Standard Time C
> patreilly43(at)hotmail.com writes:
> Lynn C What is an "enclosure heater"?
> Pat Reilly
> Mod 3 582 Rebuild
> Rockford C IL
_=======
n85ae
Posted: Thu Dec 11, 2008 1:35 pm Post subject: Re: cold weather starting |
I have a Reiff pre-heat system on my engine as well, but prefer the
el-cheapo space heater system. It simply heats the entire engine and engine
compartment to a nice cozy temp quite easily.
Jeff
| icubob(at)newnorth.net wrote: | so many ways to preheat. here is an angle i am looking into. devices are available that will turn on an electric appliance with a call to a landline phone. safe aviation preheat systems are available. fleet farm also carries 150 watt oil pan heaters similiar to the aviation stuff. use your imagination on this............ a phone call to your hangar turns on your preheat or a call turns it off. life would be perfect if a unit worked with a cell phone!
Lynn Matteson
Posted: Thu Dec 11, 2008 2:08 pm Post subject: Cold weather starting |
Good 'un, Pat! (sorry 'bout that, Steve) : )
Now to keep it educational, here is a shot of my enclosure heater.
The only part that gets shoved up the.....I mean inserted into the
lower cowl, is the metal and fiberglass tape, not the wood. I had
just removed it from the engine and it was hot, so I laid it on he
wood. When I got there today, the oil temp was 104° F, and the heads
were 64° F. By the way, the exposed electrical studs never get near
anything metallic...I should insulate them somehow, but haven't
really looked into what I could use...maybe more of the fiberglass
tape. Or at least get pretty and put terminals on those bare wires.
Lynn Matteson
Jabiru 2200, #2062, 595+ hrs
Sensenich 62x46
system;
On Dec 11, 2008, at 4:27 PM, patrick reilly wrote:
| Quote: | Lynn, The guy lives in NC. He thinks cold is 50 degrees F, and skis
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
396.63 KB |
516 Time(s) |
N369LM |
Posted: Thu Dec 11, 2008 2:13 pm Post subject: Cold weather starting |
Hey Guys C Another good book is "Mavericks of the Sky". It is about the inception of U.S. Airmail.
Pat Reilly
Mod3 582 Rebuild
Rockford C IL
| Quote: | From: Patrick.Best(at)telus.com
Date: Thu C 11 Dec 2008 10:13:59 -0500
Subject: RE: Cold weather starting
--> Kitfox-List message posted by: Patrick Best <Patrick.Best(at)telus.com>
I would like to recommend using a Blow-Pot C like the northern bush-pilot pioneers!
For those of you who don't know what that is....
When a pilot was done flying for the day during the winter in northern Canada C the "flight engineer's" responsibility was to drain the oil from the engine into a large metal bucket and bring it indoors over night. The next morning C in temperatures as low as -60 F (yes C that's a real temp) C the engineer would shroud the engine C light the kersone blow-pot stove and heat the oil in the buckets for a couple of hours. Then it would be poured back into the engine for the flight.
I read it in this FASCINATING book. I would completely recommend it. It's about 1930's era Junkers with skis. Crashes and flying without reliable maps. Good pictures too.
The site says it's out of print C but there's probably many copies around still.
http://www.harbourpublishing.com/title/BentPropsBlowPots
&g=====
Posted: Thu Dec 11, 2008 2:32 pm Post subject: Cold weather starting |
Lynn C Thanks for the picture. I have a 582 greyhead watercooled and have installed a block heater in the hose below the pump inlet. Don't know how it will work yet. It is simple and cheap enough to try anyway.
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
Date: Thu C 11 Dec 2008 17:04:32 -0500
Good 'un C Pat! (sorry 'bout that C Steve) : )
Now to keep it educational C here is a shot of my enclosure heater.
lower cowl C is the metal and fiberglass tape C not the wood. I had
just removed it from the engine and it was hot C so I laid it on he
wood. When I got there today C the oil temp was 104° F C and the heads
were 64° F. By the way C the exposed electrical studs never get near
anything metallic...I should insulate them somehow C but haven't
Posted: Thu Dec 11, 2008 2:53 pm Post subject: Cold weather starting |
Pat, I didn't say 50 is cold... plus I have a heater in my plane. 40 is pushing it a bit... Oh ya, and I know about the water ski thing, but how about them go carts they put skis on the front of... Now that's innovation... Steve (no need for skis) Bennett NC guy...
In a message dated 12/11/2008 4:29:11 P.M. Eastern Standard Time, patreilly43(at)hotmail.com writes:
| Quote: | Lynn, The guy lives in NC. He thinks cold is 50 degrees F, and skis were invented to use on water.
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
Date: Thu, 11 Dec 2008 06:43:30 -0500
Ok, Steve, bend over....I would think that starting fluid just gets
the engine started, without giving any warmth to the oil and the rest
dealers...no names, please...would suggest that you warm the engine
does start. I'm thinking that if you NEED starting fluid, something
isn't right...too much friction, too much drag on the starter,
bringing the battery down, cold fuel, etc.
Lynn Matteson
Sensenich 62x46
system;
> In a message dated 12/10/2008 9:40:31 P.M. Eastern Standard Time,
> Lynn, What is an "enclosure heater"?
> Pat Reilly
> Mod 3 582 Rebuild
> Rockford, IL
_=======
://www.matronics.com/contribution">http://www.matronics.com/contribution
f="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronics.com/Navigator?Kitfox-List
.matronics.com/">http://forums.matronics.com
Make your life easier with all your friends, email, and favorite sites in ony&ncid=emlcntaolcom00000010">Try it now.
Posted: Thu Dec 11, 2008 4:35 pm Post subject: cold weather starting |
hi lynn,
i may be wrong but i would assume you key in some numbers to activate the
device, the same as you do to get your answering machine to play your
messages. i live about 45 minutes from the airport and at least warm oil
when i get there would be good for engine life. i do have a red dragon
propane preheater that worked fine on a lyc. but i know it didnt do much for
the oil temp.
one way or another i am leaning toward an electric preheat system for
next year.
bob noffs
Lynn Matteson
Posted: Thu Dec 11, 2008 6:22 pm Post subject: cold weather starting |
Oh yeah, like an extension number that (probably) no one else would
know about. Yeah, Bob, that makes perfect sense now. I live 4 miles
from my hangar, and I leave my heater on all the time, because I fly
a lot and I want it ready to go when the weather allows for it. I
think that cycling on and off leads to condensation buildup. My
system warms the whole engine and even the cowl (under the blanket),
so condensation cannot collect...at least so far that's been the
case. I haven't figured what it costs to run (200 watts x 5 hours=1
kilowatt hour=how much per KW hour? dunno) but this times 5 would be
about one day's run cost. If I could find my electric bill, I could
figure what I'm costing my hangar landlord, and maybe back off on the
24x7 usage of the heater.
I haven't tried any tests to determine if cycling the heater actually
causes condensation to appear, but maybe a 4 hr cycle would retain
enough heat between cycles to avoid moisture. If I had a recording
humidity gauge (gotta be a fancier word for that, but it's too late
at night for me to think clearly), maybe I could determine if this
was feasible.
Lynn Matteson
Sensenich 62x46
system;
On Dec 11, 2008, at 7:34 PM, bob noffs wrote:
hi lynn,
activate the device, the same as you do to get your answering
machine to play your messages. i live about 45 minutes from the
airport and at least warm oil when i get there would be good for
engine life. i do have a red dragon propane preheater that worked
fine on a lyc. but i know it didnt do much for the oil temp.
for next year.
bob noffs
N369LM |
Float Flyr
Posted: Thu Dec 11, 2008 7:56 pm Post subject: Cold weather starting |
Steve:
Remind me not to by one of your used engines..
Noel
Kitfox III-A
Float Flyr
Posted: Thu Dec 11, 2008 8:24 pm Post subject: cold weather starting |
What you propose is no problem. Simply have a computer answer the phone on
the third ring ... enter a four , five or six digit DTMF code form your
phone and your heater is turned on or off. You can use this set up to
unlock doors and turn off and on lights. The answer sounds like and in fact
is an answering machine so it will take messages for you too.
Noel
Kitfox III-A
Lynn Matteson
Posted: Fri Dec 12, 2008 6:42 am Post subject: cold weather starting |
And that solution would take care of the telemarketer problem, too, I
would think.
Lynn Matteson
Sensenich 62x46
system;
phone on
your
and in fact
Noel
N369LM |
Float Flyr
Posted: Fri Dec 12, 2008 7:17 am Post subject: Cold weather starting |
If you guys really want some fun just try to start an old Bell 47-G below
50F... Then when you get it going you have to keep the rpm up because there
is no flywheel... once the engine is nicely warmed up then you have to
engage the rotors without flooding, not only the engine but the closest
three counties..
Noel
Kitfox III-A
Posted: Fri Dec 12, 2008 12:18 pm Post subject: cold weather starting |
lynn,
a little more research on the condensation business seems to point to an engine that was run for only a short time and didnt get to operating temps before it was shut down. this leaves water in the engine as a product of combustion that didnt get a chance to be boiled off. now comes the constant preheat that puts the moisture that was in the oil in vapor form and then it condenses on the colder parts of the engine. i dont know if all this is true but keeping a preheat on an engine that was put away hot should not be a problem.
bob noffs
