JH's "Darned rat" vandal
undoctor
PostPosted: Wed Dec 10, 2008 8:55 am    Post subject: JH's "Darned rat" vandal Reply with quote
[b]Went over to Gantt International Airport anyhow. Decided to drag the strip
and smooth out the cow pies. While I was down by the hanger I checked out
my bird. Darned rat has been back in it while I was on my trip. He ate t
he right shoulder harness. Cut'em right off the bulkhead. Also got the ri
ght seatbelt. Looks like it went through a buzz saw. While he was at it,
he or she checked out a couple wires. Cut the 12vdc wires to my ANR headse
t and my Chillie Vest. That is all I could find damaged. Hopefully, he di
dn't get back in places and cut wires and hydraulic brake lines like he did
a couple years ago.
[/b]
John, gang,
I had an '88 BMW K100LT 2-wheeler which was beginning to run pretty nasty. On my ride though AK, I took a rock from a passing semi on the Dalton Hwy around Coldfoot which broke the grill on the air intake on the front of the scooter's fairing. I didn't see any harm, so, for years I never fixed it, until Nookers, my black lab/hound, chewed the intake trying to get at something.
When I removed that part of the fairing to have it re-glassed and painted, I found a massive field mouse's nest in my airbox! .I use my cycles year round, so apparently he either was going along for the ride daily, or waited till I returned home and parked it back in the shed to re-enter his "home."
Here's the Kolb part. I learned that if you sprinkle moth balls on the floor around any place the mice can access your vehicle, they won't go through the smell and your vehicle's safe. Of course the down side is enduring the smell of the moth balls. Without regard to the imminent risk of folks asking the age-old burning question, "Do you know how to smell moth balls?", this info could prevent a lot of mice from trespassing on a lot of Kolbs.
Dave Kulp
Bethlehem PA
FireFly 098
SAD PS Nookers died suddenly at 14 years old last Wednesday, leaving a huge hole in my life once occupied by a dear, dear friend!!
 Filesize:  117.85 KB
 Viewed:  526 Time(s)
cristalclear13
PostPosted: Wed Dec 10, 2008 1:13 pm    Post subject: Re: JH's Reply with quote
a couple years ago.
[/b]
John, gang,
John,
Does this mean the valerian didn't work or did the smell/effect wear off while you were roaming the countryside?
Cristal
Cristal Waters
Private Pilot Aug 2008
Rotax 2 stroke maintenance April 2009
grantr
PostPosted: Wed Dec 10, 2008 1:33 pm    Post subject: Re: JH's Reply with quote
Last year,
I had a similar situation where a rats or a few got under the hood of my truck and cut a few wires to the computer shorting it out. They had a massive amount of figs piles high on my intake cover. The truck was running a 6 cylinders barely and the ABS system failed.
I had to have the ABS and computer replace at a cost of $1200.
Shortly after this they got back in a cut my alternator wire twice. 1st time I had to be pulled 16 miles to a shop to have a new wire made since it was cut right at the connector.
2nd time i made it back home and the truck died in the yard. Wire was easy to fix this time.
This year I killed 9 mice in my attic. I have no Idea how they got there.
The cheap victor snap traps with peanut butter on them will kill them 99% of the time.
Moth balls don't work that well. They still get in my landlords vehicle despite him putting mothballs around the truck. He has to leave the hood open with mothballs on the engine to keep them out.
If you don't have pets, Timick (spelling?) a granular pesticide used by farmers will kill the rats almost instantly. It is however very toxic and potent in smell.
I keep my Kolb in a 8.5X 24 foot Haulmark car hauler. No rats can get it it!
You can alway install a cat in your hangar. They are pretty efficient rat killers if you don't over feed them.
Hope you get your bird back flying soon.
PostPosted: Wed Dec 10, 2008 2:53 pm    Post subject: JH's "Darned rat" vandal Reply with quote
John,
Cristal
Cristal:
Don't know. I probably should have dumped the whole bottle of valerian
capsules in the boom tube, sprinkled several boxes of moth balls around the
tailwheel, main wheels, and some inside.
Not a good feeling to open the door and see your airplane chewed up.
Especially the second time around. ;-(
I put out two big sticky pads for rats, some Decon rat poison, and a box of
moth balls in front of and below the boom tube inside the cockpit. Hope it
works before I have my seat belts and shoulder harnesses replaced.
mkIII - Slightly chewed on.
beauford
PostPosted: Wed Dec 10, 2008 4:01 pm    Post subject: JH's "Darned rat" vandal Reply with quote
Victor also makes an electronic rat assasination machine... they sell them
at
Home Depot and Lowes... is a black plastic box with what amounts to the
electronic
guts of a Taser built into it...runs on 4 xC cells... you smear a little
peanut butter
on the back wall... to reach the peanut butter the prospect has to step
across two
metal plates wired into the floor... the big 'ol capacitor then discharges
and blows his
(or her) little rat head off...
I don't have the rat size device...I bought the mouse size... the guy
wearing the black
hood selling these things said the rat item makes a satisfying crack like a
.22 short when it fires...
and if one hurries, the corpse is still smoking when one opens the top..
Given the fact that you have a score to settle with the varmits, might be
worth sitting around
one evening and reloading it a few times... also has a LED on top which
gives the status
of the batteries, warns of armed condition, and tell when there has been a
kill.
One could place it, or a couple of them, right in the floor of the Kolb...
bloodthirsty beauford
FF-076
Brandon, FL
PostPosted: Wed Dec 10, 2008 4:10 pm    Post subject: JH's "Darned rat" vandal Reply with quote
> Victor also makes an electronic rat assasination machine >
Beauford:
I like that idea.
Gonna got to Lowes tomorrow and see if I can find me one of them. Put it
right by the tailwheel. I am sure they are getting in the airplane via
tailwheel and tailboom.
JetPilot
PostPosted: Wed Dec 10, 2008 4:42 pm    Post subject: Re: JH's Reply with quote
I have one of those electronic mouse killers. I had a medium sized mouse that I was trying to kill, and put a camera by the trap. He went in, got zapped, jumped back out and never went near it again.
The electronic Rat Killer is a great idea, its just not strong enough to work all the time.
Kolb MK-III Xtra, 912-S
russ(at)rkiphoto.com
PostPosted: Wed Dec 10, 2008 5:26 pm    Post subject: JH's "Darned rat" vandal Reply with quote
List
FWIW - rats & mice W ILL get 'in' anywhere, no matter what you put up
as a barrier. Most often the tailwheel area. Electric zappers do
work, but get the biggest one you can. It would be fairly easy to
make one self-resetting; there was one like that a long time ago.
Shoved the dead ones over into a sealed & concealed container &
readied itself for the next one. Rats are smart-- if they see a dead
one they may stay away.
Rat/mouse urine is very corrosive to alum. Most expensive to repair
too.
Peanut butter is a good bait. But if you use a Havahart trap with a
1/2" wire mesh, mice will enter, trip it, eat the bait & then squeeze
out thru the 1/2"mesh.
I had a boa constrictor as a pet for years, NO mice/rats in the
house. But I realize that's not a solution for everyone.
Good luck.
PS Don't let them get near Viagra! -- no telling what would happen.
Beauford:
I like that idea.
Put it right by the tailwheel. I am sure they are getting in the
airplane via tailwheel and tailboom.
rlaird
PostPosted: Wed Dec 10, 2008 5:38 pm    Post subject: JH's "Darned rat" vandal Reply with quote
Ok, here's my solution... worked EVERY time.... Got a large
bucket... really large, and tall... made of plastic so the sides were
slippery... Bucket has to be big enough and deep enough for about at
least 8 inches of water, 8 inches between the water and the rim, and
slippery enough so a mouse/rat can't climb out.
I stuck a chair next to the bucket, filled the bucket half way with
water, put a 2x4 that went out over the bucket and then put a weight
on the 2x4 so it became, essentially a steady diving board.
Then I took a 6" x 6" piece of plywood, put it on the water, then put
on it a couple of bits of dry dog food... the really smelly kind.
The mice/rats would climb out on the diving board, drop down to the
plywood to get the dog food, the plywood would immediately tump over,
and the mouse/rat would swim to exhaustion and drown. Obviously,
making sure the mouse/rat can't climb back out is critical, as is
making sure the water level/plywood is far enough away so they -have-
to drop down to to get it.
Worked flawlessly, every time. I once got rid of a whole family that
way, one each day.
-- R
On Wed, Dec 10, 2008 at 7:25 PM, russ kinne <russ(at)rkiphoto.com> wrote:
List
FWIW - rats & mice W ILL get 'in' anywhere, no matter what you put up as a
barrier. Most often the tailwheel area. Electric zappers do work, but get
the biggest one you can. It would be fairly easy to make one
self-resetting; there was one like that a long time ago. Shoved the dead
ones over into a sealed & concealed container & readied itself for the next
one. Rats are smart-- if they see a dead one they may stay away.
Rat/mouse urine is very corrosive to alum. Most expensive to repair too.
Peanut butter is a good bait. But if you use a Havahart trap with a 1/2"
wire mesh, mice will enter, trip it, eat the bait & then squeeze out thru
the 1/2"mesh.
I had a boa constrictor as a pet for years, NO mice/rats in the house. But I
Good luck.
> Beauford:
> I like that idea.
> john h
> mkIII
Robert Laird
Houston, TX area
http://www.Texas-Flyer.com
Bill Vincent
PostPosted: Wed Dec 10, 2008 6:01 pm    Post subject: JH's "Darned rat" vandal Reply with quote
Hi Gang
When I used to have my old T-Bird I saw a mouse jump out of the tip of my wing while I was Taxing.
Since then I always put moth balls around my Firestar but I think the mice like to eat them.
A few years ago I had a Pine snake in my hangar which was good because I didn't see any mice around ... but...I was always afraid the snake would be coming out of the tail boom while I was flying; so I always checked the tail boom with a flashlight before I took off.
Someone on the List said to use Bounce strips to keep the mice away, I had them scattered around the plane and in the plane; not sure if they really worked.
Bill Vincent
Bill Vincent
Firestar II
Upper Peninsula of Michigan
ElleryWeld(at)aol.com
PostPosted: Wed Dec 10, 2008 7:51 pm    Post subject: JH's "Darned rat" vandal Reply with quote
That's funny, the mice don't even want to fly with you
    Surprised)
Ellery
In a message dated 12/10/2008 9:02:18 P.M. Eastern Standard Time, emailbill(at)chartermi.net writes:
Make your life easier with all your friends, email, and favorite sites in one plac=emlcntaolcom00000010">Try it now.
PostPosted: Thu Dec 11, 2008 7:36 am    Post subject: JH's "Darned rat" vandal Reply with quote
FWIW I never found Bounce strips much good as a mouse-deterrant. But they do prevent/eliminate musty odors in closed spaces. Whenever I go on  a new boat I put one in every drawer. Makes the boat smell much better, and the owner  his wife like it too. More pleasant all around.do not archive
On Dec 10, 2008, at 9:01 PM, Bill Vincent wrote:
[quote] Hi Gang
Bill Vincent
beauford
PostPosted: Thu Dec 11, 2008 7:39 am    Post subject: JH's "Darned rat" vandal Reply with quote
Brother Jet...
..with the smaller mouse box the body count in my attic stands at 2 so far
this week....not sure how many got away... or how my mice stack up against
your "medium" mouse. Data plates on mine say "mouse, field, brown, general
purpose" but there is no size given.... The mouse-size unit runs on AA
cells... the rat unit feels a lot heavier and uses C cells... I assume from
the weight that the capacitor in the rat unit has substantially more punch.
You might consider trying a small damp door-mat at the entrance of yours...
Believe that if I were faced with the major problem John has in that
barn-shed-hangar of his, I would definitely go for the bigger unit.
..even if the shock doesn't kill them outright, they will likely have
trouble remembering where his airplane is afterwards....
Now you have me wondering... This matter may require some bench testing with
the Bride's sissified cat to see how good this thing actually is... will
go look for the welding gloves... Report to follow.
curious beauford
FF-076
Brandon, FL
Do not Archive
PostPosted: Thu Dec 11, 2008 3:10 pm    Post subject: JH's "Darned rat" vandal Reply with quote
from
punch.
yours...
curious beauford
Bro Beau:
Went by Lowes on the way home from MGM. All they had was the little bitty
mouse zappers. Had they had the Rat Zappers, I would have gotten one or a
couple.
However, I did buy two big old rat traps at 1.97 ea. Gonna bait'em up with
a little peanut butter and see what I can catch.
I haven't had time to get back over to Gantt International Airport to see
how my glue traps have done. I also left them 4 trays of Decon to munch on
while I was gone. Too dark and too cold to set the traps tonight.
I might ought to tack a 1/16" cable to the rat traps in case I catch
something that is too big for them and decides to walk off with one on its
nose or paw.
I am gonna get'em.
Take care,
mkIII pilot and rat killer!!!
PostPosted: Thu Dec 11, 2008 3:52 pm    Post subject: JH's "Darned rat" vandal Reply with quote
Wiring the traps down is a good idea. If the rat itself doesn't bug
off, any prowling cat/dog/coyote/bobcat/whatever may well cart off
the trap & rat & you'd never know what had happened.
> assume from
> more punch.
> yours...
> curious beauford
Bro Beau:
little bitty mouse zappers. Had they had the Rat Zappers, I would
have gotten one or a couple.
up with a little peanut butter and see what I can catch.
to see how my glue traps have done. I also left them 4 trays of
Decon to munch on while I was gone. Too dark and too cold to set
the traps tonight.
catch something that is too big for them and decides to walk off
with one on its nose or paw.
I am gonna get'em.
Take care,
DAquaNut(at)aol.com
PostPosted: Thu Dec 11, 2008 6:22 pm    Post subject: JH's "Darned rat" vandal Reply with quote
In a message dated 12/11/2008 5:11:14 P.M. Central Standard Time, jhauck(at)elmore.rr.com writes:
John,
If that doesn't do it, try getting some corn kernels, like they feed deer. Take a 1/16 th inch drill bit and drill through about six kernels and wire them together on the rat trap trigger. It is hard for them to get it off without tripping the trap. Another option is to get some bird seed that has sunflower seed in it. Put a small amount into a piece of plastic window screen, making it into a little ball and wiring it onto the trap trigger. Another choice is to wire a peanut in its shell ,to the trigger If necessary you can modify the trigger to where it will trip easier. I have had rats lick all the Peanut butter off and not get caught!
Ed Diebel FF 062
Make your life easier with all your friends, email, and favorite sites in one ncid=emlcntaolcom00000010">Try it now.
PostPosted: Thu Dec 11, 2008 7:01 pm    Post subject: JH's "Darned rat" vandal Reply with quote
Thanks Ed D:
These Alabama rats are big and clumsey, I hope. They are field rats with teeth like bolt cutters.
I'll try peanut butter first. If they can get the peanut butter with out getting caught, I will try some of your suggestions. We will prevail.
[quote] If that doesn't do it, try getting some corn kernels, like they feed deer. Take a 1/16 th inch drill bit and drill through about six kernels and wire them together on the rat trap trigger. It is hard for them to get it off without tripping the trap.  Another option is to get some bird seed that has sunflower seed in it. Put a small amount into a piece of plastic window screen, making it into a little ball and wiring it onto the trap trigger. Another choice is to wire a peanut in its shell ,to the trigger If necessary you can modify  the trigger to where it will trip easier. I have had rats lick all the Peanut butter off and not get caught!
Ed Diebel FF 062
