Posted: Wed Nov 12, 2008 7:34 am Post subject: Polish, Paint OR not |
Hi Kevin,
After 2 years of flying bare aluminum, the paint on my 601HDS came to a
total of 14 lbs.
I did W&B before and right after painting with no exposed aluminum left
to polish.
I can also fully appreciate the prospective "joy" of polishing upside
down and around color trim paint.
Painting is a big chore, but decidedly worth it no matter what kind you use.
That's a 4 year perspective, twice a year, just spray off the dust and
wipe dry.
Bugs seem to come off paint much easier too with just a little cleaner.
Good luck,
K Dilks wrote:
After looking at all the nice shiny 601xl s on the web I have to ask .
Do you polish under the Fuzz and wings ? and how do you polish right up to the edge of a painted area?
How much does the paint weight on the outside on a decent paint job?
. Like the idea of less cost and weight too but the thought of having to grovel on the ground polishing under neath does not float my boat.
Kevin
Austria .............
ashontz
Posted: Tue Dec 09, 2008 12:48 pm Post subject: Re: Polish, Paint OR not |
Isn't there some sort of alodine solution you can put on the metal after it's polished that helps protect the aluminum? I thought that's what that slight yellow tinge was.
| jaybannist(at)cs.com wrote: | Raymond,
Thanks. I too was building a flying tool, not a hanger queen nor a beauty contestant. But I did want it to be a fun thing too, thus the military look.
No I have not experimented with wax nor a clear coat. If I begin to see signs of surface corrosion, I will certainly entertain one of those. But, here in North Texas, we don't have any salty sea air nor any influence from salting snowy roads.
I finished my wings and stored them outside, on a wooden rack covered with a tarp. When I brought them inside to do the painting, I found a lot of surface corrosion. It occurred mainly where the tarp touched the metal. It took the better part of a month to get rid of it. They probably would have fared better if I had left them uncovered. I think the corrosion formed when the tarp actually kept the contact area moist. Uncovered, the moisture would have mostly run off and the rest just evaporated.
Jay
ashontz
Posted: Tue Dec 09, 2008 12:54 pm Post subject: Re: Polish, Paint OR not |
I know aluminum boats in salt-water need zinc anodes and aluminum boats in freshwater need magnesium anodes. I'm guessing a plane near the sea would need a zinc anode. Might want to experiment with both types.
| raymondj(at)frontiernet.n wrote: | Interesting thought on the home base sacrificial anode. I may setup a trial
next spring if I get around to it. Hang just a piece of al on a string and
another one attached to a magnesium stake driven into the ground. Very
interesting!
Raymond Julian
Kettle River, MN
"Hope for the best,
but prepare for the worst."
