grjtucson
Posted: Fri Dec 05, 2008 5:14 pm Post subject: Z-11 Questions |
Hello Listers,
A few questions for my RV-7, Z-11 system, E-Mag/P-Mag.
1. Can I run the Main Bus feed from the Alternator side of the ANL60 Current Limiter? The wiring run would be slightly easier and there's a secondary reason...
2. If I can do #1, would that provide sufficient protection for the 8AWG feed line to the Main Bus? That feed has no protection in Z-11 and it seems like it should. I foresee little risk of that line shorting to ground, but the consequences would be significant.
3. If I can't do #1, can I / should I use a 12AWG fusible link to protect the Main Bus feed line?
4. My Battery Bus feed line will exceed 6". It's roughly the same run length as the Main Bus feed, something like 24". Can I / should I protect it with a fusible link? Same rationale as the Main Bus feed. It would be a 14AWG run (Battery bus is source for the E-Bus Alt Feed) with an 18AWG fusible link.
5. This is more FYI and for comment, but I'm wiring my E-Mag and P-Mag each the same way:
- E-Bus to 2A panel breaker to mag for power
- SPST switch and shielded P-lead for each mag
My thinking is that they should be wired identically and treated much the same as mags. Powered up on the E-Bus 'cuz they're important, the individual breakers will allow me to power down the P-Mag to test it, and finally the shielded P-leads allow me to switch to traditional mags if ever needed. It is far less complicated than many schemes I've seen and uses cheaper switches (albeit two pricey panel breakers). Any holes in my plan?
6. Finally, is there any problem with feeding those panel breakers through a fuse on the E-Bus? My only other panel breaker, the Field, will be fed through a fusible link from the Main Bus screw terminal.
Thanks in advance,
George Jenson
Tucson, AZ
_________________ George Jenson - http://www.georgejenson.com
Tucson, AZ - RV-7 Standard Build
Empennage Completed 1/06
Wings Completed 11/06
Fuselage in Progress |
Posted: Sat Dec 06, 2008 6:32 am Post subject: Z-11 Questions |
At 07:14 PM 12/5/2008, you wrote:
Hello Listers,
How about the system side of the ANL? The reason
the ANL would open is because of a fault in the
alternator or its feeder. This is an exceedingly
rare event but it would take down the whole system
if you feed from the alternator side.
| Quote: | 2. If I can do #1, would that provide sufficient protection for the
FAT wires in airplanes that feed large busses
and connect starters and batteries together do not
require protection. You won't find such protection
in any certified light aircraft. Here's an excerpt
from FAR23
http://www.aeroelectric.com/Reference_Docs/FAA/Part23_electrical_A.pdf
Check out paragraph 23.1357 . . .
| Quote: | 3. If I can't do #1, can I / should I use a 12AWG fusible link to
Not useful . . .
| Quote: | 4. My Battery Bus feed line will exceed 6". It's roughly the same
No, that 6" thing is a design goal. The world does
not spin down to a halt if it is longer. Treat this
feeder with the same concerns for design, installation,
and maintenance as your prop bolts. Satisfy yourself
that there is NO way this wire's functionality can
become compromised.
| Quote: | 5. This is more FYI and for comment, but I'm wiring my E-Mag and
| Quote: | - SPST switch and shielded P-lead for each mag
much the same as mags. E-Bus 'cuz their important, the individual
The switching arrangements shown in Z-11 for Emagair
products are consistent with their recommendations
and consideration of the effects of possible failure
modes. This is your airplane . . . if you have comfort
requirements that go beyond these recommendations, by
all means, address them.
| Quote: | 6. Finally, is there any problem with feeding those panel breakers
Breakers fed with like sized fuses will never operate.
The fuses are 10x or more faster than breakers. You might
as well use switches . . . which are already part of the
suggested design. If you have a desire to incorporate
breakers, then the battery bus fuses need to up-size to
30A devices and the feeder wire from bus to breaker
should up-size to 14AWG or so.
It's my recommendation that you wire the airplane as
suggested in Z-11. This architecture was developed
over 15 or so years of considerations for the uniqueness
of the OBAM aircraft community based on 40+ years
of experience in the TC aircraft world. Changes can and
should be made if you find the recommendations lacking in
some way for (1) minimizing weight, parts count and/or cost,
(2) operational convenience or (3) safety. In these
cases proposed changes should be evaluated by everyone as
a candidate for revising Z-11 as published.
But it's your airplane . . . your safest operational
mode requires that you need to fly it with comfort
and understanding.
grjtucson
Posted: Sun Dec 07, 2008 9:42 am Post subject: Re: Z-11 Questions |
I'll wire per Z-11 on the bus feeds, thanks for the lesson and illumination.
I am, however, going to wire per E-Mag Air on the mags. For the power feeds, E-Mag calls for a breaker for the E-Mag and a switch and breaker for the P-Mag, optionally combining the switch and breaker. I'm just going to use breakers for both, pulling the P-Mag's when I test it's generator. I prefer the simplicity of a SPST switch consistently used for both, and should I ever switch to standard mags, I just delete my panel breakers.
I will feed the breakers from the terminal of the E-bus, not through a fuse.
BTW, the present revision M of Z-13/8 has the P-Mag generator unable to be tested (open P-Lead and no power) short of powering down the Main bus. I'd think having the P-Mag get a 3 pos. switch as you had on Rev L would be superior. The P-Mag would then be Off-On-Bat and the E-Mag would be Off-Bat-On, and you could feed both from the Battery Bus.
Also, for what it's worth, E-Mag Air does call for 18AWG feeders and grounds, contrary to the Z diagrams.
Thanks for doing what you do
George
Posted: Sun Dec 07, 2008 9:58 am Post subject: Z-11 Questions |
At 11:42 AM 12/7/2008, you wrote:
Given that there are two ignition systems with a high
degree of reliability . . . either one of which runs
the engine just fine . . . Emagair told me that there
was very little to be gained by frequent testing of
the E-Mag's self supporting capabilities. They suggested
a couple of times a year. This is easy to do at the same
time you deliberately drop the main bus to do battery-only
endurance verifications or what-ever. The point is that
the system wired as shown CAN be tested by the pilot either
in pre-flight or during flight with the controls configured
as shown.
As shown, one achieves automatic load-shedding of the
E-mag during battery-only ops because IT IS fed from
the main bus.
| Quote: | Also, for what it's worth, E-Mag Air does call for 18AWG feeders and
Yeah, not necessary from the perspective of operating physics.
It's a mechanical robustness thing.
| Quote: | Thanks for doing what you do
My pleasure sir. I'm pleased that you receive good
value from the effort.
( -Thomas Paine 1776- )
