Posted: Fri Dec 05, 2008 8:32 am Post subject: Where to find closed-end lugs for Super-CCA cable |
At 01:24 PM 12/2/2008, you wrote:
| Quote: | | Where is the best place to buy lugs for Eric Jones' Super-CCA electric cable in #4 size? My partners wants a "closed end" type as suggested by Bob Nuckolls on one of his weekend seminars. It appears that Eric only sells the open end type. This would be a type which uses the "solder pellet" which you drop into the lug, then insert the wire and heat. |
Hmmm . . . I may have mentioned the closed-end devices as
being an alternative . . . but I don't think I spoke to
them being preferred. In fact, they're more difficult to
install using the "copper wedge and solder" technique
described in
http://www.aeroelectric.com/articles/big_term.pdf
The open-end structure lets you (1) drive wedges and
(2) observe the results of your skill in applying heat
and solder to achieve the desired result. Closed-end
devices are soldered blind and difficult to wedge.
