How to create epoxy threads
Mike Whisky
PostPosted: Fri Dec 05, 2008 2:08 am    Post subject: How to create epoxy threads Reply with quote
Hi,
I am using a composite cover inside of the doors to cover the lock and door handles mechanics.
I now face the issue that I need to have threads in between the door shelfs to screw the cover to the door.
Nutplates won't work since I do not have access. I read about rivnuts but I'd like to use epoxy and make the thread myself.
Any ideas? How did you do it?
Michael
RV-10 builder (flying)
#511
dlm46007(at)cox.net
PostPosted: Fri Dec 05, 2008 3:43 am    Post subject: How to create epoxy threads Reply with quote
Create a hard point. Use a small diameter stub of pipe. PVC? Fill with putty
(epoxy,fibers and cabosil). Lastly drill and tap.
dlm46007(at)cox.net
PostPosted: Fri Dec 05, 2008 3:44 am    Post subject: How to create epoxy threads Reply with quote
If dopr is thick enough already just drill and tap.
bhughes(at)qnsi.net
PostPosted: Fri Dec 05, 2008 5:00 am    Post subject: How to create epoxy threads Reply with quote
I am using aluminum rivnuts in several places to attach the Flightline
Interior panels. Easy to install, lightweight and non-locking so you can
continue to use the same screw after removal.
Bobby
40116
indigoonlatigo(at)msn.com
PostPosted: Fri Dec 05, 2008 7:12 am    Post subject: How to create epoxy threads Reply with quote
Hardwood dowels would work will too. Drill out a hole C cut dowel to length C glue in.
Not likely you will be removing the screws enough that the threads will wear with the screws.
[quote] From: dlm46007(at)cox.net
Subject: RE: How to create epoxy threads
Date: Fri C 5 Dec 2008 04:40:21 -0700
partner14
PostPosted: Fri Dec 05, 2008 8:38 am    Post subject: How to create epoxy threads Reply with quote
Can't understand why noone has suggested just floxing or micro-ballooning in an odd shaped piece of aluminum. The odd shape will keep it from spinning, and drilling and tapping is simple.
Don
--- On Fri, 12/5/08, John Gonzalez <indigoonlatigo(at)msn.com> wrote:
[quote]From: John Gonzalez <indigoonlatigo(at)msn.com>
To: "RV 10 group" <rv10-list(at)matronics.com>
Date: Friday, December 5, 2008, 7:10 AM
#yiv1920014348 .hmmessage P { margin:0px;padding:0px;} #yiv1920014348 { font-size:10pt;font-family:Verdana;} Hardwood dowels would work will too. Drill out a hole, cut dowel to length, glue in.
Date: Fri, 5 Dec 2008 04:40:21 -0700
--> RV10-List message posted by: "David McNeill" <dlm46007(at)cox.net>
Don A. McDonald
40636
ricksked(at)embarqmail.co
PostPosted: Fri Dec 05, 2008 10:33 am    Post subject: How to create epoxy threads Reply with quote
It's really just as easy to make up the flox, no need for any metal. The epoxy/flox mixture drills and taps very nicely. I did embed a 1" dowel into my doors for a pull down strap though.
Rick S.
40185
LarryRosen
PostPosted: Wed Dec 31, 2008 9:09 am    Post subject: Re: How to create epoxy threads Reply with quote
You could use a click bond bushing with a threaded center.
See them at <http>
Larry Rosen
#356
Larry Rosen
#40356
N205EN (reserved)
<http>
nukeflyboy
PostPosted: Sat Jan 03, 2009 5:29 am    Post subject: Re: How to create epoxy threads Reply with quote
Depending on how much depth you have to work with you could use threaded inserts. Available at Lowe's Aviation Supply in the misc hardware drawers you can find 2 types of inserts. One presses in and is held with barbs (for use in wood) and the other screws in. This would give a little stronger hard point if you don't want to tap an epoxy wad (though that may be the easiest solution).
Dave Moore
RV-6 built and sold
RV-10 built and flying
pascal(at)rv10builder.net
PostPosted: Sat Jan 03, 2009 6:38 am    Post subject: How to create epoxy threads Reply with quote
Being my cover for the door handle and lock is rather light I simply drilled
7/64 into doors and used the screws to make the tap. 5x 6R6 screws and the
panel is held fine and appears secure. I think the door has enough depth
around the handle to be strong enough to hold a few screws. If it fails
later in life I'll do more at that point.
Pascal
Sent: Saturday, January 03, 2009 5:29 AM
Subject: Re: How to create epoxy threads
Dave Moore
RV-6 flying
RV-10 QB - cabin top/fiberglass hell
http://forums.matronics.com/viewtopic.php?p 22530#222530
Mike Whisky
PostPosted: Mon Jan 05, 2009 7:40 am    Post subject: Re: How to create epoxy threads Reply with quote
Thank you for all your answers!
One questions remains open though, if I just have lets say a 3/16 hole how will I get epoxy/flox through it to make a nice base in the inside of the door. Just pressing it through the hole won't do the job.
Michael
#511
greghale
PostPosted: Mon Jan 05, 2009 7:55 am    Post subject: Re: How to create epoxy threads Reply with quote
My armrest are larger than normal armrests. I need a solid attachment of the armrest to the door. I thought about rivnuts and epoxing aluminum inserts in the door. I came up with a simple attachment that is very solid for my armrest. I used a scrap piece of aluminum and attached three nutplates on the back side. Dremeled clearance holes in the door for the nutplates. I then expoxied and flush riveted the aluminum piece to the door. I plan on adding a strap in the middle of my door below my armrest for pulling the door down and shut when latching the door. This attachment provided me with a very solid attachment point.
Greg...
 Filesize:  23.89 KB
 Viewed:  681 Time(s)
Greg Hale rv10 -- N210KH
www.nwacaptain.com
PostPosted: Mon Jan 05, 2009 8:14 am    Post subject: How to create epoxy threads Reply with quote
Michael;
I built a lock on one door and built a cover for the handle and lock. All
that is holding the fiberglass piece is 6R6 screws. I noticed that when I
applied flox (just slightly thinner than peanut butter) it was enough to
fill the hole and slightly drip (without breaking off) down. When I drill
the 7/64 hole and use the screws to tap the hole the flox is giving it a
little more space to grip onto. it is strong enough that I am unable to move
the cover nor the screws. I really don't think anything stronger is needed
for my application, which is simply a light cover that really should not
need to be removed often.
With the 3/16 hole I think filling it with flox might give you the same
effect, just make sure it is more like peanut butter, another option if your
looking for filling the area around it is flip the door upside down; use a
syringe to squeeze the flox into the hole, cover the hole/flox with plastic;
let it set. the gravity will cause the flox to spread around the area
depending on how thin the flox is will determine how much is spreads, of
course.
Pascal
From: "Michael Wellenzohn" <rv-10(at)wellenzohn.net>
Sent: Monday, January 05, 2009 7:40 AM
Michael
RV-10 builder (engine, prop, finishing)
#511
http://forums.matronics.com/viewtopic.php?p 22957#222957
partner14
PostPosted: Mon Jan 05, 2009 9:48 am    Post subject: How to create epoxy threads Reply with quote
Pascal, I've also created covers for the inner door hardware. I made up some wing spacers that I will JB weld onto the flat portion of the door hardware.... then drill and tap the wing points to hold the cover plates. I'll snap some pics today. Also put a lock on the pilot side door.
Don McDonald
--- On Mon, 1/5/09, pascal <pascal(at)rv10builder.net> wrote:
Subject: Re: Re: How to create epoxy threads
Date: Monday, January 5, 2009, 8:13 AM
--> RV10-List message posted by: "pascal"
Michael;
I built a lock on one door and built a cover for the handle and lock. All that
is holding the fiberglass piece is 6R6 screws. I noticed that when I applied
flox (just slightly thinner than peanut butter) it was enough to fill the hole
and slightly drip (without breaking off) down. When I drill the 7/64 hole and
use the screws to tap the hole the flox is giving it a little more space to grip
onto. it is strong enough that I am unable to move the cover nor the screws. I
really don't think anything stronger is needed for my application, which is
simply a light cover that really should not need to be removed often.
With the 3/16 hole I think filling it with flox might give you the same effect,
just make sure it is more like peanut butter, another option if your looking for
filling the area around it is flip the door upside down; use a syringe to
squeeze the flox into the hole, cover the hole/flox with plastic; let it set.
the gravity will cause the flox to spread around the area depending on how thin
the flox is will determine how much is spreads, of course.
Pascal
--> RV10-List message posted by: "Michael Wellenzohn"
Michael
#511
Don A. McDonald
40636
glastar(at)gmx.net
PostPosted: Mon Jan 05, 2009 10:45 pm    Post subject: How to create epoxy threads Reply with quote
Hello Michael,
depending on where it is and what load you want to spread onto the shell
you can do following approach to create another hard point. Lay the
shell onto the back, drill your 3/26 hole, use a L shaped hard wire,
where the shorter leg is around 1/2 inch long, use your drill fix the
longer leg in the chuck. Enter through the 3/16 inch hole and start your
drill, the short leg will remove the foam between the inner and outer
shell, move it up and down to get all of it removed and blow it out with
dry air. You know created a 1" hole between the shells which you can
fill with the peanut butter (flox-epoxy) push it in there and let it
cure. This large hard point can hold up quite a bit of load.
Let me know if you need a hands on, was close to your shop December 30th
and missed you there ;o)
Werner
Michael
#511
pitts_pilot(at)bellsouth.
PostPosted: Tue Jan 06, 2009 5:24 am    Post subject: How to create epoxy threads Reply with quote
I use an allen wrench in place of the bent wire ...... If I can bend the
'L' in the wire without it cracking, it doesn't seem to stand up to the
torque.
Linn
Werner Schneider wrote:
Hello Michael,
shell you can do following approach to create another hard point. Lay
the shell onto the back, drill your 3/26 hole, use a L shaped hard
wire, where the shorter leg is around 1/2 inch long, use your drill
fix the longer leg in the chuck. Enter through the 3/16 inch hole and
start your drill, the short leg will remove the foam between the inner
and outer shell, move it up and down to get all of it removed and blow
it out with dry air. You know created a 1" hole between the shells
which you can fill with the peanut butter (flox-epoxy) push it in
there and let it cure. This large hard point can hold up quite a bit
of load.
30th and missed you there ;o)
Werner
> Michael
> #511
Mike Whisky
PostPosted: Tue Jan 06, 2009 11:47 am    Post subject: Re: How to create epoxy threads Reply with quote
Thanks guys! I understand now what to do.
Werner, I am back now from Austria and finalize the panel.
Cheers
Michael
#511
