jkreidler
Joined: 13 Feb 2008 Posts: 151 Location: Sheboygan Falls WI
Posted: Mon Dec 01, 2008 6:48 pm Post subject: Seat Belts |
Time to get seat belts on order. During construction we have discussed using 5 point harnesses in the front and back. I like 5 point harnesses when the shoulder straps are not mounted to an inertia reel. The shoulder straps have a way of pulling the lap belt up into your stomach, the submarine strap helps hold the belts down low where they belong. I have spent alot of time in race cars actually using seat belts (sometimes it just seemed like the car would fit, huh). Needless to say proper seat belt placement really helps keep the black and blue where your body can best deal with it. Enough about that , sorry to digress but I know the first question I will get is "why 5 point harnesses?".
I don't think making an anchor for the front submarine strap will be a problem, but need help in determining what belts to buy. Vans has said that I could use the same 4 point belts for the front seats in the rear seats. Does this mean that I can use the 5 point belts for the rear seats in the front? Are the shoulder belts anchored the same way? Would 5 point belts from an 8 or 4 work?
Thanks, Jason Kreidler
_________________ Jason Kreidler
4 Partner Build - Sheboygan Falls, WI
Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler
N44YH - Flying - #40617 |
rene(at)felker.com Guest
Posted: Mon Dec 01, 2008 7:26 pm Post subject: Seat Belts |
" I like 5 point harnesses when the shoulder straps are not mounted to an
inertia reel. "
I went with inertia reels and removed the 5 point from the back seat...see
attached picture.
http://www.inertialbelts.com/
I know...not much help with what you are asking, but I do like my belts.
Rene'
801-721-6080
231.2 KB |
464 Time(s) |
avu1(at)md.metrocast.net Guest
Posted: Mon Dec 01, 2008 7:57 pm Post subject: Seat Belts |
It's been a while but I remember that Van's harnesses are all the same,
front or rear. So yes you can use the 5-point for the front and vice
versa. If you can find a way to add anchor tabs in the front like the ones
in the rear, it should work.
Anh
N591VU - flying
<jason.kreidler(at)regalbeloit.com>
RV-10 Quick Build
4 Partner Build - Finishing
http://forums.matronics.com/viewtopic.php?p 17257#217257
lbgjb10
Posted: Tue Dec 02, 2008 6:26 am Post subject: Re: Seat Belts |
how difficult is it to 'retro' fit inertial reels to front seats on flying plane??lbb
_________________ Larry and Gayle N104LG |
dlm46007(at)cox.net Guest
Posted: Tue Dec 02, 2008 6:52 am Post subject: Seat Belts |
If you look at the procedures on www.inertialbelts.com, you will need to
create the four hardpoints each belt from the outside of the lid. We used a
cutter inside to cut the inner glass and remove the foam; then we reinforced
the lid with additional layers of glass. This would have to be accomplished
from the outside. If you wish to discuss how to do this, give me a call
480-626-4048. Obviously this will create some need for re paint if the paint
is already on the aircraft.
Deems Davis
msausen
Joined: 25 Oct 2007 Posts: 559 Location: Appleton, WI USA
Posted: Tue Dec 02, 2008 6:56 am Post subject: Seat Belts |
You will probably have to send in your existing belts to have the reels put on if the original manufacturer offers them. That's assuming there is enough slack to use reels. If you have Hooker belts right now the easiest thing to do would be to order the same belts again but with the reels this time and then sell your existing belts.
Michael
