cristalclear13
Joined: 19 Sep 2007 Posts: 363 Location: Southeast Georgia
Posted: Sat Nov 29, 2008 8:57 pm Post subject: corrosion in the tube |
I'm seeing some rust on the inside bottom backside of my tube.
I can't see very far into the tube. Does anyone have any ideas of a way to inspect the entire inside of the tube?
And what's a good way to treat the rust in there?
_________________ Cristal Waters
Private Pilot Aug 2008
Rotax 2 stroke maintenance April 2009 |
Posted: Sun Nov 30, 2008 6:43 am Post subject: corrosion in the tube |
Are you speaking of the tail boom tube? Since it's aluminum the
rust is coming from something else. Cables? H-member?
Linseed oil reduced with lacquer thinner makes a pretty good
preservative.
Careful around paint though.
BB
On 29, Nov 2008, at 11:57 PM, cristalclear13 wrote:
<cristalclearwaters(at)gmail.com>
Cristal Waters
Kolb Mark II Twinstar
Rotax 503 DCSI
http://forums.matronics.com/viewtopic.php?p 16946#216946
Posted: Sun Nov 30, 2008 8:12 am Post subject: corrosion in the tube |
At 08:57 PM 11/29/08 -0800, you wrote:
Cristal,
There are all kinds of rust killers on the market. From the following site:
"DESCRIPTION: GEM RUST KILLER & Metal Prep is a balanced formula of
phosphoric acid, wetting agent and extenders. It causes rust (iron oxide) to
chemically change to iron phosphate, which turns the metal black. A coat of
paint then attaches itself so closely to the metal that moisture and oxygen
cannot attack the surface and results in a much longer lasting paint
job."
http://www.gemrustkiller.com/
I don't know what phosphoric acid will do to aluminum. You might want to
test it first. If you are talking about the tail end of the boom tube, you
might consider periodically spraying it with WD40. It will drive out the
moisture and prevent further corrosion.
Also there is a electrolysis problem between the steel ring around the
aluminum tube. If you can convert the iron oxide to iron phosphate, it may
provide a stronger barrier to the dissimilar metal problem.
Jack B. Hart FF004
Winchester, IN
Posted: Mon Dec 01, 2008 4:38 am Post subject: corrosion in the tube |
Jack- I was looking at your web site, and it looks like your main fuselage tube is bare aluminum. Is it coated with anything? What did you do about electrolysis at the contact points with steel, front and rear? How do you keep it shiny, wax?
Bill Sullivan
Windsor Locks, Ct.
Posted: Mon Dec 01, 2008 7:06 am Post subject: corrosion in the tube |
Date: Mon, 1 Dec 2008 04:38:23 -0800 (PST)
From: william sullivan <williamtsullivan(at)att.net>
keep it shiny, wax?
Bill,
The fuselage tube is not coated. I don't worry too much about electorlysis,
as the FireFly is always hangared. I do het the joints with a little spray
WD 40 a couple times a the year. I polish the tube tube one time a year. I
use automotive aluminum wheel polish on a folded paper towel followed by an
old soft cotton tee shirt. It looks better in the photo that it realy is.
Jack B. Hart FF004
Winchester, IN
cristalclear13
Posted: Mon Dec 01, 2008 8:39 pm Post subject: Re: corrosion in the tube |
We got the corrosion cleaned up fairly easily....what wasn't easy was digging the mouse nest out from the middle of the boom tube.
Does anyone put anything on the ends of their boom tubes to keep the critters out?
by0ung(at)brigham.net Guest
Posted: Tue Dec 02, 2008 7:13 am Post subject: corrosion in the tube |
Cristal
I have glued in a piece of fabric about 6 inches in from the end. Then
had to cut small slits in the fabric to let the cables pass through. My
purpose for doing this was not to keep critters out,,, it was to keep the
air in the cabin from being sucked out the back. This way I can keep a bit
warmer in the winter.
Boyd Young
Kolb MKIIIC
critters out?
Cristal Waters
Posted: Tue Dec 02, 2008 7:38 am Post subject: corrosion in the tube |
critters out?
Cristal Waters
Cristal:
Serious problem, rodents.
My main concern is urine. It is very corrosive, especially to aluminum.
I don't know of anyway to check the tailboom tube to insure it has not been
corroded by rodent urine. Very difficult to see using a flashlight and
peeking in the end of the tube.
Several years ago my mkIII was attacked by rodents, rats and/or chipmonks.
Major damage was caused by chewing wire bundles, kevlar parachute bridals,
seats, even plastic hydraulic brake lines filled with fluid. They's chew up
any thing to build a nest.
I haven't had a problem with them for some time now. I keep a couple
Valerian capsules in the tail boom and floor of the cockpit. Valerian is a
herb you can buy at Walmart.
Hope the neighbors have not moved in while I have been gone the last two
months.
Payson, AZ
_________________ John Hauck
Titus, Alabama |
aslsa.rng(at)gmail.com Guest
Posted: Tue Dec 02, 2008 7:45 am Post subject: corrosion in the tube |
John, a bit off the corrosion question, but I'm curious about the valerian. Does it affect mice in the same way it affects cats?
Rick
On Tue, Dec 2, 2008 at 9:38 AM, John Hauck <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)> wrote:
[quote]--> Kolb-List message posted by: "John Hauck" <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)>
Cristal Waters
Cristal:
I don't know of anyway to check the tailboom tube to insure it has not been corroded by rodent urine. Very difficult to see using a flashlight and peeking in the end of the tube.
Several years ago my mkIII was attacked by rodents, rats and/or chipmonks. Major damage was caused by chewing wire bundles, kevlar parachute bridals, seats, even plastic hydraulic brake lines filled with fluid. They's chew up any thing to build a nest.
I haven't had a problem with them for some time now. I keep a couple Valerian capsules in the tail boom and floor of the cockpit. Valerian is a herb you can buy at Walmart.
Hope the neighbors have not moved in while I have been gone the last two months.
Payson, AZ
Posted: Tue Dec 02, 2008 7:57 am Post subject: corrosion in the tube |
Rick:
Don't know about cats, but when I was having my rodent problem I discovered through research on the internet that Valerian would act as a repellent. It stinks!
Rick
Titus, Alabama |
cristalclear13
Posted: Tue Dec 02, 2008 8:40 am Post subject: Re: corrosion in the tube |
| John Hauck wrote: |
months.
I hope not too. We also have a LOT of spiders in the hanger and I found where a couple have been making their nests/laying their eggs/whatever you call it in tiny crevices. I don't know if they cause much corrosion, but one had a webby mess inside the tube where my tailwheel attaches.
Posted: Tue Dec 02, 2008 9:08 am Post subject: corrosion in the tube |
Interesting. In cats, if catnip is analogous to kittie pot, valerian is kitty LSD. Hope the mice don't figure that one out or the hangar cat is in for a high old time.
Rick
On Tue, Dec 2, 2008 at 9:56 AM, John Hauck <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)> wrote:
| Quote: | Rick:
Rick
[/b] |
