Avionics Interconnect
jim(at)CombsFive.Com
PostPosted: Mon Dec 01, 2008 8:52 am    Post subject: Avionics Interconnect Reply with quote
I have attached my avionics interconnect spreadsheet. It does not include the connections to lights, engine but does include the interface between the EFIS, NAVCOM, Transponder, audio panel and GPS. I used this to build a harness for the stack. It may be of some use to others.My configuration is:EFIS -> Advanced Flight Systems AF3500 EENavCom -> Garmin SL-30Transponder -> Garmin 327GPS -> Serial BR-355Audio -> PS8000BJim CombsN312F - 40192
Avionics_Interconnect_Wiring.xls
 Filename:  Avionics_Interconnect_Wiring.xls
 Filesize:  81.5 KB
 Downloaded:  363 Time(s)
planesmith(at)hotmail.com
PostPosted: Mon Dec 01, 2008 10:17 am    Post subject: Avionics Interconnect Reply with quote
Jim C
Nice easy way to map the connections! Never thought of laying them out in Excel in this way.
Thanks for the post C
Vern Smith (#324 cowl)
Date: Mon C 1 Dec 2008 11:48:59 -0500
Subject: Avionics Interconnect
I have attached my avionics interconnect spreadsheet.  It does not include the connections to lights C engine but does include the interface between the EFIS C NAVCOM C Transponder C audio panel and GPS.  I used this to build a harness for the stack.
Audio -> PS8000B
Jim Combs
N312F - 40192
Color coding for safety: Windows Live Hotmail alerts you to suspicious email. Sign up today. [quote][b]
msausen
PostPosted: Tue Dec 02, 2008 5:49 am    Post subject: Avionics Interconnect Reply with quote
Did anyone else see the RV-10 when they stared at it out of focus? Heh
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jim
Sent: Monday, December 01, 2008 10:49 AM
Audio -> PS8000B
Jim Combs
N312F - 40192
daveleikam(at)wi.rr.com
PostPosted: Tue Dec 02, 2008 6:03 am    Post subject: Avionics Interconnect Reply with quote
Have another cup of coffee... things will clear right up.
PostPosted: Tue Dec 02, 2008 7:04 am    Post subject: Avionics Interconnect Reply with quote
Actually if you print it, It is much easier to read.I have it sized to fit on two sheets. The first sheet is the interfaces to the EFIS, NAVCOM, Transponder and Audio panel. The second sheet is pretty much all the audio to the headset connectors.Jim C> Have another cup of coffee... things will clear right up.> > do not archive> ----- Original Message -----> From: RV Builder (Michael Sausen)> To: rv10-list(at)matronics.com> Sent: Monday, December 01, 2008 12:57 PM> Subject: RE: Avionics Interconnect> > > Did anyone else see the RV-10 when they stared at it out of focus? Heh> > > > Do not archive> > > > From: owner-rv10-list-server(at)matronics.com> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jim> Sent: Monday, December 01, 2008 10:49 AM> To: rv10-list(at)matronics.com> Subject: Avionics Interconnect> > > > I have attached my avionics interconnect spreadsheet. It does not> include the connections to lights, engine but does include the interface> between the EFIS, NAVCOM, Transponder, audio panel and GPS. I used this> to build a harness for the stack.> > It may be of some use to others.> > My configuration is:> > EFIS -> Advanced Flight Systems AF3500 EE> NavCom -> Garmin SL-30> Transponder -> Garmin 327> GPS -> Serial BR-355> Audio -> PS8000B> > Jim Combs> N312F - 40192> > > > > > [quote][b]
Lew Gallagher
PostPosted: Wed Dec 03, 2008 6:26 am    Post subject: Re: Avionics Interconnect Reply with quote
Hey Jim,
Thanks for the print out tip -- I have to admit, I was one of those who opened the file, my vision glazed over, and I filed it away in case I needed it later. Now, printed out, it is much easier.
Later, - Lew
non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed !
