naumuk(at)alltel.net Guest
Posted: Sat Feb 10, 2007 6:05 pm Post subject: Longeron |
HDS People-
I'm at a loss here. My upper rear longeron tracks straight along the top edge and over the inboard rear former, but is a good 1/8" from contacting the top of the former closest the tail. Former and side skin dimensions are well within ± 2mm of print. Yes, everything's level.
What do you think? Shim the top of the tail former, or bend the longeron down to make contact with the tail former?
Bill Naumuk
HDS Fuselage
Townville, Pa
Jaybannist(at)cs.com Guest
Posted: Sat Feb 10, 2007 7:25 pm Post subject: Longeron |
Bill,
I'm not "HDS People," but I think the XL is about the same in the tail end. That's really beside the point.
I would always go with shimming in preference to bending. Just my opinion, FWIW.
Jay in Dallas
"Bill Naumuk" <naumuk(at)alltel.net> wrote:
| Quote: | HDS People-
Bill Naumuk
HDS Fuselage
Townville, Pa
Posted: Sun Feb 11, 2007 8:00 am Post subject: Longeron |
Bill,
Not knowing exactly how complete your tail segment is yet, but I'd make
that decision when all the rudder and stab plates have been
positioned. Do consider the spacing of the rudder hinge plates and the
distance needed between pivot angles on your rudder. Check for
alignment and hinge distance and adjust by shim or shim plus deflection
accordingly.
Larry McFarland - 601HDS
Bill Naumuk
HDS Fuselage
Townville, Pa
MHerder
Joined: 11 Feb 2008 Posts: 143 Location: Fort Worth TX
Posted: Fri Nov 28, 2008 10:21 am Post subject: Re: Longeron |
Hi guys,
Im at the same point with the same problem on an HD and have the same issues. The longeron is about 3 mm off of the rear HT frame. Can anybody help.
_________________ Zodiac 601 HD
Jabiru 3300
Wood Sensinich 64x47
Finally Flying |
