Kitfox mishap in Colorado
Goto page Previous  1, 2, 3  Next
wingsdown(at)verizon.net
PostPosted: Thu Nov 27, 2008 7:16 am    Post subject: Kitfox mishap in Colorado Reply with quote
To extract maximum take off performance without the constant speed
feature I sometimes found it necessary or desirable to pitch the prop
flatter for maximum RPM and manifold pressure. Once on the roll, usually
just a few hundred feet off the ground, forward speed has increased to
the point the prop unloads and RPMs increase beyond what is wanted. One
must then either reduce power or pitch the prop more course. In a normal
take off scenario it really is not necessary to have to make a major
adjustment immediately after lift off. It was nice thought to be able to
go from a great climb prop to a great cruise prop at the touch of a
toggle.
On a subject not addressed, but one that was really nice, is the short
field landing or emergency short stop requirement. By putting the prop
in beta, reverse you could do some really cool approaches and short
stops. Not that one would do this on a regular basis when a good side
slip will do. Oh and should you ever need to slow down really fast in
the air, there is nothing more exciting than going beta for a few
seconds at full power. Only did that once with plenty of altitude. What
a rush being pulled forward in your harness. Only once. That was enough
for me.
Rick
Lynn Matteson
PostPosted: Thu Nov 27, 2008 2:08 pm    Post subject: Kitfox mishap in Colorado Reply with quote
I was just watching the "House" marathon on TBS, and they mentioned
the word "beta", but I didn't see or hear anything about
propellors....seriously though, what does "beta" mean in the world of
propellors? All I know about Beta is that is was a superior video
tape format that the stupid masses voted down in favor of the longer
running-time VHS.
I really am serious about the question, though....what does beta mean
in respect to props? (the dictionary exp. doesn't give me a clue)
(Maybe if I got the additional 20 hours of flight training, I'd know
this but I didn't and I don't.) : )
Lynn Matteson (educationally challenged Sport Pilot)
Jabiru 2200, 593hrs
Sensenich 62x46
flying again after rebuild, and new Electroair direct-fire ignition
system;
also building a new pair of snow skis
On Nov 27, 2008, at 7:56 AM, fox5flyer wrote:
(snip)
<fox5flyer(at)idealwifi.net>
That prop has built in interlocks so that it cannot go into beta
above a certain rpm. I think it's about 1200 prop rpm to be exact,
but I'd have to check.
Deke Morisse
<paul(at)eucleides.com>
(snip)
There is no danger of putting in reverse Beta in a constant speed prop.
Lynn
Kitfox IV-Jabiru 2200
N369LM
MichaelGibbs(at)cox.net
PostPosted: Thu Nov 27, 2008 2:21 pm    Post subject: Kitfox mishap in Colorado Reply with quote
Lynn asks:
...what does beta mean in respect to props?
Beta means the prop pitch can be reversed. Very handy for float
planes that need to maneuver to and from a dock without the pilot
having to get out and use a paddle.
Mike G.
N728KF, Kitfox IV-1200 Speedster
Phoenix, AZ
Lynn Matteson
PostPosted: Thu Nov 27, 2008 2:50 pm    Post subject: Kitfox mishap in Colorado Reply with quote
Thanks, Mike....now as a person who needs to know how words came
about, I just have to know how do I tie the word "beta" into prop
pitch reversing? The dictionary says (for one example) "the second
item in a series of classification", so I guess the first is going
forward, and the second is "beta" or reversing, eh? Sorry to be a
pain in the butt, but "I gots to know!"
I just can't stand it when they throw a word at something without a
reasonable explanation for it.
Lynn Matteson
Jabiru 2200, 593hrs
Sensenich 62x46
system;
On Nov 27, 2008, at 5:20 PM, Michael Gibbs wrote:
<MichaelGibbs(at)cox.net>
Lynn asks:
Mike G.
Phoenix, AZ
Lynn
N369LM
MDKitfox(at)aol.com
PostPosted: Thu Nov 27, 2008 3:59 pm    Post subject: Kitfox mishap in Colorado Reply with quote
Lynn,
Here's a simple definition of Beta as provided by Hatrzell. I figure they may know a little about props.
(I through in the feathering definition at no extra charge.)
What is beta? What does feathering mean?
Beta Range/Reverse
Some constant speed propellers are equipped for beta/reverse operation. Beta Range is any blade angle below flight idle (Hydraulic low pitch stop). Reverse is any blade angle less than zero degrees. This blade angle produces thrust in a direction opposite to that of normal thrust. Such propellers are typically installed on aircraft with turbine engines and are used for to reduce landing roll.
Feathering
Some constant speed propellers, primarily installed on twin engine aircraft, are equipped to reposition the blades until they are nearly aligned with the relative wind. This position, termed feathering, is used to minimize drag, thus increasing single engine performance
Rick Weiss
N39RW Series V Speedster, 912ULS
SkyStar S/N 1
Port Orange, FL
On Nov 27, 2008, at 5:51 PM, Lynn Matteson wrote:
[quote]--> Kitfox-List message posted by: Lynn Matteson <lynnmatt(at)jps.net (lynnmatt(at)jps.net)>
Thanks, Mike....now as a person who needs to know how words came about, I just have to know how do I tie the word "beta" into prop pitch reversing? The dictionary says (for one example) "the second item in a series of classification", so I guess the first is going forward, and the second is "beta" or reversing, eh? Sorry to be a pain in the butt, but "I gots to know!"
I just can't stand it when they throw a word at something without a reasonable explanation for it.
Lynn Matteson
Jabiru 2200, 593hrs
Sensenich 62x46
flying again after rebuild, and new Electroair direct-fire ignition system;
--> Kitfox-List message posted by: Michael Gibbs <MichaelGibbs(at)cox.net (MichaelGibbs(at)cox.net)>
Lynn asks:
Beta means the prop pitch can be reversed. Very handy for float planes that need to maneuver to and from a dock without the pilot having to get out and use a paddle.
Mike G.
Phoenix, AZ
http://www.matronics.p;   -Matt Dralle, List Adminsp; - MATRONICS WEB FOR========================
= [quote][b]
Lynn Matteson
PostPosted: Thu Nov 27, 2008 4:37 pm    Post subject: Kitfox mishap in Colorado Reply with quote
Thanks, Rick....the feathering I knew about, and the description of
beta I will accept, but the choice of that particular word for that
particular function still leaves me scratching my head, but I'll drop
the line of questioning at that.
And regarding Hartzell...yeah, I figure they know a LOT about props,
as a friend of mine and I stopped by there on the way home from
Dayton, Ohio, early one morning, and were taken on about hour's tour
of the place....we saw everything from the raw stock, to balancing,
to finished props ready for shipping...really nice folks there.
Lynn Matteson
Jabiru 2200, 593hrs
Sensenich 62x46
system;
On Nov 27, 2008, at 6:58 PM, Weiss Richard wrote:
Lynn,
Beta Range/Reverse
Feathering
performance
Rick Weiss
SkyStar S/N 1
Port Orange, FL
Lynn
N369LM
Fox5flyer
Just curious, Rick. My NSI prop has mechanical interlocks to keep it from
going into beta with anything more than 1200 prop rpm. Did you remove your
interlocks? If not, how were you able to do it?
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 402+ TT
"The aim of an argument or discussion should not be victory, but progress."
- Joseph Joubert
PostPosted: Thu Nov 27, 2008 7:16 pm    Post subject: Kitfox mishap in Colorado Reply with quote
Propeller pitch can be specified in two different, but equivalent, ways. The first is
the blade angle, and the second is the pitch. The two are related as follows:
beta = atan( pitch / (2*pi*0.75*d/2) )
where beta is the blade angle, pi is 3.14159, and d is the propeller diameter. Note
that the pitch and diameter must be specified in the same units.
Paul A. Franz
Registration/Aircraft - N14UW/Merlin GT
Engine/Prop - Rotax 914/NSI CAP
Bellevue WA
425.241.1618 Cell
PostPosted: Thu Nov 27, 2008 7:41 pm    Post subject: Kitfox mishap in Colorado Reply with quote
Well, that is not true. Beta is the angle of the propeller at 3/4 radius. A negative
Beta would result in reverse thrust.
Colloquial usage might be somewhat confusing the facts. Beta, in itself does not imply
reverse thrust. A negative Beta (negative propeller angle measured at the 3/4 radius)
would imply reverse thrust.
Paul A. Franz
Bellevue WA
425.241.1618 Cell
Float Flyr
PostPosted: Fri Nov 28, 2008 6:01 am    Post subject: Kitfox mishap in Colorado Reply with quote
I've flowen with an Ivo IFA for the past three years... I'd recommend it to
anyone especially anyone who flies on floats. I'd blip my 582 from 6400 up
to 6800 just for take off. When I had around 200 ft under my feet then I'd
pick up the pitch to reduce rpm back to 6400 for the climb. When I got to
altitude I'd pick up the pitch again adn slow things down to around 6200
before pulling the throttle and setting a cruise rpm of around 5600 to 5800
rpm. Before landing I'd go into a climb and reset my prop for 6400 to be
ready for a go around.
I used that procedure for a couple of reasons one is it got me off the water
carrying floats a lot faster. I never let myself get into a situation where
I could not climb immediately at 400 ft/min. And I always cut my throttle
back to idle to descend. When I first started flying floats I would use
some throttle to level the plane out on landing but I was never really happy
with doing that so I continually tried to use less and less throttle on
landing, It got to the point that I haven't used throttle to land in a long
time... Then again last summer my plane spent it's holiday sans engine in
the shop.
In the interest of being safe I'll get a few hours with an instructor again
before taking the plane up again. Things do get rusty.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Float Flyr
PostPosted: Fri Nov 28, 2008 7:07 am    Post subject: Kitfox mishap in Colorado Reply with quote
Lynn:
Beta, ā, is the second letter of the Greek alphabet.  Alpha, į, is the first letter.  As props are primarily designed to pull or push a plane through the air I’d assume that that would be the primary, #1 or Alpha job.  Anything else is a second job or Beta.
As far as I know when the prop ceases to deliver thrust it can be considered to be in beta operation...  reverse thrust is usually known as “Full Beta”  all turbo prop engines require full beta operation.  Even on floats a Twin Otter will use full beta on landing to shorten the landing run out.  On takeoff beta allows the turbine to spool up without load to deliver the torque required to spin the prop.
Noel Loveys
Campbellton, NL, Canada
CDN AME intern, PP-Rec
C-FINB, Kitfox III-A
912 almost installed
Aerocet 1100 floats
[url=noelloveys(at)yahoo.ca]noelloveys(at)yahoo.ca[/url]
 Filesize:  7.29 KB
 Viewed:  15565 Time(s)
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Float Flyr
PostPosted: Fri Nov 28, 2008 7:11 am    Post subject: Kitfox mishap in Colorado Reply with quote
Lynn:
I neglected to say in my last post that the origin of the Beta and Full Beta terms were pure speculation. They do however make it easier to remember exactly what they do.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Lynn Matteson
PostPosted: Fri Nov 28, 2008 8:24 am    Post subject: Kitfox mishap in Colorado Reply with quote
Yup, it sounds like the use of "beta" is to designate the second
function of the prop. That's the conclusion that I came up with,
finally.
Lynn Matteson
Jabiru 2200, 593hrs
Sensenich 62x46
system;
On Nov 28, 2008, at 10:06 AM, Noel Loveys wrote:
Lynn:
Beta, β, is the second letter of the Greek alphabet. Alpha, α, is
known as ā€œFull Betaā€ all turbo prop engines require full beta
spin the prop.
Noel Loveys
Lynn
N369LM
Lynn Matteson
PostPosted: Fri Nov 28, 2008 8:29 am    Post subject: Kitfox mishap in Colorado Reply with quote
Sounds like a good assumption, Noel..certainly works for me. And
thank God I don't have to do all that setting, resetting and stuff
when I fly...just look out the window for minutes on end, and
occasionally glance at the gauges..or is it the other way around? : )
Lynn Matteson
Jabiru 2200, 593hrs
Sensenich 62x46
system;
On Nov 28, 2008, at 10:10 AM, Noel Loveys wrote:
Lynn:
Noel
Lynn
N369LM
Tom Beirne
PostPosted: Sat Nov 29, 2008 3:27 am    Post subject: Re: Kitfox mishap in Colorado Reply with quote
Well, that is not true. Beta is the angle of the propeller at 3/4 radius. A negative Beta would result in reverse thrust.
Propeller pitch can be specified in two different, but equivalent, ways. The first is the blade angle, and the second is the pitch.
Not quite right, Alpha is the blade Angle of Attack
The term Beta in this usage means the following
On Turboprop aircraft with a constant speed prop, power lever settings between flight idle and maximum power allow the prop governor to select the appropriate blade pitch to maintain a set RPM and this is called the Alpha mode of operation. When the power lever is moved below flight idle the lever directly controls the pitch angle of the blades and this is referred to as Beta mode where the pitch can be changed from the flight idle position to full reverse, also known as Full Beta.
For those interested in propeller aerodynamics
In aerodynamics the Greek letter alpha is commonly used to denote the Angle of Attack of an aerofoil (wing shape), that is the angle between the chord line and the relative airflow. This is also true for propellers as they are really just aerofoils in rotation, in this case the reference Alpha is taken at 75 percent span from the centre of the hub.
Note that this is a completely separate measure to the blade pitch angle which is a geometric angle of the blade relative to the plane of rotation of the prop. Where Angle of Attack (or Alpha) will change with both the airspeed and RPM the pitch angle remains constant,hence the term "fixed pitch". Constant speed props operate differently by continually changing the blade pitch angle to achieve a constant RPM.
As Alpha changes so too do the lift and drag properties, the most efficient use of power is when the blade achieves its best lift to drag ratio. Every blade design will have its own optimum Alpha for best lift to drag which, at a given pitch angle, is dependent on relative airspeed and RPM. Thus a fixed pitch prop is only operating at its most efficient at a given RPM and airspeed. One can choose the best operating regime by setting the blade pitch angle to give max efficiency at that speed and power setting. Ground adjustable props make this a once per flight deal but In-flight adjustable (or variable pitch) props allow the pilot to select the best pitch angle, and in doing so optimize Alpha for the conditions.
What may surprise people is that a negative blade AoA can occur at positive blade pitch angles because it is relative to the airflow and not the aircraft. At zero airspeed a nearly flat pitch angle would be required to get negative Alpha but as airspeed increases it can be achieved at coarser angles because as forward airspeed increases at a given RPM the AoA of the blade decreases. Hence at higher airspeeds the pilot will require a coarser blade pitch to keep the prop working at its most efficient Alpha. Also because higher forward airspeeds decrease AoA, if you take your in-flight adjustable prop in cruise flight and send it to fully fine too quickly there is a good chance that it will achieve negative thrust and provide a rather effective airbrake until the airspeed reduces sufficiently and equilibrium is once again reached. This might not be too good for your engine though.
matronics(at)bob.brennan.
PostPosted: Wed Dec 03, 2008 7:01 am    Post subject: Kitfox mishap in Colorado Reply with quote
Here's the webpages featuring the Kitfox that crashed, full details and
pictures. It was purchased by a missionary to fly from village to village in
Guatamala. They are currently looking for another similar plane to replace
it.
http://www.pattonministries.org/kitFox/kitFox-Main.php
More details about the crash:
http://www.albertleatribune.com/news/2008/nov/28/pilot-speaks-about-survivin
g-airplane-crash/
Bob Brennan - N717GB
1991 UK Model 2 ELSA Kitfox
Rotax 582 with 3 blade prop
Wrightsville Pa
clint_bazzill(at)hotmail.
PostPosted: Wed Dec 03, 2008 9:34 am    Post subject: Kitfox mishap in Colorado Reply with quote
Boy C that is one obese Model IV. Even without Grove gear.  What is this 10% increase in weight?
Clint
[quote] From: matronics(at)bob.brennan.name
Subject: RE: Kitfox mishap in Colorado
Date: Wed C 3 Dec 2008 10:00:39 -0500
--> Kitfox-List message posted by: "Bob Brennan" <matronics(at)bob.brennan.name>
Here's the webpages featuring the Kitfox that crashed C full details and
it.
g-airplane-crash/
Wrightsville Pa
aviateer
PostPosted: Wed Dec 03, 2008 10:07 am    Post subject: Kitfox mishap in Colorado Reply with quote
How is it that the gross weight was increased by 10%? I asked about this several years ago when I wanted to place my C IV on floats, and received mixed answers.
Kirk
On Wed, Dec 3, 2008 at 11:33 AM, Clint Bazzill <clint_bazzill(at)hotmail.com (clint_bazzill(at)hotmail.com)> wrote:
[quote] Boy, that is one obese Model IV. Even without Grove gear. What is this 10% increase in weight?
Clint
From: matronics(at)bob.brennan.name (matronics(at)bob.brennan.name)
> To: kitfox-list(at)matronics.com (kitfox-list(at)matronics.com)
Date: Wed, 3 Dec 2008 10:00:39 -0500
--> Kitfox-List message posted by: "Bob Brennan" <matronics(at)bob.brennan.name (matronics(at)bob.brennan.name)>
> it.
> g-airplane-crash/
Wrightsville Pa
Float Flyr
PostPosted: Wed Dec 03, 2008 1:38 pm    Post subject: Kitfox mishap in Colorado Reply with quote
Some, not all aircraft are certified to carry either 10% or more commonly 100lb more if they are on floats. The thinking here is at cruise speed the floats passing through the air fly themselves removing the excess weight from the plane’s structure. I’m not saying this is the case but I can say for sure my ‘Fox on Aerocet 1100s doesn’t slip very well. I think that specification has to be made when the plane is first registered.
BTW the extra pork on that plane hasn’t gone unnoticed... I had a reference to it offlist.
Noel
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com (owner-kitfox-list-server(at)matronics.com)] On Behalf Of Kitfoxkirk
Sent: Wednesday, December 03, 2008 2:37 PM
Subject: Re: Kitfox mishap in Colorado
==================== [quote][b]
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Paul A. Franz, P.E.
PostPosted: Wed Dec 03, 2008 2:03 pm    Post subject: Kitfox mishap in Colorado Reply with quote
Did you see the details of the plane on his web page? the thing was loaded! Fancy
panel and some other heavy stuff like a huge oil tank which I haven't seen before.
That was a pretty nice airplane. Not final paint. For the money he paid for the engine
and prop at the time, I think another engine choice such as the 912 would have made
more sense since the useful load is a little limiting.
As to the 10%, I think that is speculation that the plane can be over gross by that
amount in smooth air. Probably nothing official and definitely not recommended.
Paul A. Franz
Bellevue WA
425.241.1618 Cell
Paul A. Franz, P.E.
Bellevue WA
425.241.1618 Cell
425.440.9505 Office
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
Page 2 of 3
