herbgh(at)nctc.com Guest
Posted: Sun Nov 16, 2008 10:03 am Post subject: Performance of the mark III with 912 or jabiru? |
Jerry
Seems that the Titan cannot run a long enough prop to make the
912 a good alternative? Basically...Jabs do well on clean planes.
titans,Sonex etc.....Redriven 912's are well suited to any plane
where they can swing a long and more efficient prop.. Herb
ps a Jab is absolutely unsuited to a Kolb MkIII or Cobra...
At 11:45 AM 11/16/2008, you wrote:
| Quote: | Rick,
I appreciate your informed input. I can't speak for Jabs/Rotax
4-cycle engines on Kolbs, but I can on Titans. The arguments from
both sides, I've found, change nobody's mind, typically generating
more heat than light. That said, I had both a Jab 2200 and a 3300
on my Titan and found performance comparable to reported performance
of comparable 912s (of course the 100 hp 912 had fewer horses than
the 128 hp Jab), and had slightly less fuel burn. Every sport pilot
here in Madera flies behind/in front of a Jab, with one also flying
behind a 912S. I could be a little biased, I've owned five Jab
engines, and if buying another engine, that's prolly what I'd buy
again, for various reasons, but I wouldn't hesitate to own a Rotax
either. For sure, very early Jabs had teething problems and didn't
produce near the power claimed, but that was long ago and far, far
in the past. And, none of us have had to land out because of an
engine problem.
Now, back to my cellar....
Jerry
Posted: Mon Nov 17, 2008 12:43 pm Post subject: Performance of the mark III with 912 or jabiru? |
At 07:01 AM 11/17/08 -0800, you wrote:
Jerry,
There was nothing imprecise or unqualified about my statement, I did my
research very well before I decided which engine to put on my Kolb. When
someone asks a question, I give them good information in a very clear and
direct manner. Maybe you did not want to hear what I had to say, but my
information was not unqualified or imprecise...
Mike,
You are not precise. From before:
"The 912 is a better engine on a Kolb, PERIOD. If you ended up with the
inferior Jabiru on your Kolb, then I'm sorry for you, but that is no reason
to try to get others to make the same mistake."
You used the word "Kolb" and the implication is that nothing but a 912 is a
good engine. That rules out all lower hp Rotax and/or any other engine
mounted on a Kolb and this implies that a lot us who fly Kolbs are using
inferior engines. You may not want to hear this, but I really enjoy flying
my Kolb FireFly with out a 912 mounted on it.
Fly safe!
Jack B. Hart FF004
Winchester, IN
Posted: Mon Nov 17, 2008 3:09 pm Post subject: Performance of the mark III with 912 or jabiru? |
Now that we've beat that one to death.... back to SEAFOAM!
BB, puny 3 cylinder suzuki, redrive (and it actually flies!)
On 17, Nov 2008, at 3:43 PM, Jack B. Hart wrote:
<jbhart(at)onlyinternet.net>
> Jerry,
> did my
Kolb. When
clear and
but my
Mike,
with the
no reason
912 is a
engine
using
enjoy flying
Fly safe!
Jack B. Hart FF004
Winchester, IN
