longg(at)pjm.com Guest
Posted: Wed Nov 12, 2008 12:10 pm Post subject: Choosing Z-Diagram base |
I am building a system which will contain a Lycoming 360 with dual
electronic ignition and one alternator.
I have looked at Z-12, Z-19 and Z-28 as an addendum.
Which one or combination of these diagrams would support a good
solution? I read somewhere in the pages that dual electronic ignition
would best be served by two batteries.
Glenn
Beemer
Joined: 26 Aug 2006 Posts: 87 Location: Middle Georgia
Posted: Wed Nov 12, 2008 3:22 pm Post subject: Choosing Z-Diagram base |
Good evening John,
I will try to contribute something back to the list, as it has given me so
much in the last months of my build.
First question: has the engine become electrically dependent based on the
electronic ignition?
Second question: Do you physically have room to mount 2 batteries of decent
capacity in your airframe? Will your CG support such an install?
Third question: What are your general, overall goals for the electrics? I
think we all come to similar conclusions here, but...
What kind of loads are you expecting in your airplane? Maybe catalog a list
of the installed equipment. This won't necessarily change your diagram, but
it will determine the size of battery that a) will fit in the frame, and b)
is available in the market.
I studied Z-19RB quite a bit, and ended up not using it for various reasons.
That does not nullify it's validity in any way; it just didn't work for me.
I designed a simple system that provides for an acceptable safety margin,
with known risks, AND a plan for that inevitable failure. This, in and of
itself, was the golden nugget that AEC provided. It's made me think!
Don't forget, Bob's diagrams are only examples of what can be done. You can
mix and match as your needs are met. I did just that. I'm a fan of
simplicity, but others like their gadgets. Each approach has its virtues, so
you need to design around what you're comfortable with. Think about failure
modes, and how you'll deal with them when there's no more altitude,
airspeed, or ideas left.
To be continued...
Bradley
_________________ Beemer
KF2 (and now an M3!)
Suzuki G10 three-banger
Middle Georgia |
nuckolls.bob(at)cox.net Guest
Posted: Wed Nov 12, 2008 7:14 pm Post subject: Choosing Z-Diagram base |
At 03:07 PM 11/12/2008 -0500, you wrote:
. . . that statement is pretty old . . . when folks
were still installing a lot of vacuum pumps. Do you
plan a vacuum system or all electric?
If all electric, have you done a load analysis to
see how much power you need for comfortable completion
of flight with the main alternator out? You mentioned
Z-12 but consider also, Z-13/8. This is an exceedingly
light and inexpensive way to make sure you have electrons
to keep an engine running. I suspect you can trim an
e-bus load down to 8A or less. Keep in mind too that
you don't need to run both electronic ignitions all
the time. During alternator-out operations, you can
drop to one ignition with very little loss of performance
which still holds a second system in reserve.
bicyclop(at)pacbell.net Guest
Posted: Thu Nov 13, 2008 9:54 pm Post subject: Choosing Z-Diagram base |
We found a way to not have any electrons for keeping the engine alive.
Easy enough not to have our problem, but very critical that you do it
right. The fat wire from the battery to the contactor shorted out on a
brake line and filled the cabin with smoke. Shutting off the master
didn't help since it was downstream of the short. Dragged the battery
down to 5 volts. We do have one magneto and that's what kept it running
long enough to get on the ground. Very, very important that this wire
not be allowed to short, especially if both of your ignitions are on it.
Pax,
Ed Holyoke
<nuckolls.bob(at)cox.net>
Posted: Mon Nov 17, 2008 8:28 am Post subject: Choosing Z-Diagram base |
Et al,
Thanks for your suggestions. My e-bus load will easily fall below 8A
with one ignition and one Dynon running. The Z-13/8 may be a great
opportunity to save weight, money and still keep the lights on. Other
than the dual electronic ignition my system has no special requirements.
I'll check it out.
Glenn
Posted: Mon Nov 17, 2008 9:35 am Post subject: Choosing Z-Diagram base |
Two questions on Z13-8...
I like the design. My engine comes with an 80 amp internally regulated
alternator. Assuming its use, but not yet needing 80 amps (may add
air-conditioning later), may I reduce the current at the ANL using say,
a 50 amp ANL? I am assuming the shunt would be 80 AMP coming off the
Alt.
Does B & C offer a product to monitor/switch (from DC Power Master sw)
an alternator that is already internally regulated?
Posted: Sun Nov 30, 2008 9:14 am Post subject: Choosing Z-Diagram base |
At 11:33 AM 11/17/2008, you wrote:
Alt.
No, the ANL or any other protective device is intended to
open under extreme stress of faulting a wire. It's not
a controlling device to change or limit the effects of
your alternator.
Aside from weight and size, there's nothing wrong with
having a "too big" alternator. There's a bunch of C-150/
C-152 flying with 60A alternators! Lots of OBAM aircraft
with Continental engines use salvaged 60A alternators
from a Cessna even if their power requirements are a hand-full
of amps.
| Quote: | Does B & C offer a product to monitor/switch (from DC Power Master sw)
Any switch (including those sold by B&B) will control
an alternator that is controllable. Do you know the
brand and part number of the alternator supplied?
Are there instructions with it that indicate the alternator
is controllable?
( -Thomas Paine 1776- )
