cffd(at)pgrb.com Guest
Posted: Sun Nov 16, 2008 9:04 am Post subject: Heavy engine and Horiz. stab (Grant Corriveau) |
Grant,
I noticed I was flying slightly nose up in cruise in my 701. I dropped the flaperons a small amount and the nose came down and I picked up about 2 mph.
Chuck D.
N701TX
hills(at)sunflower.com Guest
Posted: Sun Nov 16, 2008 12:16 pm Post subject: Heavy engine and Horiz. stab (Grant Corriveau) |
On my Kitfox 2, the flapperons were primarily used to trim the plane, according to the flight manual.
Roger
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Chuck Deiterich
Sent: Sunday, November 16, 2008 11:01 AM
To: zenith-list
Subject: Re: Heavy engine and Horiz. stab (Grant Corriveau)
Grant,
Chuck D.
N701TX
| Quote: | | http://www.matronics.com/contribution | 01234567890123
pdn8r(at)yahoo.com Guest
Posted: Sun Nov 16, 2008 12:35 pm Post subject: Heavy engine and Horiz. stab (Grant Corriveau) |
OK, my stupid factor is in high gear today. I'm having difficulty with the flap switch wiring as shown on 6B-20. I've attached a copy. Somebody help me out, as I can't seem to get it right. I see that the black wire from the flap motor goes to the #1 lug. Red goes to number 3 lug. Ground goes to #2. Hot wire from the buss goes to 5 Beyond that I get confused. I've attached the diagram.
Thanks in advance.
Bill Pagan
--- On Sun, 11/16/08, Chuck Deiterich <cffd(at)pgrb.com> wrote:
[quote]From: Chuck Deiterich <cffd(at)pgrb.com>
To: "zenith-list" <zenith-list(at)matronics.com>
Date: Sunday, November 16, 2008, 12:00 PM
Grant,
Chuck D.
N701TX
 Download |
| Filename: |
6B-20.pdf |
219.6 KB |
| Downloaded: |
508 Time(s) |
leinad
Joined: 19 Sep 2006 Posts: 283 Location: Central Virginia
Posted: Sun Nov 16, 2008 4:17 pm Post subject: Re: Heavy engine and Horiz. stab (Grant Corriveau) |
Bill,
The idea behind that circuit is that it reverses the polarity going to the motor. One direction and ground is connected to the black and power to the red, push the switch other way and you have the reverse situation. You could hook it up without the limit switches at all and it would still work, but you wouldn't have a switch killing the power when you get to the end of the stroke. Where the schematic shows the wire as if joined in the middle you can hook to either end. You just need wire joining the described lug on the switch to either the motor or the limit switch side that then has a wire going to the motor. I think it will help you if you imagine the circuit without the limit switches.
Hope this helps.
Dan
[quote] ="pdn8r(at)yahoo.com"]OK, my stupid factor is in high gear today. I'm having difficulty with the flap switch wiring as shown on 6B-20. I've attached a copy. Somebody help me out, as I can't seem to get it right. I see that the black wire from the flap motor goes to the #1 lug. Red goes to number 3 lug. Ground goes to #2. Hot wire from the buss goes to 5 Beyond that I get confused. I've attached the diagram.
Thanks in advance.
Bill Pagan
--- On Sun, 11/16/08, Chuck Deiterich <cffd> wrote:
| Quote: | From: Chuck Deiterich <cffd>
To: "zenith-list" <zenith>
Grant,
Chuck D.
N701TX |
_________________ Scratch building XL with Corvair Engine |
