starter housing
lcottrell
PostPosted: Wed Nov 12, 2008 12:41 pm    Post subject: starter housing Reply with quote
Hi,
Just took my engine off just now and found something that puzzled me. I do not believe that it is a problem, but I would like other opinions. The outside ring of the starter housing is cracked. All the main fastening areas are secure, I do not know when it occurred or why, possibly torqued incorrectly. I have the engine sold, but do not want to pass anything off to someone that will be a problem. I have 180 hours on the engine, have always used Penn air cooled with Marvel mystery oil and Sta bil. The pistons and rings are great, no carbon, clean as a whistle.
Larry C, Oregon
 Filesize:  174.88 KB
 Viewed:  249 Time(s)
 Filesize:  165.07 KB
 Viewed:  236 Time(s)
herbgh(at)nctc.com
PostPosted: Wed Nov 12, 2008 1:08 pm    Post subject: starter housing Reply with quote
Larry
The pic shows that the mounting ring is now out of alignment
after the crack occurred...It may be that the starter or ring was not
flat when first mounted.. and torqued down in a bind... any
way...just have it tigged.. I have seen it before... Could also be
the unsupported weight of the starter along with the weakness of the
mounting ring...especially when starting..Herb
At 02:40 PM 11/12/2008, you wrote:
Hi,
Larry C, Oregon
lcottrell
PostPosted: Wed Nov 12, 2008 1:53 pm    Post subject: starter housing Reply with quote
herbgh(at)nctc.com
PostPosted: Wed Nov 12, 2008 2:03 pm    Post subject: starter housing Reply with quote
Now I remember....the starter on a 532 engine , sitting in a bedroom, has rubber bushings of sorts between the starter and housing ring...Herb
At 03:52 PM 11/12/2008, you wrote:
ElleryWeld(at)aol.com
PostPosted: Wed Nov 12, 2008 4:25 pm    Post subject: starter housing Reply with quote
The correct term would be Heliarc it with High Freq tig alone is for Stainless and mild steel welding
Ellery in Maine
In a message dated 11/12/2008 4:09:41 P.M. Eastern Standard Time, herbgh(at)nctc.com writes:
--> Kolb-List message posted by: herb <herbgh(at)nctc.com>
Larry
Hi,
Larry C, = sp; (And Get Some AWESOME FREE find you for -Matt Dralle, List es y - MATRONICS WEB FORUMS =========================
Get the Moviefone Toolbar. Showtimes, theaters, movie news & more!
