Fuel Selector Mounting and Scat Problem
partner14
PostPosted: Sun Nov 09, 2008 9:46 am    Post subject: Fuel Selector Mounting and Scat Problem Reply with quote
For those of you working on the fuel lines in the tunnel, you may want to hold off for a couple of days. I have come up with the best solution to the several problems associated with the fuel valve and scat tubing. I will provide pictures early this next week. Pascal Reid and Dennis Mangan have already seen it and were very impressed. Honestly, it's so nice, I hate to share it.
Don McDonald
#40636
4 steps forward, 2 steps back...... again
Don A. McDonald
40636
partner14
PostPosted: Tue Nov 11, 2008 5:49 pm    Post subject: Re: Fuel Selector Mounting and Scat Problem Reply with quote
Ok, attached are the pics.... but for some of you they're huge, sorry, haven't messed with the conversion software.
I am awaiting one AN fitting, and then I can finish all the fuel lines and their connections. Also, will then have pics of the scat routing.
This part had to be made from 3 pieces, welded, and then turned on a lathe. Still working on a price... which is mostly determined by the interest. Hopefully, we can make at least 10 at a time. So if interested, please let me know. Rough price is between $40 and $70. The welding is the expensive part.
Don McDonald
#40636
 Filesize:  103.66 KB
 Viewed:  472 Time(s)
 Filesize:  229.03 KB
 Viewed:  474 Time(s)
Don A. McDonald
40636
AV8ORJWC
PostPosted: Tue Nov 11, 2008 11:48 pm    Post subject: Fuel Selector Mounting and Scat Problem Reply with quote
Don, those are beautiful and it is a thrill to watch Steve's Utube and
your post showing how to dress up the RV-10.
Keep up the great work. I will start the confirmation list offline for
bandwidth consideration.
John Cox
40600
msausen
PostPosted: Wed Nov 12, 2008 4:40 am    Post subject: Fuel Selector Mounting and Scat Problem Reply with quote
Very nice. My big concern however would be something small getting into the recess and jamming the valve action.
Michael
partner14
PostPosted: Wed Nov 12, 2008 8:14 am    Post subject: Fuel Selector Mounting and Scat Problem Reply with quote
Can't happen. Everything is screwed down so tight. I'm sure you could pour sand or/and a soda in it and not affect anything. Now maybe a handfull of gravel might be a temporary problem.
--- On Wed, 11/12/08, RV Builder (Michael Sausen) <rvbuilder(at)sausen.net> wrote:
[quote]From: RV Builder (Michael Sausen) <rvbuilder(at)sausen.net>
Subject: RE: Re: Fuel Selector Mounting and Scat Problem
To: "rv10-list(at)matronics.com" <rv10-list(at)matronics.com>
Date: Wednesday, November 12, 2008, 4:39 AM
[quote]--> RV10-List message posted by: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net> Very nice. My big concern however would be something small getting into the recess and jamming the valve action. Michael --
Don A. McDonald
40636
AV8ORJWC
PostPosted: Wed Nov 12, 2008 9:43 am    Post subject: Fuel Selector Mounting and Scat Problem Reply with quote
Michael, if you use a little less lipstick and eyeliner, there won't be
as many items to loose in the new cup.
woxofswa
PostPosted: Thu Nov 13, 2008 5:12 pm    Post subject: Re: Fuel Selector Mounting and Scat Problem Reply with quote
Don,
Okay, I'm slow, but I'm not getting how recessing the fuel selector into the tunnel cover helps with the scat tube situation.
What am I missing?
Myron Nelson
Mesa, AZ
Flew May 10 2014
partner14
PostPosted: Thu Nov 13, 2008 7:34 pm    Post subject: Fuel Selector Mounting and Scat Problem Reply with quote
I just picked up the last AN fitting needed to finish the fuel lines. Then I'll hook everything up and run the scat tubing. I believe by moving the valve forward 5", there will be plenty of room to run the scat below the existing Van tunnel, and to the right of the fuel valve. We'll see tomorrow.... I'll take some pictures. Thanks again for the hospitality at Copperstate.
Don McDonald
--- On Thu, 11/13/08, woxofswa <woxof(at)aol.com> wrote:
Subject: Re: Fuel Selector Mounting and Scat Problem
Date: Thursday, November 13, 2008, 5:13 PM
--> RV10-List message posted by: "woxofswa" <woxof(at)aol.com>
Don,
What am I missing?
Myron Nelson
Mesa, AZ
Emp completed, legacy build fuse in progress
http://forums.matronics.com/viewtopic.php?p 14028#214028
Don A. McDonald
40636
