D100 compass
Goto page 1, 2  Next
naumuk(at)alltel.net
PostPosted: Sat Nov 01, 2008 5:56 am    Post subject: D100 compass Reply with quote
All-
For those of you who have a flying Dynon D-100 EFIS w/remote compass, roughly where did you mount the remote compass module?
Thanks.
Bill Naumuk
Townville, Pa.
HDS 601MG/Corvair 95%
gfmjr_20(at)HOTMAIL.COM
PostPosted: Sat Nov 01, 2008 12:25 pm    Post subject: D100 compass Reply with quote
Bill--
  I made a small bracket for mine and mounted it on the floor behind the passenger seat. Been working fine for 240 hours.
George May
601XL 912s
Subject: D100 compass
Date: Sat C 1 Nov 2008 09:55:20 -0400
All-
    For those of you who have a flying Dynon D-100 EFIS w/remote compass C roughly where did you mount the remote compass module?
    Thanks.
Bill Naumuk
Townville C Pa.
ww.matronics.com/contribution
onics.com
Stay up to date on your PC C the Web C and ymsnnkwxp1020093185mrt/direct/01/' target='_new'>See Now [quote][b]
tshankland(at)sbcglobal.n
PostPosted: Sat Nov 01, 2008 1:33 pm    Post subject: D100 compass Reply with quote
I put mine in the back of the baggage compartment. This way it its easy to get to and I have the temperature sensor connected to the outside. One item you need to keep in mine if you actually put baggage in there make sure nothing with a strong magnet, like an electric razor ends up on your remote compass.
Tim Shankland
Bill Naumuk wrote: [quote] All-
Thanks.
Bill Naumuk
Townville, Pa.
PostPosted: Sat Nov 01, 2008 3:33 pm    Post subject: D100 compass Reply with quote
George-
With the battery and ELT on a shelf on the passenger side, I don't have any more room. However, I'm sure a shelf on the pilot side would work just as well.
Thanks.
PostPosted: Sat Nov 01, 2008 3:38 pm    Post subject: D100 compass Reply with quote
Tim-
Aft of the seats somewhere seems to be the place of choice.
Thanks.
arno7452(at)bellsouth.net
PostPosted: Sat Nov 01, 2008 4:22 pm    Post subject: D100 compass Reply with quote
Mine is also mounted on the back wall of the baggage area. Easy to access and sync the relative angle between the remote and the D-100.
Ken
CH701 912ULS N701LK
PostPosted: Sat Nov 01, 2008 4:57 pm    Post subject: D100 compass Reply with quote
Thanks, Ken.
As said before, behind the seats seems to be the place.
sanyu(at)wanadoo.fr
PostPosted: Sun Nov 02, 2008 3:23 am    Post subject: D100 compass Reply with quote
hello i am from france'stoll 701/912)
i am intrested in ther mount for the unit
is there a posibilitee to send a picture ?
thank you
www.lafermeaquatique
decorte johnny
dredmoody(at)cox.net
PostPosted: Sun Nov 02, 2008 4:33 am    Post subject: D100 compass Reply with quote
Isn't the big ole flap motor in that area?
ED
lgingell
PostPosted: Sun Nov 02, 2008 7:38 am    Post subject: Re: D100 compass Reply with quote
Aft of the left seat, riveted to the floor is far enough away from the flap motor not to be affected. This leaves room for the AP servos in the centre and the behind the right seat.
Zodiac XL/Jab 3300
http://lancegingell.com
sanyu(at)wanadoo.fr
PostPosted: Sun Nov 02, 2008 7:57 am    Post subject: D100 compass Reply with quote
i do not have a flap motot my flaps are manual
regards
decorte johnny
PostPosted: Sun Nov 02, 2008 8:33 am    Post subject: D100 compass Reply with quote
Dred+All-
Unlike the XL, the HDS doesn't have a hatch near the tail. Everything's all buttoned up and I'm not going to tear the fuse top skins off or try crawling back to the tail.
One of the listers who has 200+ hours on his system installed his unit behind the passenger seat. The tray I built for the passenger side is occupied with the battery and ELT. At the same time I built the passenger side tray I built one for the pilot's side, originally intending to mount a tool box on it. I decided against it and tore it off, because the only thing gaining weight faster than I am is my project. Pictures attached for the guy from France who wanted to see some installations.
Luckily, I haven't visited the scrap yard recently so my pilot's side tray was still around. I just stuck it in position for the picture- I'll cut it down to fit the compass unit.
One question for all D-100 owners- how did you determine if the base unit and the compass are mounted within plus or minus 1 degree of each other? I assume this is in the roll axis.
 Filesize:  46.21 KB
 Viewed:  761 Time(s)
 Filesize:  41.59 KB
 Viewed:  795 Time(s)
PostPosted: Sun Nov 02, 2008 8:34 am    Post subject: D100 compass Reply with quote
All-
Well, one nice thing about the HDS is you don't have to worry about a
flap motor!
Gig Giacona
PostPosted: Sun Nov 02, 2008 8:37 am    Post subject: Re: D100 compass Reply with quote
I built my mount for the remote compass yesterday. I"m mounting well back in the fuselage aft of the large access panel.
W.R. "Gig" Giacona
601XL Under Construction
craig(at)craigandjean.com
PostPosted: Sun Nov 02, 2008 8:46 am    Post subject: D100 compass Reply with quote
“how did you determine if the base unit and the compass are mounted within plus or minus 1 degree of each other?”
Use a digital level.
-- Craig
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Bill Naumuk
Sent: Sunday, November 02, 2008 9:33 AM
Subject: Re: D100 compass
Dred+All-
----- Original Message -----
To: zenith-list(at)matronics.com (zenith-list(at)matronics.com)
Sent: Sunday, November 02, 2008 7:29 AM
Subject: Re: Zenith-List: D100 compass
ED
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?Zenith-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
Gig Giacona
PostPosted: Sun Nov 02, 2008 8:54 am    Post subject: Re: D100 compass Reply with quote
I did the same. Assuming that the plane is built to specs the panel and the Dynon box will be level when installed.
The mount I built for rear fuselage installation had to correct for the 3 degree tilt of that area.
W.R. "Gig" Giacona
Afterfxllc(at)aol.com
PostPosted: Wed Nov 05, 2008 8:58 am    Post subject: D100 compass Reply with quote
AOL Search: Your one stop for directions, recipes and all other Holiday needs. [url=http://pr.atwola.com/promoclk/100000075x1212792382x1200798498/aol?redir=http://searchblog.aol.com/2008/11/04/happy-holidays-from-aol-search/?ncid=emlcntussear00000001 ]Search Now[/url].
 Filesize:  122.14 KB
 Viewed:  807 Time(s)
Gig Giacona
PostPosted: Wed Nov 05, 2008 9:27 am    Post subject: Re: D100 compass Reply with quote
Afterfxllc(at)aol.com wrote:
Was there supposed to be text with your photo? If so it didn't show up.
That said doesn't not mounting the remote compass remotely sort of negate the idea of having a remote compass. They provide that long wire for a reason.
W.R. "Gig" Giacona
PostPosted: Wed Nov 05, 2008 10:32 am    Post subject: D100 compass Reply with quote
This is my 3rd panel built this way and they work perfect. Why route it in some far off location if you don't have to. But what do I know.
Jeff
Gig Giacona
PostPosted: Wed Nov 05, 2008 12:08 pm    Post subject: Re: D100 compass Reply with quote
That's great that it works for you but, quoting from the installation manual...
Keep the EDC-D10A away from any source of magnetic fields (such as electrical equipment and current-carrying wires) and ferrous material.
And if your intallation is anything like any other I've seen there are a metric buttload of "electrical equipment and current-carrying wires" where yours is mounted.
But what do they know, they just built it.
Jeff
[/quote]
W.R. "Gig" Giacona
Goto page 1, 2  Next
Page 1 of 2
