cookflys(at)yahoo.com Guest
Posted: Wed Oct 29, 2008 8:54 pm Post subject: cabin heater |
My kit came with a small heater core with a computer fan attached to it. Is it worth the weight? Does it work okay? The hookups use brass fittings that weigh a ton. Other safe options?
Charles Cook
N363KF 582
ATL
paul(at)eucleides.com Guest
Posted: Wed Oct 29, 2008 9:16 pm Post subject: cabin heater |
On Wed, October 29, 2008 8:53 pm, charles cook wrote:
Quote: | My kit came with a small heater core with a computer fan attached to it. Is it worth
safe options?
A few years ago Lowell posted some pictures of the baffles he made on his oil cooler
and IIRC used scat tube to duct heat in. He's got so much skill making stuff, it might
be hard to duplicate what he did but it sure looks nicely done. Those photos might
still be in the archives.
Paul A. Franz, P.E.
PAF Consulting Engineers
Office 425.440.9505
Cell 425.241.1618
eskflyer
Posted: Thu Oct 30, 2008 5:44 pm Post subject: Re: cabin heater |
what color pot scrubber should we use for this heater lol .
_________________ FLY FUN FLY LOW FLY SLOW
John Perry
Kitfox 2 N718PD
582 cbox 2:62-1 IVO IFA
1220 Full Lotus |
Dick Maddux
Posted: Fri Oct 31, 2008 4:46 am Post subject: cabin heater |
Charles,
My cabin heater is as you describe. It puts out more heat then my Triumph TR3 (which isn't much). Overall I would say it is worth it. I use it in the winter but then I am in Florida.
And yes we do have a little winter here in the Panhandle. It gets down to the low 20's on occasion Dick Maddux
Fox 4-1200
Pensacola,Fl
Plan your ne075x1212416248x1200771803/aol?redir=http://travel.aol.com/discount-travel?ncid=emlcntustrav00000001">Check out Today's Hot 5 Travel Deals!
darinh
Posted: Fri Oct 31, 2008 10:03 am Post subject: Re: cabin heater |
My cabin heat comes from the same setup you have but uses two fans. It puts out some serious heat...enough that I can usually just run the hot coolant through the heater core and don't even need to run the fans (this is down to about 40 degrees F ambient). When it gets colder, I run the fan for 30 seconds to a minute and that is good for awhile. I think I will put the switch for the fans on a potentiometer so I can vary the speed, that way I won't have to turn it on and off. I also but a cable actuated shut-off valve in the supply line so I don't get cooked in the summer months.
_________________ Darin Hawkes
Series 7
914 Turbo
Kaysville, Utah |
patreilly43(at)hotmail.co Guest
Posted: Fri Oct 31, 2008 2:48 pm Post subject: cabin heater |
Darin C Where did you get the shut-off valve? Does it reroute the fluid flow by blocking one passage C or does it simply open the heater circuit? I need to set one up on my Mod 3.
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
Quote: | Subject: Re: cabin heater
Date: Fri C 31 Oct 2008 11:03:28 -0700
--> Kitfox-List message posted by: "darinh" <gerns25(at)netscape.net>
My cabin heat comes from the same setup you have but uses two fans. It buts out some serious heat...enough that I can usually just run the hot coolant through the heater core and not even need to run the fans (this is down to about 40 degrees F ambient). When it gets colder C I run the fan for 30 seconds to a minute and that is good for awhile. I think I will put the switch for the fans on a potentiometer so I can vary the speed that way I won't have to turn it on and off. I also but a cable actuated shut-off valve in the supply line so I don't get cooked in the summer months.
Darin Hawkes
Series 7 (Phase 1 - Flight Testing)
914 Turbo
Kaysville C Utah
http://forums.matronics.com/viewtopic.php?p=211370#211370
darinh
Posted: Fri Oct 31, 2008 8:49 pm Post subject: Re: cabin heater |
Pat,
I got the shut off valve and cable from Napa auto parts. I don't recall the part number but it was a stock item and I went through what they had until I found one that fit. It simply closes the heater circuit when shut. So far it has worked like a champ.
Series 7
914 Turbo
Kaysville, Utah |
michaega(at)verizon.net Guest
Posted: Sat Nov 01, 2008 9:06 am Post subject: cabin heater |
I think the shut off valve from Napa ($20?) is probably # 6601141 5/8" with the cable in-line to the hose. Kragen Auto # 74627 sells for around $15. You can see pictures on their Web sites.
George
darinh
Posted: Sat Nov 01, 2008 11:38 am Post subject: Re: cabin heater |
I couldn't find the Napa part # on their website but the one listed on Partsamerica.com (#74627) is the exact valve I used. Here is a pic of it from their website and a pic installed in my bird. The supplied 1/2" coolant hose took a bit of coaxing to get over the 5/8" barbed ends of the valve but with a little lubricant they will go on.
Description: |
Filesize: |
451.16 KB |
Viewed: |
609 Time(s) |
Description: |
Filesize: |
24.12 KB |
Viewed: |
596 Time(s) |
Series 7
914 Turbo
Kaysville, Utah |
msm_9949(at)yahoo.com Guest
Posted: Sun Nov 02, 2008 5:48 pm Post subject: cabin heater |
Saved from a previous post:
1970 Doge Truck heater valve Napa part # Bk 6601141 $20.00 5/8 hose size, in-line cable operated. Kragen auto parts # 74627 $13.00
Marco Menezes N99KX
Model 2 582-90 C-Box 3:1
--- On Sat, 11/1/08, darinh <gerns25(at)netscape.net> wrote:
Date: Saturday, November 1, 2008, 12:49 AM
Pat,
Darin Hawkes
914 Turbo
Kaysville, Utah
http://forums.matronics.com/viewtopic.php?p 11441#211441
Posted: Sun Nov 02, 2008 6:34 pm Post subject: cabin heater |
I ordered one from Kragen. But C they are $19.
Pat Reilly
Mod 3 582 Rebuild
Rockford CIL
Date: Sun C 2 Nov 2008 17:48:03 -0800
Subject: Re: Re: cabin heater
1970 Doge Truck heater valve Napa part # Bk 6601141 $20.00 5/8 hose size C in-line cable operated. Kragen auto parts # 74627 $13.00
Marco Menezes N99KX
Date: Saturday C November 1 C 2008 C 12:49 AM
Pat C
Darin Hawkes
914 Turbo
Kaysville C Utah
http://forums.matronics.com/viewtopic.php?p=211441#211441
tfox-List
Posted: Fri Nov 07, 2008 9:18 pm Post subject: cabin heater |
Kitfoxers C Need more coolant plumbing help. Thank you Darin and George. Received my 5/8" Kragen (Parts America) valve yesterday. Now I need 2(at) 1"x1"x5/8" tees to plumb in the heater core and a 1"x1"x1/4" tee to plumb in a "steam vent " line. My coolant tank doesn't have a provision to run the line to it. And C I don't want to spend what CPS wants for a new tank. Evidently the guy I bought the FWF 582 from didn't have a "steam" vent line. Anybody got a source for these tees?
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
Date: Sat C 1 Nov 2008 10:06:14 -0700
.ExternalClass DIV {;} I think the shut off valve from Napa ($20?) is probably # 6601141 5/8" with the cable in-line to the hose. Kragen Auto # 74627 sells for around $15. You can see pictures on their Web sites.
George
