jdbutterfield(at)yahoo.co Guest
Posted: Thu Oct 30, 2008 5:48 am Post subject: how to make the wings stronger? |
Hi List
I actually tend to believe that most of the wing accidents were caused by pilot error/judgment. However, not being an engineer, am wondering how one would go about making the wings stronger. There must be a way we could modify the wing/attaching points or whatever to add a lot of strength to the wing assembly. I have no idea or experience on how this could be done, but i am sure there are plenty of people on this list that could figure out a way. It may be lighter and cheaper that getting a parachute system. Even a parachute won't help if a wing falls off at low altitude. I certainly would give up a few (lot) pounds to not to ever have to worry about wing departure.
john
XL, corvair
Torrance, CA
countzero
Posted: Thu Oct 30, 2008 6:03 am Post subject: Re: how to make the wings stronger? |
Hello John,
You could reduce the loading on the wings by lowering your gross weight. This is not the same as improving the structure pound for pound but is far simpler for you to do.
Rob
jaybannist(at)cs.com Guest
Posted: Thu Oct 30, 2008 6:16 am Post subject: how to make the wings stronger? |
John,
This is not intended as a "flaming" response. I just want share my thoughts on structural modifications.
An aircraft structure is one of the most interdependent structural systems there is. You can't just "beef up" one part without knowing how that effects stresses on adjacent parts and parts adjacent to those. A building designer wouldn't dream of adding a floor to a high-rise building without checking all the existing columns, beams and foundations to see if they could take the additional weight and moments. In order to do that, he would have to have access to, and understand all the structural calculations. The same applies to an airplane. I would not trust ANY structural modification unless I knew, without a doubt, that all the structural design calculations had been checked and that they would allow such a modification. An airplane structure is just not a good thing to "tinker" with.
Jay in Dallas
zodierocket(at)hsfx.ca Guest
Posted: Thu Oct 30, 2008 6:37 am Post subject: how to make the wings stronger? |
When we look at the incidents, some are looked upon as pilot error, a
thunderstorm comes to mind. But also keep in mind that mechanical errors
can also creep in (missing bolts and cable tension are foremost in my
thoughts). There are many flying 601XL's and quite a few have amazing
hours accumulated. Zenair has time and time again tested the design for
many countries standards as well as use a 3rd party to test the
structure.
One thing I have seen in looking at some planes is that the cables are
not to spec in tension. These may have been set properly prior to first
flight but not stretched, which would allow slacking. We also tend not
to own a tension meter of which I would recommend having.
We have read letters from Chris on Zenith's website and AMD's as well as
a letter in the Zenair Newsletter about the importance of cable tension.
Attached is a letter issued from Zenair Europe as an AD. In America we
can only see an AD from the FAA so if we look on Zeniths website we see
a Zenair Safety Alert at
http://www.zenithair.com/zodiac/xl/data/ad-ze-2008-01.pdf
Read this and take it to action. IF you have been flying your plane
check it before next flight with a proper gauge. IF you're building
remember to pre-stretch your cables and check often during initial
flights and in a set interval during the life of the plane.
Entertaining an idea of changing a design that bears up in mathematical
and physical structural testing seems fool hardy and ill advised.
Ensuring that your plane is to standards as set forth by designer and
AC43-13b would be far more prudent and well in the reach of each
builder.
My Thoughts.
Mark Townsend Alma, Ontario
Zodiac CH650 C-GOXL, CH701 Rotax 912,
STOL CH750 Just started
www.ch601.org / www.ch701.com
 Download |
| Filename: |
AD#_ZE-2008-01.pdf |
21.22 KB |
| Downloaded: |
672 Time(s) |
K Dilks
Posted: Thu Oct 30, 2008 6:44 am Post subject: Re: how to make the wings stronger? |
The euro plane empty weight is quoted as 265 KG
most empty zodiacs come in at 320 to 340kg
So besides the undercarrige where else can they save that much weight.
I have looked hard to day around the net but I am sure they are using ,16 skins. Maybe not on CZAW planes but on the ones from Dynaero in Portugal..
Not also the the data for loading . 6g is the ultimate so operational is 4g . I wonder if guys are pulling 6 thinking there safe.
The lower figure of 4 is somtimes give and is on the plans.Check ZAC web site.
All in all with so many versions and makers / suppliers this is quite a mess to work out.
_________________ Back home ................. |
z601(at)anemicaardvark.co Guest
Posted: Thu Oct 30, 2008 8:16 am Post subject: how to make the wings stronger? |
On Thursday 30 October 2008 08:48, john butterfield wrote:
| Quote: | I actually tend to believe that most of the wing accidents were caused by
the wing assembly.
<snip>
First, let me say I agree with the caution that one cannot change one part of
a structure without considering the impact on the rest of the structure. We
can't afford to make structural changes to the design, without a lot more
information than is available.
Having said that, it has appeared to me (since I first looked at the design)
that the 6 AN5 bolts which connect the wing spar to the carry-through spar
are pretty small and few in number to the task. There isn't that much overlap
between the wing spar and the carry-through spar to transfer the wing loading
to the rest of the structure.
The commercial designs with which I'm most familiar had more and larger bolts,
and in some cases, close-tolerance bolts. There is, as I recall, much more
overlap between the spars to allow for reasonable spacing between the extra
bolts.
Is this the problem? Only the results of the various accident reports will
tell. But it could sure cause wing separation, if it is.
Those who can, do. Those who can't, sue.
Jim B. Belcher
BS, MS Physics, math, Computer Science
A&P/IA
Instrument Rated Pilot
General Radio Telephone Certificate
Martin Pohl
Joined: 30 Jan 2006 Posts: 118 Location: CH-8645 Jona SG, Switzerland
Posted: Thu Oct 30, 2008 8:17 am Post subject: Re: how to make the wings stronger? |
The average empty weight for CZAW CH601XLs seems to be around 310 - 320 kg. The new European version might be different.
I checked my kit and I can assure that (on my CZAW 601XL) the wing sheet thickness is 0.025".
Cheers Martin[/quote]
_________________ Martin Pohl
Zodiac XL QBK
8645 Jona, Switzerland
http://www.pohltec.ch/ZodiacXL/Main.html |
Joemotis(at)aol.com Guest
Posted: Thu Oct 30, 2008 4:46 pm Post subject: how to make the wings stronger? |
Maybe we should learn from this pilot!
http://www.youtube.com/watch?v=XRCbkBfdBrQ&eurl=http://www.chilloutzone.de/files/08102703.html
This is incredible.
Joe Motis
In a message dated 10/30/2008 9:17:07 A.M. Pacific Daylight Time, z601(at)anemicaardvark.com writes:
| Quote: | --> Zenith601-List message posted by: Jim Belcher <z601(at)anemicaardvark.com>
the wing assembly.
<snip>
bolts.
Jim B. Belcher
A&P/IA
===================e the es y --> - MATRONICS WEB FORUMS nbsp; - List Contribution Web Site ; =========================
Plan your next getaway with AOL Travel. Check out Today's Hot 5 Travel Deals!
Posted: Thu Oct 30, 2008 5:00 pm Post subject: how to make the wings stronger? |
Yeah (as previously mentioned) it is a pretty good fake:
http://www.avweb.com/blogs/insider/AVwebInsiderBlog_ViralVideo_KillaThrill_LostWingLanding_199096-1.html
-- Craig
From: owner-zenith601-list-server(at)matronics.com [mailto:owner-zenith601-list-server(at)matronics.com] On Behalf Of Joemotis(at)aol.com
Sent: Thursday, October 30, 2008 6:45 PM
Subject: Re: how to make the wings stronger?
This is incredible.
Joe Motis
> the wing assembly.
<snip>
bolts.
Jim B. Belcher
A&P/IA
| Quote: | | http://www.matronics.com/Navigator?Zenith601-List | 0123456789
Posted: Thu Oct 30, 2008 5:17 pm Post subject: how to make the wings stronger? |
It certainly faked me out!
Joe Motis
In a message dated 10/30/2008 6:01:02 P.M. Pacific Daylight Time, craig(at)craigandjean.com writes:
-- Craig
This is incredible.
Joe Motis
the wing assembly.
<snip>
bolts.
Jim B. Belcher
A&P/IA
0 |
paulrod36(at)msn.com Guest
Posted: Thu Oct 30, 2008 6:55 pm Post subject: how to make the wings stronger? |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> I'm not an engineer, and don't even play one in commercials, but I don't recall anything surfacing in any of the failures that indicated sheared through-bolts. 6 AN5's per wing ought to hold several thousand ponds more then 1320 at 6G's. However, the Dutch report is the first one, I think, to have mentioned that the spar reinforcements were twisted and bent outside the wing/fusalage connection. If memory serves, at that point you have two (roughly) quarter inch by one and a quarter solid aluminum bars, a web of .040 or .060 sheet, and a flange of .040, for top and bottom. All of that is held by driven rivets (I forget the size) It would be really useful to see pictures of the failed area. Could the rivets have not been tight? If the rivets didn't do their job, then the individual units weren't supporting each other, and the reinforcement bars could have given, one by one. Just a theory........
Paul Rodriguez
601XL/Corvair
