Air Vents
jimpuglise(at)comcast.net
PostPosted: Wed Oct 29, 2008 2:20 pm    Post subject: Air Vents Reply with quote
I have an NACA vent in my rudder and tubing running forward to the overhead panel in the cockpit. I would like to install a couple of overhead vents similar to those in airliners. What have others used and where do you get them?
Jim Puglise A-283, Punta Gorda, FL
europa(at)pstewart.f2s.co
PostPosted: Wed Oct 29, 2008 3:41 pm    Post subject: Air Vents Reply with quote
Jim
I used a couple of aluminum eye ball vents not in same position but the same idea. Pretty sure they came from aircraft spruce.
Paul
[img]cid:8105FF01-C0B3-4245-88F3-7AF55A2431C5[/img]
On 29 Oct 2008, at 22:19, jimpuglise(at)comcast.net (jimpuglise(at)comcast.net) wrote:
href="3D"http://forums.matronics.com"">http://forums.matronics.com
href="3D"http://www.matronics.com/contribution"">http://www.matronics.com/contribution
 Filesize:  12.02 KB
 Viewed:  385 Time(s)
DuaneFamly(at)aol.com
PostPosted: Wed Oct 29, 2008 7:35 pm    Post subject: Air Vents Reply with quote
Jim,
I have installed these in the same setup that you have. http://www.aircraftspruce.com/catalog/appages/alumeyeball.php
My vent tube from the rear connected to an open space in the overhead just behind my head and I installed two of these vents....one for me and the other for my passenger.
Mike Duane A207A
Redding, California
XS Conventional Gear
Jabiru 3300A
Sensenich R64Z N
Ground Adjustable Prop
A Good Credit 11625659x1200715650/aol?redir=http://www.freecreditreport.com/pm/default.aspx?sc=668072&hmpgID=82&bcd=emailfooter"> See yours in just 2 easy steps!
h&jeuropa
PostPosted: Thu Oct 30, 2008 3:32 am    Post subject: Re: Air Vents Reply with quote
The RV guys use the one's available from Stein Air (www.steinair.com). Supposedly much stronger construction, better seals and low friction wear surfaces. But also kinda expensive.
Jim Butcher
N241BW
air.guerner(at)orange.fr
PostPosted: Thu Oct 30, 2008 4:03 am    Post subject: Air Vents Reply with quote
Jim,
From experience, ACS air vents are either cheap plastic ones which are not good quality and fail quickly or very expensive aluminum ones. Another source is SteinAir. http://www.steinair.com/eyeballvents.htm
They sell high quality aluminum vents at a more reasonable price.
Hope that helps
Remi Guerner
F-PGKL
panel in the cockpit.=C2- I would like to install a couple of overhead v
ents similar to those in airliners.=C2- What have others used and where d
o you get them?=C2- >>>>>
