Posted: Wed Oct 29, 2008 10:41 am Post subject: Non-Moving EGT's |
At 07:51 PM 10/26/08 -0700, you wrote:
| Quote: | I am still chasing egts. I raised my needle one notch and am still getting
right at 1200o but then engine runs just as well as it did before the
adjustment. I am going to read the plugs next time I get the airport.
Grant,
If you raise the needle and the EGT's do not move down, it may indicate that
the main jet is limiting fuel flow. Try increasing your main jet to the
next larger size.
Jack B. Hart FF004
Winchester, IN
Dana
Posted: Wed Oct 29, 2008 1:43 pm Post subject: Non-Moving EGT's |
Grant,
next larger size.
Is this full throttle EGT? The needle should be completely out of the jet
and have no effect at full throttle, no?
-Dana
Can I deduct last years taxes as a bad investment?
grantr
