fuel pump etc
Rowland_Carson
PostPosted: Sun Oct 26, 2008 2:57 pm    Post subject: fuel pump etc Reply with quote
I'm intending to fit aluminium pipe (and braided nitrile) instead of
the smelly rubber stuff and am trying to plan the pipe runs from the
fuel selector area back to the fuel pump. It seems wise to put the
aluminium pipes in before I stick down the cockpit module, although
the manual leaves it to much later for the rubber pipes.
The picture on page 6-4 of the 912 FWF manual seems to show that the
pipe from the selector goes back near the fuselage floor (or perhaps
higher up at the port side of the tunnel), and that the pipe coming
forward from the pump runs near the top of the tunnel through the
tank.
I guess this is all in line with the philosophy of a gradually-rising
pipe from tank to engine - but obviously it can't quite adhere to
that throughout.
I don't want to clip a pipe in a position where it will get in the
way of stuff to be installed later such as the flap actuation
mechanism.
I plan to install an Andair gascolator, and the obvious place where
there is some room for that is alongside the pump.
Does anyone have any advice or comments about:
(a) the routing of aluminium pipes from the selector area to the pump;
(b) the location of an Andair 375 gascolator.
Are there any pictures online of the SS502 / 40106 pump (apparently a
Facet item) or an Andair 375 gascolator installation for a 912s?
regards
Rowland
| Wilma & Rowland Carson http://home.clara.net/rowil/
| <rowil(at)clara.net> ... that's Rowland with a 'w' ...
DuaneFamly(at)aol.com
PostPosted: Sun Oct 26, 2008 4:33 pm    Post subject: fuel pump etc Reply with quote
This is what I did.....
A Good00075x1211625659x1200715650/aol?redir=http://www.freecreditreport.com/pm/default.aspx?sc=668072&hmpgID=82&bcd=emailfooter"> See yours in just 2 easy steps!
 Filesize:  376.39 KB
 Viewed:  504 Time(s)
 Filesize:  378.15 KB
 Viewed:  446 Time(s)
ptag.dev(at)tiscali.co.uk
PostPosted: Mon Oct 27, 2008 1:25 am    Post subject: fuel pump etc Reply with quote
Hi! Rowland
I always have difficulty remembering if you are building trike or Mono?
However I personally would be bothered about stressing the pipework if
you do it prior to stabilizing the module in the fuselage. It must be in
a relaxed mode with flexible mountings.
The Facet pump must be at 45deg to horizontal along the flow line to the
lowest point of the fuel system.
I've used braided rubber throughout and the fuel system module is
mounted on the belly plate where the mono would have been. However I
also have two electric pumps and two mini Andair Gascolators being a
914.
Bob Harrison G-PTAG 337
bdanbish(at)gmail.com
PostPosted: Mon Oct 27, 2008 11:40 am    Post subject: fuel pump etc Reply with quote
Hi Rowland,
I spent a lot of time messing with the fuel system and ended up with something I think I'll be happy with. View the album in the gallery at:
http://www.europaowners.org/modules.php?set_albumName=album164&op=modload&name=gallery&file=index&include=view_album.php&page=1
Keep in mind that I'm installing a 914 in a mono so it might not apply to your build. This is a series set up using manifolds, 1 from Aircraft Spruce and two from McMaster Carr (I think). It has an Andair fuel selector, gascolator, and check valves. I put everything on removable breadboards in case I've got to get at it later, easily accessible through the baggage bay and I also installed duplicate fuel filters both in the seat pan and back near the pumps (see photos). Overkill for sure, but I plan to run the first 30 hrs or so with this set up then possibly remove the rear filters.
All my work was done AFTER the cockpit was installed since I bought a used kit with that already done. I would have much preferred to do it before the cockpit was in, especially putting the GS fuel fittings into the tanks. As you can see, I had to make holes in the seat areas in order to get those in. Also, I haven't put in a sight gauge. I have the fuel level sender in the tank and a fuel computer that will calculate the flow and return from the 914 into a Dynon D180, so that should do it. I still have the option of adding one later in this set up though.
I had to redo the versatube several times to get it right but it's spot on now. To simplify things, I have the fuel runs running through the cockpit instead of the tunnel, but hoping that won't become an issue (fingers crossed). Everything is versatube where possible, with Gates R9 fuel injection hose used everywhere else as it has a Teflon lining which is supposed to prolong life. The only place I used R7 was the very short run near the pumps where I couldn't find any of that size in R9.
Let me know if you have any questions,
Dan
Visit - www.EuropaOwners.org
Rowland_Carson
PostPosted: Sun Nov 02, 2008 2:56 pm    Post subject: fuel pump etc Reply with quote
Mike - thanks for the nice pictures. The layout looks neat ....
But shouldn't the gascolator be ahead of the fuel pump in the sequence?
And all the advice I've seen is that the pump wants to be mounted at
45 degrees, or at least have its inlet lower than its outlet.
regards
Rowland
Rowland_Carson
Bob - I'm a mono.
I'm not intending to fix it down yet, just want to get it in roughly
the right place. I recognise that the aluminium needs to be fixed in
a non-stressed position and not subject to any movement or vibration.
That is great for flexibility and s/s braiding is very robust but
heavier (and more expensive) than the aluminium, and can't do really
tight bends.
Thanks for your input.
regards
Rowland
PostPosted: Mon Nov 03, 2008 1:55 am    Post subject: fuel pump etc Reply with quote
Hi! Rowland
Don't know about "ahead" of fuel pump for gascolator. But IMHO in
direction of flow terms the gascolator needs to be between tank and pump
(Of course in this context "ahead" may be the same). The last thing you
need in the pump is unfiltered fuel.
Bob H G-PTAG
ami(at)mcfadyean.freeserv
PostPosted: Mon Nov 03, 2008 3:04 am    Post subject: fuel pump etc Reply with quote
Depends on the type of pump.
A roller-cell pump (914 etc) is very intolerant of dirt (it scores the
traces in the pump). The shuttle type pump (eg Facet) is far more tolerant.
Both types of pump are much better at pushing than pulling; so any partial
blockage of a filter on the suction side will test the ability of the pump
to suck (typically a maximum suction head of 0.6m is quoted for roller cell
pumps; much of this allowance can be used up with high flow rates and the
tortuous plumbing frequently seen). This is asking for trouble, particularly
if Mogas is being used.
Duncan McF.
PostPosted: Mon Nov 03, 2008 6:50 am    Post subject: fuel pump etc Reply with quote
Hi! Duncan
Yes I understand but of course there is generally a "head" assisting the
suction side of the pumps since they are on the belly plate. My reserve
side is my main fall back system but at least the gascolator filters do
allow for quite a volume of contamination before blocking and regular
water drain checks AND gascolator drain checks should give adequate
insurance.
My previous experiences of blockage was the "dog hair and cloth fibres"
in a bad drilling intersection of the Europa Tank Connectors. Now with
Graham Singleton's connectors fitted at least the "crud" gets through to
the gascolators . I'm no longer using the gauze type finger filters but
brass tubular with many holes drilled and deburred so as not to catch
the fibres etc. Still I had the problem with water and rust which I
believe I picked up in Europe. I use white plastic drums to fill locally
with visual inspection of the drum bottom prior to using one of Alan
Burrows electric pumps which doesn't reach the bottom anyway.
However it still didn't show in the tank water drains. When I ground the
a/c soon for the Mode S fiasco I will have the tank top off and do wipe
out.
At least the gascolators will accommodate a reasonable volume of water
before blocking, if "REASONABLE" IS THE WORD!
Bob Harrison G-PTAG
gregoryf.flyboy(at)comcas
PostPosted: Tue Nov 04, 2008 2:43 am    Post subject: fuel pump etc Reply with quote
It seems that decreasing the pumping volume in the lines up to the intake of
the pump would speed the fuel through a bit quicker, especially in partially
blocked filter situations (So I wonder if 'tortuous plumbing' could mean:
bigger fuel lines). I am considering a slightly smaller inlet area to the
pumps, than on the output of the pumps. For example: 5/16" aluminum tubing
on the input to the pump, and 3/8" on the output, though haven't verified
the flow rate for the 5/16" yet (at pressure, -intend using 914).
Originally, I was going to mount the filters under the seat (before the
pumps, to protect them), and the gascolator well 'behind' the pumps in a
typical area, up front by the engine, but have seen a few engine outs due to
fuel starvation of just one filter. One could always switch to the reserve
tank, but in the 'heat of the battle' of takeoff, that could be considered
difficult or dangerous. Now the filters intended position will be moved to
just before each pump (in the series//parallel mode, next to the Andair
check valves), and a water drain/check mounted in the seat well, in place of
where the filter was to originally go.
Rowland, I am currently planning to go the route you were surmising, and
will put 3/8" aluminum in the long runs through the cockpit module (pump to
engine, engine return back to tank). This will obviate the need to replace
the rubber there. The lines are being installed now, before the module gets
cemented in place. I have the Tri-gear, and am running the fuel line roughly
where the manual calls it out, a bit below the top of the center console.
Hopefully, it will be adequate (fingers crossed).
Looking at all the fittings needed (and the lack of), hooking it all
together seems a bit overwhelming. It is hard to find 5/16" of anything
articulate, and many things on the Europa use 5/16". I think the pump needs
a 5/16 to 12mm adapter (from memory, so it may be wrong). The Andair check
valves could use 3/8 or 1/4" fittings, and so on. Don't know what the return
feedline needs from the regulator output. Many options, and also many
limited options. If anyone has produced a table, or schematic, or drawing of
all the different fittings sizes, and where they were used, it would be oh
so most helpful to me, as I have already pulled out some of my hair Smile. Even
if it isn't the exact way I will be implementing, it would still give a good
idea of what fitting is needed where...
Greg Fuchs
A050 XS TRI 914
Rowland_Carson
PostPosted: Tue Nov 04, 2008 3:54 pm    Post subject: fuel pump etc Reply with quote
Greg - here's the list I have prepared so far, for a 912S installation.
Port outlet, tank fitting A, side 1/4" NPT
AN822-6D elbow
AN819-6D sleeve & AN818-6D nut
3/8" OD aluminium tube
AN822-6D elbow
FS20x7F Andair left inlet
Starboard outlet, tank fitting B, side 1/4" NPT
AN822-6D elbow
AN822-6D elbow
FS20x7F Andair right inlet
FS20x7F Andair bottom outlet
GAS375 Andair gascolator inlet
GAS375 Andair gascolator drain
DV125 Andair drain valve
GAS375 Andair gascolator primer port
NP125 Andair 1/8" NPT plug (AN913-1D)
GAS375 Andair gascolator outlet
AN6 to 1/8" NPT straight or elbow?
Fuel pump inlet
Fuel pump outlet
AN6 to 1/8"NPT straight or elbow
AN832-6D bulkhead union & AN924-6D nut
101-06 aluminium hose-end straight
100-06 SS braided nitrile hose
Engine-driven pump inlet - 8mm - Speedflow hose finisher clamp
Engine-driven pump outlet - 6mm - what? - to carbs
Carbs fuel return through restrictor + 6mm adaptor?
AN823-6D elbow
Vent, tank fitting C, side 1/4" NPT
Port outlet, tank fitting A, end 1/8" NPT
AN914-1D elbow
Starboard outlet, tank fitting B, end 1/8" NPT
AN914-1D elbow
Andair drain valve
Port outlet, tank fitting A, side 1/8" NPT
AN842-4D elbow
Restrictor
TU23RM 6mm polyurethane sight tube
AN838-4D bulkhead elbow & AN924-4D nut
Filler moulding top end
Vent, tank fitting C, end 1/4" NPT
AN823-6D elbow
AN833-6D elbow & AN924-6D nut
AN833-4D elbow & AN924-4D nut
AN819-4D sleeve & AN818-4D nut
1/4" OD aluminium tube to atmosphere
This is still subject to editing in the light of experience - but I
hope it will be of some use.
Note that I am planning to leave out the factory-supplied glass
filters which are intended to be fitted upstream of the selector. My
thinking is that the filter area in the Andair gascolator is so much
bigger than the factory ones, and it will be so much easier to check,
that having 1 filter instead of 2 will not increase risk of fuel
starvation significantly.
I am also planning to modify Graham Singleton's sight gauge
modification, by taking the upper end to the filler moulding instead
of the top tank vent. I've heard reports of fuel coming back down
from the vent when the tank is filled and causing airlocks in the
sight gauge.
BTW, apologies for my late responses to the original replies to my
posting. The Matronics list server suddenly decided to reject my
messages, thanks to a badly-configured spam filter, and it was
several days before i could get through again.
regards
Rowland
| Rowland Carson LAA #16532 http://home.clara.net/rowil/aviation/
| 1150 hours building Europa #435 G-ROWI e-mail <rowil(at)clara.net>
PostPosted: Tue Nov 04, 2008 7:33 pm    Post subject: fuel pump etc Reply with quote
Hi Rowland,
See responses below:
I am sure it will, and will take a look at this tomorrow. Tonight I have an
election result family gathering to tend to.
I am sure it will, I thought it might be you, that had some info on this,
being one of the more thorough of anyone on the site.
Good point. It sounds like a better than factory arrangement. I too, will
not be using the glass filters. They will be replaced however, by two more
filters (yet to be determined), with a very large surface area on its filter
media. They will be downstream of the selector, as well, and each will be
installed on the input to the pump. The Andair gascolator (I plan to install
it near the engine) will be the large one, with increased surface area, as
well. I have not thought it out yet, but plan to have pressure or suction
measurements on both pumps, to provide advanced warning to failure of either
side (pump-filter combos). Unfortunately, there will be 3 filters to tend
to, as opposed to 1. Two though, basically care for themselves (with
real-time feedback), and the other will be checked before each flight, for
water mostly.
sight gauge.
I decided to skip the glass sight gauge for now, and see how the special
tubing that others have tried (the pvc with Teflon lining inside) works
first. It runs up the seat-back, but final supports for it will come
later(it needs a slightly wider turn radius, to prevent kinking of the
Teflon liner). That seems to be the more simple way, for now. Alternatively,
all of the turns will be replaced with normal multi-fuel capable black fuel
hose, and the 'special' tubing will be only used at the sight area, using
some fittings.
The site tube connection to the filler tube seems to be a good way to go,
for more than one reason(fuel spillage, air pressure, ?).
ALAN YERLY has some good pics on sight tube location at
customflightcreations.com. It seems to be about the same.
I was delayed too, but I was just busy. Your excuse is a bit better than
mine SmileSmile
Greg F.
XS TRI 914
Rowland_Carson
PostPosted: Wed Nov 05, 2008 3:25 pm    Post subject: fuel pump etc Reply with quote
Greg - thanks for your kind words. Some have been less complimentary
in their choice of phrase; I got "pernickity" twice at a
team-building event when folk were asked to pick one adjective for
each participant. I take comfort, though, from the fact that none of
them ever complained about me being pernickity when I was
pre-flighting an aircraft they were shortly to be a passenger in!
Attached as PDF is another way to look at the list of parts, courtesy
of FileMaker Pro (where I make most of my lists), showing what
connects to most of the parts. I find doing this sort of list helps
to highlight any inconsistencies in my planning.
The parts at the top without AN prefixes are from Speedflow, a UK
supplier of race car plumbing parts.
regards
Rowland
| 1160 hours building Europa #435 G-ROWI e-mail <rowil(at)clara.net>
fuel_parts.pdf
 Filename:  fuel_parts.pdf
 Filesize:  23.22 KB
 Downloaded:  587 Time(s)
PostPosted: Wed Nov 05, 2008 11:10 pm    Post subject: fuel pump etc Reply with quote
Sure thing!
Not ever! Smile#)
I've got it in the print queue. Thanks.
We have a similar supplier here in Portland, OR. I may have to cross
reference.
regards
Rowland
Thanks again, I appreciate the help, Rowland.
Greg
DO NOT ARCHIVE
