Gary Weaver
Peter H
Posted: Mon Oct 13, 2008 9:57 pm Post subject: Tach ?? |
I have a VDO that works from the alternator or from the trigger supplied or
from coil negative earth.
Peter
| | - The Matronics JabiruEngine-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?JabiruEngine-List |
Lynn Matteson
Posted: Tue Oct 14, 2008 2:29 am Post subject: Tach ?? |
It is digital, but no problems with my Grand Rapids EIS....lots of
info besides rpm, too.
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200, 562 hrs, temporarily grounded; igniton parts will arrive
Friday; flight soon after.
On Oct 13, 2008, at 11:37 PM, Gary Weaver wrote:
<gweaver(at)nctv.com>
What are you guys using for a tach? I'm not having much luck with
UMA, I'm on number two and it doesn't work !! The one from jabiru
(VDO) is not going to work either(boat tach). Other than a digital
is there anything else that works?? [Shocked]
http://forums.matronics.com/viewtopic.php?p 8648#208648
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Gary Weaver
Posted: Wed Oct 22, 2008 6:52 am Post subject: Re: Tach ?? |
Peter,
Do you have a part number? Is it a 3and a 1/8 inch? UMA redid this one and it works sort of,, well it dies at 750 RPM but any thing above that works great. Flew it yesterday for the first time.
Gary
263.55 KB |
551 Time(s) |
checkpoint2(at)COMCAST.NE Guest
Posted: Wed Oct 22, 2008 8:21 am Post subject: Tach ?? |
I have had 3 VDO tacks,a little over 200 hrs. in my Jabiru powered
Alpi So far this new one is working ok. If you find a good replacement don't
keep it a secret! Bob Haas 380HB.
Peter H
Posted: Wed Oct 22, 2008 1:35 pm Post subject: Tach ?? |
Gary
I purchased from the local Australian agent SGESCO.MAX. They provide tel
advice if there is a problem.
The part number given is 333015038 and it also displays engine hours in an
LCD display. The installation details are provided by VDO in a flyer which
tells how to connect it to drive it from the alternator, the neg earth or
the small HE sender supplied. They also supplied a noise suppression diode
which I am using with the alternator connection.
Peter
